Posts posted by Kevin Kenny
- Ryland Craze, Pio, mtaylor and 4 others
- 7
- KentM, druxey, EricWilliamMarshall and 9 others
- 12
Makes me so envious looking at your fine work.
- mtaylor and giampieroricci
- 1
- 1
Hi Yves
No it has no smell. Coffee is grown on a tree and very old plantations produce a trunk that can be 6” wide. when the trees become old and tall they are usually felled and the coffee grove replanted. The wood was i]usually discarded. One of the biggest challenges in building scale wooden models is seeing grain in the wood used to make the models. Coffee woods grain is almost invisible and the colour is as white as you are going to get. It has turned out to be a fantastic deck board or strake which gives great contrast to other woods used on the model . The deck of the Thorn is coffee wood.
- yvesvidal, mtaylor, TomShipModel and 1 other
- 4
Just finished converting all the coffeewood trees to planking material. I noticed some termite droppings so decided to get on the saws and cut everything up. It was a messy job but glad it is over. Only one piece of stock was infected. Ill spray all the balance. I now have enough for several models.
- Seventynet, mtaylor, TomShipModel and 8 others
- 11
I plan to plank the complete model.
- mtaylor, Ryland Craze and druxey
- 3
Henry 50 inches will give you a reading on the caliper of 1.04” at 1/4” scale. As Greg says above, you need to establish the upper deck beams in place to accurately calculate the height.
. If you are going to measure the height just above the upper deck beam ( as i did) you will have to add 3” which is the thickness of the deck planking. So the measurement from the top of the upper deck beam to the top of the pin is 3+50 =53” or 1.102” on the caliper.
I cant remember as that was so long ago. I still say the key is the location of the beams. The photos i shared give you a good idea of the correlation. Looking back at the notes that i sent you it is clear that i was estimating the measurements above the main deck. They should have given us the measurements. I have it as 27” above the main deck.
This is why today i have a written log so i can tell you why and what i did.
Lighting upgrade to Proxxon band saw
in Modeling tools and Workshop Equipment
This cost me $15 and I was able to hook it up to the saw switch so it comes on when the saw is turned on.
