Posts posted by Kevin Kenny
I follow the art of boat building as well and you are right. What i find so interesting is that we follow as much as we can, the same techniques in model building. Sometimes it so hard to see the techniques but in full scale it becomes so obvious .
kevin
- Knocklouder, dvm27 and mtaylor
- 3
- KentM, GrandpaPhil, AON and 3 others
- 6
When you dont know what you are doing you can purchase all sorts of useless crap on line. I purchased the gauges along with the portable valves (just to cover my donkey) to set up the Chinese knockoff of the Smith Little torch. The oxygen worked fine but when i tried to connect the gas gauge (LPG) there was no local supplier that could accommodate me with the CGA 200 connection on the gauge. Then i went to at least 10 different wielding suppliers and non could help me find an adaptor. Thank goodness i purchased the small bottle valves.
eventually i was able to hook up a medical oxygen bottle ( of which i have 2) to the Bernzomatic gas and got it to work. A real pain in the donkey -
- GrandpaPhil, dvm27, AON and 2 others
- 5
Why not blacken brass or copper?
- mtaylor and French Mr Bean
- 2
- GrandpaPhil, ccoyle, chris watton and 9 others
- 12
- Dave_E, GrandpaPhil, No Idea and 2 others
- 5
- chris watton, ct mike, KentM and 3 others
- 6
- giampieroricci, AON, ct mike and 11 others
- 14
You forget that we did this on the internal planks. This would have been so much easier to do on the external planks but the book did not want us to use stealers, so we followed the book. I have to say this is the first time i shaped both ends of all the strakes for the entire hull rather than force bending them into shape and what a difference it made. I was always worried that having to finish the open side of the plank would result in irregular surface causing a difficult joint when the next row of planks was applied, but this turned out not to be so. I found that the hand plane made it very easy to prepare a nice smooth line on the exposed side of the plank.
- KentM, Speedy, GrandpaPhil and 7 others
- 10
Your ability to line up and cut the recesses for the carlins is so accurate and is excellent. Can you describe the process. Kevin
- bdgiantman2, Mirabell61, KentM and 1 other
- 4
HMS Thorn by Kevin Kenny - 1:48 scale - Swan-class - David Antscherl practium
Now complete
