Posts posted by Kevin Kenny
Too much traveling. 25 days in NY. Then back to Tobago for a wedding. Ill finish strake 5 tomorrow and then start closing up the last two bands.
- Ryland Craze, scrubbyj427 and mtaylor
- 3
- scrubbyj427, AON, Ryland Craze and 6 others
- 9
Haha, it caused some strife, but in the end she was very accommodating.
Alan if you want to get a good finish you will need to place some temporary strakes inside the model. Use PVA which you can easily remove with 90% alcohol when you are finished and you will never know you put them there. The problem with sanding at this point is that there is too much movement in the frames. The temporary strakes solve this problem. When you are happy with the outside you reverse the process and temporary plank the outside and sand the inside.
kevin- scrubbyj427, bruce d, allanyed and 1 other
- 4
Its an interesting response as in the Swan practium a number of the sheaves a number of the blocks contain Bronze sheaves.
- mtaylor and thibaultron
- 2
Does anyone know when sheaves were changed from Lignum vitae to brass?
- thibaultron and mtaylor
- 2
sorry but I had to remove the first time I uploaded this as I had a music copywriter problem. Now resolved.
Video 94
- Seventynet, ct mike, James G and 5 others
- 8
- No Idea, Seventynet, mtaylor and 9 others
- 12
HMS Thorn by Kevin Kenny - 1:48 scale - Swan-class - David Antscherl practium
Thats what i figured. I used this system with the first set of planking. I did not feel that it mattered with strake 1-5. But fair enough. Ill do it for the last two bands
