Posts posted by Kevin Kenny
I decided to update my table saw video on safety to include Kurts advice and my subsequent additions. .
- James G, KentM, usedtosail and 5 others
8
Tom, i did not make a video on the clamp extension arms but it was easy to make. I used some hardwood, in my case some green heart, cut a slot so the original clamp ends can fit down inside the slot and filled with epoxy. When a lot of pressure is placed on the arms i do get some bend. I plan to make two more using aluminum arms to see how they work out. I also feel they are too long and will make up a set that is only 3” deep. Also i added sand paper at the very end as when a lot of pressure is used they tend to slip. Once the sand paper was added that problem disappeared. I also made up some extensions which help me get into close up situations.
- ct mike, GrandpaPhil, dvm27 and 5 others
8
In the tropics all untreated wood is subject to damage from dry-wood termites and woodworm damage. I have actually had one of my finished models attacked and had to treat the internal wood with liquid fluid and then gassed the model and case to kill all insects under the cover. Liquid termite fluid cannot penetrate painted surfaces while gas penetrates everything but leave no residue and so does not treat. It just kills. So now to make sure that does not happen again i treat all the wooden parts before i paint or apply any finish.
Swan-Class Sloop by Stuglo - FINISHED - 1:48
This is my challenge for January. Your job looks great. I `plan to use some very dark greenheart wood that i have and will still stain them black.
