Posts posted by Jaekon Lee
Copper plate & bolting on the keel
Thank you friends as always. ;-)
Horse shoe and fish tail copper plates were attached on the both sides of the keel. Brass wire was used to fix them on the keel. After finishing bolting work, keel, frame and outside planking strakes were oiled with the mixture of linseed oil and turpentine oil.
Cheers,
Lee
- druxey, Timmo, Laurence_B and 18 others
- 21
Beautiful progress of your journey, Nils. Your workshop looks also very nice. :-)
Main deck planking
Planking of port side main deck has been finished at the breast center line. Though it is hard to see at this moment, treenails were simulated with syringe needle tip. I hope they will be more visible after oil finishing. : )
Windlass spindle, jeer bitt and several standards for them were attached and bolted. Small windlass will be added between the jeer bitt pins.
Cheers, Lee
- captainbob, wyz, Michel and 8 others
- 11
Great start Karl!!!! So excited to follow your build.
- Mirabell61, GLakie and Jeronimo
- 3
Thanks Nils, Antony, Coleman, Tadheus, Tom and Alex for your compliments and likes.
Tom, yes I mixed carbon black into the normal white glue to blacken it. To make uniform mixture, I made carbon black slurry with small amount of water and then mixed it to glue with small agitator. Drop of bonding strength was negligible.
Cheers
- Mike Y, Mirabell61 and wyz
- 3
- Mirabell61, tadheus, allanyed and 12 others
- 15
Very nice metal stove, Alex
It's a great pleasure to follow your building progress, Nils. Will you do planking the hull?
One more question is that you built hull with series of blukhead to support the hull shape (so it would be plank on bulkhead, 'POB') but you write "POF" in the title. Am I incorrect?
Lee
- Piet and Mirabell61
- 2
Draft rail and rough tree rail
Hi, Nils, Christian, David and Mike. Many thanks for your compliments.
Long break and little progress due to busy work and trip. Draft rails on the top timbers and gun ports were joined with glue. Nailing seems to be required to reinforce the joining strength. At the aft hull side, rough tree rails were placed between extended top timbers over the draft rail. Now I'm ready to install deck planking. ;D
Cheers, Lee
Hi, Nils. What a great start and progress!!!
Waterway, spirketting, plank sheer and scupper
Thank you Nils and Bob as always. Welcome Jim on my build log.
To Nils; I drilled smaller holes and chiseled them to square hole.
Next will be adding rough tree rail on the top timber ends. For the color contrast, I'll make it by ebony strake.
Cheers, Lee
Antony, thank you always. ^^*
Many thanks all friends for the warm words and likes. You make my heart beat increase. ^^*
Stern transom and timber structure
Due to the complex shape of stern structure and lack of information, many trials were needed to make this part. Though it is not clear with the drawing, side counter timber was formed as double layered with recess to receive the outer top side planking boards. Outer side counter timber was made by ebony to match the color of wale. Curved shape of transoms and tafferal were formed by steam bending method.
Cheers, Lee
- qwerty2008, yamsterman, druxey and 16 others
- 19
Thanks Rao, Nils and Bob for the kind words.
Bob, I will do half planking (in and out side of port side)
See you soon~~~
- captainbob and Mirabell61
- 2
Upper deck beam structure
Though it was tedious, with installing the last deck beam, called as deck transom, upper deck beam structure was finished. It is hardly seen but captain's room and bread room bulkhead was fitted below the deck beam structure. ^^*
Next work will be stern timber structure and port side deck planking.
Cheers, Lee
OMG, Lextin. You did magic. Wonderful!
- IgorSky and qwerty2008
- 2
Thank you all for the compliment and likes.
Christian, you looks so busy now a days.
David, I have slow hands rather than patience. ^^*
- Rao A.L.G., Mirabell61, druxey and 17 others
- 20
HMS Alert 1777 by Jaekon Lee - 1/64
Attaching rudder
Thank you Nils and Bob. ;-)
Four set of pintle and gudgeon braces were fixed on the rudder and stern post with brass nail. The nail heads were blackened after hammering. I think this work seems one of the hardest part to get neat result.
Cheers,
Lee
