GuntherMT
Everything posted by GuntherMT
  1. Great start Ken, look forward to seeing your work on the Constitution.
  2. Why not use a seizing and avoid the knots altogether? Also, instead CA glue to secure the knot or seizing, try using Matte Medium or Matte Glaze. Not quite as quick as CA, but works to perfection, and doesn't discolor your rope at all, and of course being a matte, leaves no shiny residue (or worse, white crystals if there is water present when CA is used). It also remains somewhat flexible, avoiding those 'kinks'.
  3. I was just curious, as the lathe has worked fine for me. I have an independent 4-jaw, self centering 4-jaw and a 3-jaw. I do use a follower rest for the masting work. Sorry for the derail on your log Maurys.
  4. Brian, but Gunther is fine too, it's an old nick-name. Your idea to thread the needle through is a good one. In my case I wasn't looking far enough ahead when I put the shrouds on the deadeyes, and thought I was being smart my making the shrouds so tight around the deadeyes. Later on I realized how the lanyards were supposed to run through the gaps, and was sort of kicking myself. I chose not to redo them because it would have required completely remaking the shrouds. I did everything on a jig, which you can see if you select my AVS build log link in my signature - I have an index in the first post which you can use to jump to the entry "Main mast standing rigging begins" which is where the jig is shown (or, just click there, since apparently copy/pasting the line in the log also copied the link).
  5. Why do you find it frustrating to use the lathe? I start with square stock in the lathe, make it all nice and round, then cut it down to the approximate size using cutting bits and then finish with sand paper. I made all the masting on my AVS this way with what I think are quite good results, so I'm curious what you find frustrating, and why a self centering 4 jaw defeats the purpose (given the purpose is to center the wood stock, which is what it does).
  6. Ignore the first drawing I posted when looking to secure the lanyard at the end. Look carefully at the 2nd illustration. The lanyard comes up behind the deadeye from below, going FIRST through the gap between the deadeye and the shroud, then loops around and underneath itself, and then wraps around the shroud above. There are no knots, the very end of the line is seized to the shroud with a small seize. The red arrow is pointing to the seizing. Notice that there are no knots at all. On my model I accomplished keeping this line fairly neat by the simple expedient of soaking everything thoroughly in 50/50 white glue/water mixture and just taking my time. Mine are not quite done correctly either, as I did not leave enough gap between the deadeye and shroud to make the proper feed through from below, so mine just wrap around and under instead of going through the gap like they should. It would be neater and more secure with the gap though.
  7. The first picture shows the deadeyes oriented correctly, but the other three have the lower deadeye 180 degrees off. I think they are pictures of opposite sides of the ship, and on the one side they are fixed and the other they aren't?
  8. I agree with the prior two posts, the lanyards are being run incorrectly, and that is probably where your twist is coming from. The lanyards should always run from outside face to outside face, never cross from front to back in the run from top to bottom, and when it comes up to the top on the last one, it should be behind the deadeye. This drawing is wrong on where to start (should be on the left, not the right), but shows that the lanyards always go from outside to outside, and inside to inside. If you flip this left to right it's correct: Here is another drawing showing it correctly, but without the 'step by step' arrows. You can see from the 'outboard view' (the one on the right), that the outside always goes to the outside corresponding hole in the deadeyes. You can also see how the final run comes up from below on the inside, and goes between the deadeye and the cross-over of the shroud. Be sure to click on the above drawing to see it full size for clarity.
  9. Does Proxxon make a self-centering 4-jaw chuck? That's what I got for my Sherline to make all of my masts. So glad I got it, well worth the investment to make the lathe into a mast making machine.
  10. Looking good! The effect on the cabin top is quite striking, it worked out very well (even with your 'mistake'). But what's up with that big round silver hatch next to the scuttle?
  11. I've never seen a double in-haul arrangement like that, but goodness knows that my knowledge of the subject is extremely limited. I just meant to offer a possible alternative for the purpose of those eye-bolts. The carriages for the guns on the Californian have that same pair of eye-bolts. Not sure when I will get back there, but I do plan on trying to get there sometime before the end of this year, and if I do, I'll try to remember to ask them about it. The Californian carriages also have the single center eye-bolt which shows obvious wear from use, whereas the doubles show no sign of wear on the paint at all. Here is a picture of a stowed gun on the Californian showing this arrangement, but I never saw the guns in firing position. I've increase the exposure and reduced the shadows on this so that the center in-haul eye-bolt is visible.
  12. Might also be something as simple as a point to attach a block/line for lashing the gun down when stowed.
  13. Spectacular job Ken, and congratulations on finishing. I would never believe this was anyone's "first build" if I hadn't followed you along from the beginning, you've done a great job, and I've learned a fair amount of interesting things from your log. You finished in record time too, almost half the time it took me for the much simpler AVS. Just amazing. Looking forward to seeing what you do with the Constitution!
  14. Beautiful. Just wish we could have larger pictures for your final update!
  15. Less than a week after finishing the AVS, yesterday I got up far too early, and spent the day at the annual model show put on in Phoenix by the local IPMS chapter. The Modelzona show is one of the largest annual shows, this year it had 550 entries, with my ship as the only non-plastic entry. I entered the AVS into the Surface Ships class that included some pretty amazing entries, including a 1/700 scale Japanese WW2 carrier in the middle of launching a strike, that had 313 little tiny crew figures servicing the planes and manning the guns etc., as well as 4 different entries by a guy who is a professional model-maker as his day job. At the end of the day, the AVS did quite well. I took first place in Surface Ships, and also Best Ship (all ship/submarine classes).
  16. Thanks all. Marcus, I use a Nikon D3300 with the kit 18-55mm lens. I shoot with a tripod using longish exposures so that I can adjust the aperture for depth of field. Happy to answer any questions you might have, but currently at your model show, so likely tomorrow before I can respond.
  17. Why not post it and share with everyone?
  18. Good stuff, really like the color scheme, and I'm looking forward to seeing your finished stove, so far it's very nice looking!
  19. My very simple system - Don't have children. This also prevents grand children as a side effect.
  20. Oh, I figured you guys had done the legwork on that, but it sure would have been a convenient location! Seems odd that their meeting prices are that much higher, the basic room costs are pretty much the same for non-special rates.
  21. Extremely cheap insurance - http://www.amazon.com/gp/product/B007SO12YO?psc=1&redirect=true&ref_=oh_aui_detailpage_o01_s00 I have a pair, and I don't wear them as much as I should. Try to remember to put them on when I'm going to be doing a lot of cutting that will obviously place my fingers/hands at risk, not so much for the very fine stuff where I'm not applying much pressure at all.
  22. Good looking boat Bob. Someone else just recently completed a build here, and I look forward to seeing how yours comes out!
