Everything posted by hornet
Making and using a draw plate
hornet replied to Don Case's topic in Modeling tools and Workshop Equipment
If you do a google image search for the Byrnes draw plate you can see the step down between hole sizes used. This drawplate is brilliant. As to cutting bamboo cleanly, I use a pair of cutters with very, very sharp, fine jaws. -
this is my ropewalk. Works a treat. https://modelshipworld.com/topic/14464-inexpensive-powered-rope-walker/?tab=comments#comment-449106
I have spent quite a lot of time haunting antique shops. I have collected a lot of old cotton and linen thread - people actually collect cotton reels - which is (in my opinion) often better quality that the tread produced now. I calculate diameter then make up appropriate diameter ropes using various numbers of threads on my home made rope walker. It is now one of my favourite model related pastimes.
Question on ropewalks
hornet replied to DispleasedOwl's topic in Rope Making/Ropewalks's Rope Materials and parts resources
Gday Mate, the rope walker in your pic is the one I built quite a while ago. I have made many great looking ropes with it since and it is now one of my favourite aspects of the hobby. In answer to your question, I didn’t put a motor at the other end of the Walker, but after I make a length of rope on the walker, I have found that attaching a cheap battery powered screwdriver on a low speed setting to the rear of the bolt on the trolly to which my rope strands are tied and giving it 50 - 100 rotations tightens up the rope even more. The rope still needs to be under pressure i.e the lead weight is still attached to the trolly. After removing the rope from the Walker I always run it backwards and forwards over a curved , hard surface to ‘harden’ it. The pic attached is my trolly with the screwdriver sitting on the bolt which goes through a bearing to a ring onto which I tie my threads - it is not set up to make any rope - just a demo pic so you can see what I mean. Hope this helps. Steve (hornet) -
Inexpensive powered rope walker
hornet replied to hornet's topic in Modeling tools and Workshop Equipment
Larry Leno cogs are marked z24. Diameter 25mm. Wheels (pulleys) on trolly are marked 1-05. 30mm diameter. -
I hold this size block in a fly tying vice, ream the hole out slightly with a very fine drill bit then use a doubled over very fine piece of copper wire taken from the core of a piece of electrical wire. BTW an upturned glass jar (with concave base) makes a good receptacle for a few drops of CA glue.
Straightening thin brass wire
hornet replied to vossy's topic in Metal Work, Soldering and Metal Fittings
Thin brass rod from 1mm and upward in diameter is available on EBay. I’ve found it to be useful for a variety of applications. Usually comes in a pack of 5 & lengths of 300mm -
Building the PVC tumbler was a bit of work Y.T. but it was a fun project and gave me a sense of achievement (not dissimilar to building a model). I have to agree with Mark though, the inflexible blades on a food mixer may be a little harsh for the job. You might like to consider making a whole new sandpaper ‘impeller’ to replace the blades on the spline completely or cut the blades off the attachment and replace with something more flexible. Post your endeavours as I would be interested to see the results.
I use the variable speed control from my Domanoff serving machine ( which I also use on my home made rope making machine) I experimented with different grit sandpaper in the tumbler and ended up deciding on 180 grit. I tumble them for a couple of minutes but because I use the variable speed control the number of revolutions in the tumbler depends (obviously) on the motor speed - not too fast, not too slow. I check the blocks as I go. Another pic of tumbler and some tumbled blocks below.
Just spent the day putting together a block tumbler using PVC pipe and end caps. Had to cut the end caps down a bit but it works well. The whole thing comes apart by taking one nylex nut from the end of the shaft. Bearings were obtained very cheaply on EBay. Added a small 12 volt motor and now I can tumble a handful of blocks very quickly. Cheers Steve.
Newbie with a few tool questions....
hornet replied to CPDDET's topic in Modeling tools and Workshop Equipment
I’d probably add a keel clamp of some sort to your list. Check out the thread above for one that I made cheaply and have used on 10 builds. -
I have recessed a set of these into a piece of timber. Covers most sizes of dowel I use. Push dowel into recess, centre marked, job done. https://www.ebay.com.au/itm/8Pcs-Dowel-Drill-Centre-Points-Pin-Wood-6mm-8mm-10mm-12mm-Dowel-Tenon-Center-Set-/351989788914
Lots of great ideas here.
Hull filler.
hornet replied to bluenose2's topic in Building, Framing, Planking and plating a ships hull and deck
I have found that if you are careful about hull shaping as you apply the first layer of planking, packing out/ trimming planks as you go, there is very little need for filler of any sort. If you are concerned about small gaps you can make a wood dust & PVC paste to fill them. I you are concerned about planks drying out and cracks appearing you can use bandage gauze and PVC - a bit like fibreglassing on the inside of the hull. -
Anyone using electric plank bender?
hornet replied to MESSIS's topic in Modeling tools and Workshop Equipment
The beauty of the aeropiccola bender is the spring loaded roller attachment. It allows you much more control of the bend. I normally use mine while the handle is clamped in a vice. This allows me both hands to work the plank. You could do the same with this bender. -
These are the bees knee. Not sold any more. I have had one for over 30 years. If you can find one second hand, snap it up! -
Favorite Paint
hornet replied to Koa4225's topic in Painting, finishing and weathering products and techniques
Admiralty Paints for me. -
I hate making tree-nails
hornet replied to barkeater's topic in Building, Framing, Planking and plating a ships hull and deck
1 mm is easy with Byrnes draw plate but I have found that for a 1:64 scale model, 0.5 mm is more to scale. When drawing bamboo down to this size it I have found it does get tedious and fiddly. -
1:64 Copper plating
hornet replied to Peter Y.'s topic in Building, Framing, Planking and plating a ships hull and deck
Whichever plates you choose, I probably wouldn’t overlap them. I think it would be very difficult to get a neat and tidy finish. I’ve done 3 models using your option 1 - I bulk ordered the plates from Cornwall Models and they were a bit too expensive to bin. While not completely satisfied with the size of the rivets/dimples on the plates, I was happy with the overall effect. If I was choosing again, I would probably go something with much smaller rivets but I still wouldn’t overlap. Below is my current build - HMAT Bounty with option 1 plates attached.- 14 replies
- pickle
- caldercraft
Google ‘squadron precision glue applicator’ It is specifically designed for applying CA glue. I use it when attaching copper plates. Works very well.
I also only use diluted wood glue on rigging. CA glue fumes are also very toxic. Cause flu like symptoms. I only use CA when fixing copper plates. I put puddle on the bottom of an upturned glass jar and use a glue applicator (like a metal hook that holds a drop of CA) purchased from a hobby shop. I only use CA while working outside on a verandah in the open air.
