slow2cool
Everything posted by slow2cool
  1. WOW talk about greatness in detail That's juat about as great as one can be !!!!!!! Joe
  2. Hi Gerhard Your build is outstanding. It looks like you are using some kind of paper templet for your soldering. Is it paper??? If so how do you keep it from going up in flames when you solder????? Joe
  3. You are one amazing man. How you keep coming up with something from nothing I will never know. Great Work Joe
  4. WOW Dave After looking over your build log, I have to take my hat off to you. To begin with this being your first build and the job you are doing is just amazing. Next thing is, it is one thing to do this kind of stuff and have power tools to do the job. It looks like you are doing this with hand tools sandpaper and determination. So to do all this and obtain the results you have, makes you a true and skilled shipwright. Joe
  5. Dave Great Job For your first build, you are doing super. I am going to look up your build log and follow. Joe
  6. Is this what you are talking about http://www.micromark.com/10-piece-planking-clamp-set,6454.html Joe
  7. Hi I just found your build log. You are doing outstanding work I really like what you did with the haul. It looks to me, that you painted the haul then sanded. I am guessing that this brings out the grain in the wood. Then you stained it with oil base stain. I see you have a airbrush in one of your pics. What was in the airbrush??? IF I have missed something in your finishing the haul, please let me know. I would very much like to try your method. Thanks Joe
  8. Hi Yang I understand If you run into problems, send me a PM Joe
  9. it just keeps getting better and better and better great job Joe
  10. I just made my first ship with rigging and sails. The box shows them some what furled, but I wanted to to try the full blown efect. The way it turned out it does hide some of the rigging when looking from the front, when you look from the sides you can see the rigging and more details. I find that a ship with full blown sails very majestic. If losing detail is you concern you can always have the sails just starting to furl. Or have the top sails full and the bottom sails starting to furl. One more thing to think about is at the scale you are woking with you should have more room to work with sails. Mine was 1:90 scale, so things were a little tight. On the other hand, if this is your first ship, you may want to take things a little easy. From what I understand you have a great kit. Now if it were me, I would go full tilt, because the Victory is a very majestic ship. Hope you do a build log, I would like to follow your progress. If you do, send me a PM so I can follow your log. Joe
  11. Ken I would like to know about how to harden rope. That's a new one on me. Joe
  12. Dave I have been following Ian's build. His planking job is outstanding, for a first time build, plus the type of ship. Here is his link. http://modelshipworld.com/index.php/topic/11130-hms-victory-by-seventynet-caldercraft-scale-1-72/ If you look what he has done with the 1st planking, he use some drop planks and steelers, but for 1st layer is like wow. He does use spilling for his 2nd planking on one side, but the wood came out looking like 2 different shades. For the other side he came up with a way of cutting the planks to scale lenght then edge bending. I will try this method on my next ship. I find that I am learning as I go. If your ship has 2 layers of planks the first is were you get the feel of easy part and problem spots. Joe
  13. 1 pic File small flat spot 2 pic use T pin to make starter hole for drill then drill hole I use wire from twist ties last pics are what you want Now follow steps for drilling hole in other piece Cut wire to size The only thing you don't want to do is drill to deep. If you do it's not that big a deal Hope this helps Need more help let me know Joe
  14. Hi Steve What I do is file a very small flat spot to the yard, and mast. Then drill a small hole in yard and mast, just big enough for a very thin wire. Glue wire mast and yard, then rig them. If need I can send pics. Joe
  15. Ian I found your build log about a week ago. I was hooked right from the planking job you did. I have learned a boat load from your log. I look forward to see just what you come up with next. Seems like it keeps getting better and better. I must say the planking job is outstanding. For your first build is even more then outstanding. As soon as I get the time I going to go back and hit the like button. I think it’s the least I can do for such a great build log as yours. I just finished my first ship with sails. I find the rigging a real joy to do. I think you will feel the same. Joe
  16. Ray I also have never done any weathering. Like Pete said hope you post how you do it and results Joe
  17. I can see were this would come in handy Where did you find????? Joe
  18. I like the pattern of the planking. Wish I could give you advise, but I know less then you do in this area. The one thing I would like to know is, should #1 line of planks start more to the left, so the very short planks at the right will be a little longer. Don't know if I explained that right. Joe
  19. Mike the link keeps taking me back to the same page i was on Joe
  20. Rainbow I have been looking over a build log that you might want to see. He does a great job planking. http://modelshipworld.com/index.php/topic/11130-hms-victory-by-seventynet-caldercraft-scale-1-72/ Also as to what you were talking about sanding, I found a page about using scrapers. I have never tried this, but I may in the future. http://modelshipworld.com/index.php/topic/10704-do-you-use-a-scraper-in-shaping-instead-of-sanding/page-1#entry323292 Joe
  21. Hi Rainbow If you are talking about sanding the planks on the hull, then I think hand sanding is the best. I was talking about sanding the planks before they are on the hull. I use my sander for so many things. Also the the size of the dish helps. Mine is 10 inch so I have 5 inch of sanding area. I use mine for making the masts and yards cone shape. It is really fast. I spin the yard with left hand, and a little pressure with the right You can also see how small I can make things with zero clearence. Joe
  22. This is what I did with mine. http://modelshipworld.com/index.php/topic/12989-back-akwards-proper-attachment-of-buntlines/ As you can tell from the link, I did make a mistake. Now I know what not to do. LOL Joe
