Everything posted by Keith_W
Brian, the other two boats I have at home are not copper plated. The potential size of Chris Watton's Victory means that it will not be displayed next to Royal William, so I don't need to contrast the two ships I am more concerned about historic accuracy if I do embark on copper plating. BTW, did you ever find a source for gunport hinges? I also found this on Amati's website. Pity it doesn't tell you what the dimensions are: http://www.amatimodel.com/en/accessories/minuterie-e-accessori/hinges-without-pins I am also thinking of putting these on the inside of the gunport lids: http://www.amatimodel.com/en/accessories/minuterie-e-accessori/lions-head 6mm in length, each. The bottom gunports are 14mm in height, the mid-deck gunports are 13mm, and the smallest gunports with a lid are 10mm. It should be OK, but again - not sure about historic accuracy.
Can I have some thoughts as to whether I should copper plate this ship? She was broken up in 1813, and copper plating was introduced in the British Navy around 1750. If I don't copper plate, I will paint the hull below the waterline white. (edit) I would probably use these: http://www.amatimodel.com/en/accessories/minuterie-e-accessori/photoetched-copper-plates
Zheng He's Massive Ship from Ming Dynasty
Keith_W replied to mkmossop's topic in Wood ship model kits
I have my doubts as to the historical accuracy of that ship, to be honest. There is an upper limit in size for wooden ships - any larger than a certain size, and they lose structural integrity. I suspect that there is a good dose of historic embellishment going on there. (edit) having said that, a ship that hugs coastal waters where the sea is relatively calm does not have to be as rigid as a ship that has to sail blue water. -
Hi Jeff, sorry for not replying earlier. Somehow your email did end up in my spam folder! I have replied your email. Thanks for your patience. Max, I would like to build a Friedrich Wilhelm as well, but I suspect my next ship will be Chris Watton's Victory. I am always thinking of my next ship! Richard, thanks for dropping in. Yes, hopefully i'll do a better job with the second planking than I did with the first. In any case, I will probably start the second planking (below the waterline) very soon. I may as well get this done while there are no fragile elements that project out the top.
Planking down to the keel is now completed. I have also cut out the second row of gunports. Here she is, all sanded down and ready to go ... while I ponder what to do next. My ambition when I started out was to use no filler. Sad to say, I had to resort to the dreadful stuff. At least I didn't have to use much of it! Yes, I know it will be hidden by the second planking, but it would have given me a lot of satisfaction if I did not have to use any of it.
I just love your small details. Could you share how you made those buckets please?
- 43 replies
- new bedford whaleboat
- model shipways
I built the HMS Bounty from Artesania Latina. I believe that OcCre sell the same kit. The unique feature of this kit is that the side is open, allowing you to see the inner decks and offers scope for more detailing if you so wish. The kit is single plank on frame, meaning that your planking mistakes are there for all to see if you are not careful! Fortunately the wood supplied is good quality. The frames are made from plywood, which means they need to be stained since they will be on full display. The downside of this kit is that the rigging instructions are poor and confusing. You are supplied a full size plan of the ship, but it is not clear where the lines go nor where they start. I purchased the Anatomy of the Ship book to help guide me and found that some of the rigging instructions were incorrect. Nevertheless, I just ran the lines where I wanted to and it produced an acceptable looking ship. This was early in my modelling career where accuracy was not as important as it is now!
That's great, keep the updates coming!
- 593 replies
- royal william
- euromodels
You will definitely lose tactile feedback by using surgical gloves. I am a little confused as to why your skin is splitting. Do you have a skin condition? Perhaps you should see a doctor?
I'll be watching this one too. Can I ask - what are the daggerboards for?
- 220 replies
- finished
- volvo open 70
Hi Richard, don't worry about the cherry frames being loose. The only structural role they have is to hold the planks together. They are too weak to hold the shape of the boat. As you will find from reading several build logs, the boat seems to get wider after she is removed from the plug. The most important structural element, apart from the planks, are the thwarts. You will notice your boat will feel much more solid after you install these ... much later in your build!
I suggest you view this thread and watch the video. It is VERY helpful. http://modelshipworld.com/index.php/topic/5471-new-video-on-basic-soldering-for-scale-models/
