Everything posted by Canute
Great way to recharge the batteries, Jay.
- 572 replies
- constitution
- frigate
Grant, I'll join you in the front row. Looking forward to another build by Clare.
- 51 replies
- wasen
- thermal studio
1/10-scale Japanese Fishing Boat kit from Thermal Studios
Canute replied to catopower's topic in Wood ship model kits
Very interesting boat, Clare. Will be following your build. The masking tape looks like the same tape Tamiya sells. Excellent masking tape!. -
How will you keep it level? Guess you could pin the wheels and put one under the trunnion point.
- 572 replies
- constitution
- frigate
Mick, the first few and the ones showing the overall acrylic supports for the cant frames on top of your build board. Wasn't visualizing the supports until I looked at the overall ones. Takes a while to get stuff drilled into this Irish-Sicilian skull.
- 504 replies
- washington
- galley
Click! Light bulb on now. One picture (or in this case a series) does the trick. Thanks, Mick!
- 504 replies
- washington
- galley
That boat's a beauty, Sal. As are the sweeps and oars.
- 659 replies
- syren
- model shipways
Sharp blades and a cutting mat work well. But, balsa is a very soft wood; really only useful as filler for a hull, between the bulkheads. Trying to shape items, like deck furniture, is difficult because the wood is so soft. The edges don't hold up if much pressure is applied, so fine detail is hard to achieve. You may want to try some basswood. It's still soft, but it doesn't have the issues of balsa.
Very work on the gun carriages, Grant. Worth a bookmark!
- 456 replies
- finished
- bomb ketch
You could include sounds via sound decoders. Several roads did have steamboat whistles on their locos. But sound decoders, speakers and a good enclosure aren't cheap. I just put sound in an Alco B unit and that was over $100. Smoke, on the other hand, won't look too good. The wispy smoke these generators put out won't look even close.
For those of you interested in bigger scales, check out Flagship Models, a purveyor of 1/192 scale ships and some bigger scales. All resin and photo-etch brass, primarily American Civil War era, but he does has an 1890s US torpedo boat aka destroyer. His address: http://www.flagshipmodels.com
Check out the folks at Kombrig, a Russian maker of resin ships in 1/350 and 1/700. They have a number of pre-dreadnoughts in their catalog. Here's their site: http://www.steelnavy.com/CombrigPage.htm
Well done, Greg. Didn't realize the scale of the barky was that small. It's about the size of a WW II Destroyer. That's for sharing your build.
OC, nice and slow with these thin wood parts. They're nice looking so be very precise in your placement. You'll only get one good shot. Patience is key.
All around excellent work, Mobbsie. Well done!
- 255 replies
- granado
- bomb ketch
Cutter Cheerful 1806 by rafine - FINISHED
Canute replied to rafine's topic in - Build logs for subjects built 1801 - 1850
Beautifully done, Bob.- 525 replies
- cheerful
- Syren Ship Model Company
Power Precision Screwdriver
Canute replied to Julie Mo's topic in Modeling tools and Workshop Equipment
I'll use MM for some stuff that only they may carry. A lot of stuff may be cheaper from Amazon or any number of other stores, both online and the brick and mortar places. I probably have 9-12 shops bookmarked to see if they carry some widget I need/want. Pays to shop around. -
Echo by Maury S - FINISHED - Cross-Section
Canute replied to Maury S's topic in - Build logs for subjects built 1751 - 1800
Maury, the breastwork looks good. One drilling technique I've used on basswood parts is to increment the drill sizes from a fairly undersized drill to almost the correct size. Then you should be close enough to use your files and reamers.- 324 replies
Better late than never, Jack. Pulling up a stool to watch all this. The sparse instructions have to be disheartening, but superior skill and cunning will overcome. And an adult beverage for when you run out of ideas. I like it!
- 203 replies
- artesania latina
- marie jeanne
