Everything posted by Canute
Jonny, that's 'all"? Your build is coming along nicely. I hope to get back to mine soon.
- 188 replies
- Sherbourne
- Caldercraft
S.S Atlantus (sp) off the west side of Cape May, NJ off Sunset Beach. It 's a concrete ship. Can't copy photos, but you can see pix on Google Earth, search Sunset Beach, NJ.
I would put the filler on the bare wood, sand it to your degree of smooth, recheck the filler, then prime the surface. A light sanding with fine grit paper or very fine steel wool and you should be good for your paint. Your primer color should be white or light gray if you plan on painting yellows. These colors are more translucent and you'd need more coats of paint to get the color right. Not good with some acrylics, especially if you're brush painting.
- 440 replies
- niagara
- model shipways
Jonny, dunk the brass in vinegar. It's a weak acid and will remove the oils. The blackening agent may need diluting to work properly. Read the bottle. Good luck.
- 188 replies
- Sherbourne
- Caldercraft
Brig Eagle by robnbill - 1:48
Canute replied to robnbill's topic in - Build logs for subjects built 1801 - 1850
Great details, Bill. The cartridge bags look great. -
Congrats to the Admiral and you. I think you'll be happier with brass barrels, though you'll need to blacken them somehow. The chemical way lets the details show better than paint, but the chemicals require a couple of steps. There are a couple of logs explaining the process here.
- 188 replies
- Sherbourne
- Caldercraft
The resin plug issues are pretty typical for most resin cast kits. The molds are soft and rubbery, so the dimensions can vary by small fractions. Every rolling stock kit I've ever worked on had a lot of cleanup, truing and squaring. Check against accurate plans, said the novice to the masters. Request permission to watch one of the masters.
Mobbsie, it's looking great! Very nice joinery and finish. And glad to see how you've organized your work documents in ring binders; I've done that for years and most modelers around here think I'm OCD or just anal.
- 255 replies
- granado
- bomb ketch
Matt, I'm sure between your design ideas and the Nuts Bros skills, those carronades will be primo! Keep it up.
Good call by that parrot... oops, cockatoo.The shaping and finishing of the cap rail look great! Looks like that aft pivot gun/caronnade will have a good field of fire. My compliments to the Nutz crew.
comparison of masking tapes
Canute replied to vaddoc's topic in Painting, finishing and weathering products and techniques
You may want to lay your making tapes on a clean metal or glass surface and cut it with your sharp knife and a metal straight edge. The flat surface with take some of the tackiness off your tape and the fresh cut tape edge is way crisper than the factory cut edge. And like grsjax said, seal the edge. -
Brian, good idea firing up the mill. The cannons look very good, as does the sloop.
- 831 replies
- Armed Virginia Sloop
- Model Shipways
Matt, love the patterning and choice of wood colors. Good work. My compliments to Woodie and his crew(s). Dare you Splice the Mainbrace?
Yowzah! Beautiful detailing there! Well done.
- 308 replies
- finished
- model shipways
Hope you didn't feed Tiny one of you "manly" cupcakes. Chocolate is bad for pups. Why not stain your wales black? Stain can be a good option vice playing with ebony wood. What's wrong with baking? I brew a little beer and bake bread occasionally.
- 188 replies
- Sherbourne
- Caldercraft
Ken, pretty much standard issue back then. We USAF aircrews had several other less "PC" names for them, too. I salute all veterans who served any time and any where. And to all my Viet Nam brothers and sisters, Welcome Home!
- 440 replies
- niagara
- model shipways
Echo by jml1083 - 1:48 - Cross-Section
Canute replied to jml1083's topic in - Build logs for subjects built 1751 - 1800
Jim, Thanks for the mini-practicum.So many things to learn here. -
Grant, your little tutorial is excellent. The dimly lit light bulb in my brain just got lit up like a fireworks display. Thanks for that explanation for doing the beams.
- 456 replies
- finished
- bomb ketch
Very nice job on both the Bomb Vessel and the Pirate Pig. Hope the Pig floated upright!
- 255 replies
- granado
- bomb ketch
Jonny, I'll pull up a seat and follow along. I like these cutters.
- 188 replies
- Sherbourne
- Caldercraft
