ccoyle
Moderators
Everything posted by ccoyle
  1. Great little model there! Being originally from Northern California (the REAL Northern California 😉 ), I frequently saw drift boats in action. Back-trolling from a drift boat is a particularly effective way to fish for salmon and steelhead. I only ever fished from shore and could only look on with a bit of envy. Cheers!
  2. So of course the Big Question is, How many times to did you inadvertently grind from first gear into reverse? I won't say how many times I did. 🙄
  3. Well, this puts you in a special minority. Personally, I think that era is fascinating, too, but most modelers seem to think that ships of that time period tend towards the "ugly" side of the aesthetics spectrum. I disagree. But then, I also think that the rapidly transitioning Golden Age of Aviation is more interesting as a source of modeling subjects than what came before or after. I look forward to seeing some of your projects!
  4. Steingraeber kit from the 1970s, 1/90 scale. See link for pics of one listed at auction. One sold on eBay in 2012 for $89.99. https://nazya.com/ebay/single/4946477/orig_desc.html
  5. I once owned a '64 Ford Falcon wagon that was affectionately (?) known as "The Bondo Special."
  6. I work with a guy from Finland, which I dare say isn't all that common on this side of the pond.
  7. Hi, Adrie. For perspective, the blue squares on the cutting mat are 5 cm on a side. Not trying to be unduly modest, but a lot of the "smashing-ness" of the model is really due to the excellent design of the kit and not so much to any great skill on my part. Thanks for commenting!
  8. Hull planking completed and sanded. This is as far as I will get before traveling over Christmas break. Construction will resume in the new year.
  9. Just remember, Jeff, that there are two components of any completion ratio data set: those who don't finish, but also those who do. We do occasionally see some of the latter, so keep at it, and hopefully we'll see you join that select group. Cheers!
  10. I don't know, but try searching (either here or on the Internet in general) for build logs of Shipyard kits. You might find how they plan for that task. Good luck!
  11. Yup, you have a challenging kit there! Fortunately, there are a lot of Victory build logs here, and you should be able to find what you need. Cheers!
  12. Scott, If a sail was not bent (i.e. attached) to its yard, any running rigging that attached directly to the sail would be down as well.
  13. Hmm. This one is a little different than what we usually see around here. I have a few preliminary thoughts. 1. I don't believe that this is a mass-produced decorative model, as those tend to be purported reproductions of famous ships, and K. D. Echoes is definitely not a famous ship. 2. On the other hand, someone could have purchased just such a model and then endeavored to personalize it by adding the name. 3. The rig on the model is odd, because the topsails have gaffs. This might have been seen on early 19th-century schooners, but almost certainly not on one in 1930. 4. So my "educated" (for whatever that's worth) guess is that this is a scratch-built model based on someone's idea of what a schooner looks like (as opposed to built from plans or a kit), and that the name and date have some sort of personal significance to the builder; e.g. "K.D." could be someone they knew, and 1930 might be the year the model was built. The true story is probably lost to history. Thanks for sharing!
  14. At a mid-level price point, I have gotten good results with Simmons white sable brushes.
  15. I have found quilting thread to be a good choice. It's pretty heavy-duty and has a lot less fuzz than regular sewing thread.
  16. Slow progress ... a couple of planks here, a couple of planks there as time and interest allow. Twelve strakes on, six more to go. Did a little preliminary sanding and temporarily fitted the display cradle together, just for this shot.
  17. I'm pretty sure they're interested in ships of any nation, and your smack project sounds like just the type of vessel that fits the bill. The only restriction is that grants are reserved for NRG members.
  18. Just reading that makes me feel a bit woozy -- and I'm not even building the model!
  19. Welcome! Several times on Facebook I have seen a video of some chocolatiers making a ship out of chocolate, so gingerbread does not strike me as all that far-fetched. Have fun thinking about what model to build!
  20. Hi, Scott! Not to confuse the issue, but have you considered any of the other Bounty kits out there, e.g. Amati, Billing Boats, or Caldercraft? I haven't built any of them, so I can't offer an opinion one way or the other.
