ccoyle
Moderators
Everything posted by ccoyle
  1. I'm not an expert by any stretch on smallcraft rigs, but a cursory internet search of the terms 'cat-ketch' and 'cat-yawl' turns up a lot of images with rigs that are essentially identical, so maybe we're not the only ones who are confused.
  2. It may take some digging, but it is generally possible to find out who designed a particular kit, even if that info is not available at the publisher's website.
  3. I love the lines on this little boat. Seeing one being built here always makes me wish I had a real one.
  4. The observer's position is complete. These are the last views anyone will see before it gets zipped up. After this, anyone wanting to get a good closeup look will need to use an endoscope. 😑
  5. How can those of us who aren't piping engineers know for certain that all that piping wasn't just added to the ship in random patterns? 🤔😉
  6. Welcome aboard, Max!
  7. Midwest kits are now manufactured by Model Expo. They may provide you with a copy of the instructions if you make an inquiry with them.
  8. Welcome aboard, Brent!
  9. I call this next one the "last time you'll ever have a clear view of this cockpit" shot. And here's the cockpit section all closed up and mated to the forward fuselage. The butt joint did not turn out as nicely this time. A simple fuselage slice is next, followed by construction of the observer's position. Cheers!
  10. When this kit first arrived, I noticed that it is designed to use butt joints. I really dislike butt joints. Because it uses butt joints, no joiner strips are provided -- not even the sort that are typically used to close rings. Hmph. Work proceeded on the first fuselage section. Regardless of what the kit designer intended, I simply made myself a joiner strip to close up the ring, which, as you can see in this first photo, is not entirely ring-shaped. It's a ring where it joins the cowl, but then flares to a flat bottom along the rest of the fuselage. The forward-most bulkhead is a simple circle, but the aft bulkhead has a cutout where cockpit elements will be located. I stiffened the entire flimsy-looking bulkhead with thin CA. I also painted the interior a sort-of canvas-colored tan, because I don't know how much of it will be visible once the fuselage and cockpit are assembled. (BTW, that's just an old, dried glue blob in the lower left corner.) Both bulkheads required some sanding to get them to slip easily into the ring. Here's the completed fuselage section, now mated to the cowl assembly. The cowl has numerous blisters, which I will add later to avoid smooshing them while working on the fuselage. That first butt joint turned out well. I'll be very happy if the rest turn out as nice. Moving to the next fuselage section, construction of the forward cockpit begins, so there will be a lot more elements. Cheers!
  11. Congratulations! Your finished Endeavour turned out wonderfully!
  12. First two cowl rings and radiator shutters completed. Now I'm busy trying to make sense of the assembly instructions and diagrams, which leave a substantial portion of the build process to the imagination.
  13. People sometimes ask why I don't build any jets in card. Simple answer: I only build in 1/33 scale, and at that scale jets are simply too large to fit on my available shelving!
  14. First Cuts Construction begins with the forward fuselage. One unusual feature of the Salmson was its powerplant -- a liquid-cooled, 9-cylinder Salmson 9Z radial producing 231 hp. The radiator layout featured shutters that looked rather like fan blades. You can easily see them in this photo: from Wikimedia Commons And here are the shutters as seen in the construction diagram: The shutters are provided as a flat, printed part depicting the shutters closed, but the instructions say that experienced models may attempt to display them in the open position. Challenge accepted: That job took awhile, so that's all I got done this evening.
  15. Guilty! I needed to pump up our stats -- at least, that's the excuse I'm going to use! 😳
