russ
Members-
Everything posted by russ
Coloring Basswood
russ replied to JPett's topic in Painting, finishing and weathering products and techniques
I use Minwax prestain conditioner and then Minwax oil based stains. I have been able to get a nice even cherry color using this combination on basswood. You apply the stain within a few minutes of the conditioner and then allow it to soak in. The longer you leave it on before you wipe it off, the darker the color. Russ -
Andy: Splicing was a constant routine on board any ship, so it might look right at home. Russ
- 246 replies
- revell
- constitution
Solder brass rod for deadeye
russ replied to cog's topic in Metal Work, Soldering and Metal Fittings
Thanks. As I have never had any problems with Brass Black from Bluejacket Shipcrafters, that is what I will continue to use. Russ -
I am not familar with Carrs in modeling work. However, if it works, that is a good thing. I am not certain of the availability and I can only relate what I have learned from my experience with soldering. I hope that it is helpful to someone. Russ -
I agree that some soldered joints are not under stress, however, soft soldered joints will not take chemcial toning while silver soldered joints will. Of course, you can always paint the pieces, but that will often obscure details. As for flux, I use a prefluxed soldering paste. In the case of deadeye strops and chainplates, they will be under some sort of stress at some point and that is why silver soldering is really the best option for those joints. I have had soft soldered joints in deadeye straps come loose and it leaves the shrouds limp. If I had silver soldered those joints, it would not have happened. This same reasoning applies to eye bolts or rings used in tackles, or eyes on mastbands. Russ -
That is a nice looking assembly. I agree with John. It looks like it might actually work. Russ
- 103 replies
- picket boat
- model shipways
Brian: I have silver soldered joints fairly close to one another on several occasions and I have always used the higher temp solder and the torch. Never had any problems. It may be that there would be problems in certain insances, but I have not found them yet. When I solder 4 eyes onto a mastband, it seems to work just fione using one temp of solder. Russ -
Carl: The shape of the piece does not matter when it comes to filing. Straight or curved, angled etc really will not make a difference. You just need to have an assortment of 4 inch jeweler's files that you can use on the various parts. Russ -
When heating brass strips, just heat until it glows red. Then take the heat away and let it cool. No water. Russ
- 773 replies
- san francisco ii
- artesania latina
Robbyn: You have made a fairly good job of the rudder hinges. The materials they give are not all that great, but you have solved it well enough. It will look good in the end. Nice work. Russ
- 773 replies
- san francisco ii
- artesania latina
I honestly do not know and I am not in a position for a few days where I can look it up. The idea sounds good, but I am not certain. Russ
- 246 replies
- revell
- constitution
I always file my soldered joints afterwards. If the joint is done properly, the filing will clean them up with no problems. After that, they can be chemically toned and they looks just fine. Russ -
Carl: Nice job on the chainplates. That is really very good work. Russ -
The block and the rigging line are beautiful. Russ
- 2,214 replies
Second Layer Planking Guide
russ replied to caveman's topic in Building, Framing, Planking and plating a ships hull and deck
Baris: I agree with Chuck about the proper way to plank. I would definitely recommend those planking guides that Chuck linked to. I also realize that you are probably wanting to work within the confines of the kit. Those kit supplied planking strips will work, you will just have to cut them to fit and let them lay on the first layer as naturally as possible. It is not how the boat was actually planked, but it will get the job done and look nice if done with care. You can use pins to hold your second layer planks in place, but pin into the first layer and let the cap of the pin hold down the second layer plank. That way there will be no unsightly holes in the finished planking. As for glue, I like to use yellow carpenter's glue, but any good water based glue will work fine. Just keep a damp rag handy to wipe off squeeze out etc. This is much easier than using super glues, but it will take a bit longer to dry. Russ
