russ
Members-
Everything posted by russ
Aldo: Thanks. This restoration will always be one of my favorite projects. It was a good subject, a great client, and the finished model has gotten more than a few ooos and aahhs. Russ
- 43 replies
- restoration
- finished
Michael: Thanks for your kind words. I appreciate it. Russ
- 43 replies
- restoration
- finished
Anja: Thank you. It was an enjoyable project. The term "white winged queen" was very likely coined by a local journalist, Walter Fountain. He wrote many newspaper stories about the annual schooner races. Russ
- 43 replies
- restoration
- finished
Bob: In all of the photos I have seen of Biloxi schooners, they had the boom on the forestaysail as I have shown. The jib does not. Thanks for the kind words. Russ
- 43 replies
- restoration
- finished
I agree with Gary. I do not think there is a "right" color for blocks. I have seen them lighter and darker. In working boats, I have seen them painted. I think for 18th century blocks it would be some shade of "natural". Russ
- 43 replies
- restoration
- finished
New gaffs and booms were made and the sails were sewn out of japara cotton. Rigging was created from Egyptian cotton. I can heartily recommend Egyptian cotton for rigging. It is some of the best stuff I have used. Here are some photographs of the completed model. More to come. Russ
- 43 replies
- restoration
- finished
There were several photos of detail in the original build log that I no longer have. So, descriptions will have to suffice for the most part. After fitting the deadeyes and chainplates, I had to work on the masts. The original mainmast was one long stick, but it had been broken about two thirds the way up, so it made sense to cut the mast off and then add a proper masthead. Here you can see what I did. The white area is a separate piece of wood shaped and fitted to the lower mast. A dowel was used to connect the two pieces, using the dowel as a spline. This same procedure was done on both mastheads. Russ
- 43 replies
- restoration
- finished
The deck framing looks very good. So long as the paper you use is not too thick, the caulking lines should be okay. Russ
- 332 replies
- Triton
- cross-section
The tub would be for water to use when sponging out the gun. That battlestation model is generic in nature. I am not sure what time period or country it represents. Russ
- 601 replies
- constitution
- revell
- 601 replies
- constitution
- revell
Wow. That sounds like a bit of work. The results are good. Russ
- 601 replies
- constitution
- revell
Apprentice: I am not sure what time period or nationality you are talking about, but I have always read that planks were spiled and tapered, at least in British and American shipyards. For framing they would look for timbers that had naturally curved grain, but in planks, that would be very difficult to find in most cases. It is far more likely that they would use what they had an spile the mating edge and taper the other edge from a wider plank. If it was just a minor bit of edge bending, they would do it, especially on the ceiling plank, but for any significant curve, that almost certainly had to come out of a wider plank. Certainly in the mid to late 19th century in American merchant shipyards, they were spiling and tapering. There is plenty of evidence for that and the same is known of British merchant shipyards of the period. Maybe you are referring to an earlier period or larger ships? Russ
Those barrels look pretty good. Did you add the staves on the outside of the barrel? The bands look very good. Russ
- 601 replies
- constitution
- revell
Mark: I would go for the hand tool solution. Make up a jig to hold the piece and plane down the corners, one at a time, to get the shape you want. So long as the plane is headed away from your body, you should be okay. Russ
A question on drop planks
russ replied to apprentice's topic in Building, Framing, Planking and plating a ships hull and deck
In that photo, they used four strakes between the drop planks and the butt joints as I recall, so that would fit. I think they had to work within the rules as best they could. So long as they did not violate the rules, they were okay. Russ
