russ
Members-
Everything posted by russ
What you show for the breeching is probably not what it used back in its early career. That is what they have now, but I would not think that sort of arrangement was used in the 1812 era. In that period it was more likely to see a ringbolt on each side of the gunport to take the breeching. Then further out from the gunport there would be another ringbolt on each side to take the side tackles. The rider bitt loks very good. Nice work there. Russ
- 601 replies
- constitution
- revell
Hooks
russ replied to popeye2sea's topic in Discussion for a Ship's Deck Furniture, Guns, boats and other Fittings
I make mine from brass wire. That said, I do not put any strain on them. There is never enough weight being applied to cause strain that would bend the hooks. Russ -
Dave: I would think that the flying backstay would be black and the tackle would be tan. That is how you would see shifting backstays. Since the standing part of the backstay is mostly structural, it would be black along with the shrouds and stays. Russ
- 95 replies
- bluenose
- model shipways
Floyd: I think you meant "rot" instead of "rats". Tar was a preservative for the rope. It needed protection from the elements. Dave, the rigging looks very good. One thing I would ask is was the standing rigging on this vessel wire or rope? Russ
- 95 replies
- bluenose
- model shipways
The gun carriages look very good as does your camboose. Very nice work. The ringbolts in the side for the tackles will not be seen so you can work around them if you like. If you choose to rig the breechings, you will need two ringbolts per gun, one on either side of each gun. Russ
- 601 replies
- constitution
- revell
The Model Shipways Mayflower would be a good choice. This kit was designed by Chuck Passaro. I am sure it has really good instructions and plans. Plus, Chuck is here on MSW and can help with any questions you might have in the build. I am sure the AVS kit is also good, but with such resources, I would go for the Mayflower. Russ
The guns look good. That was a good call using the smaller blocks. The 6 inch blocks look great. Russ
- 110 replies
- armed virginia sloop
- model shipways
I agree that the rigging looks great. That it took longer than you thought it would is not as important though. What really matters is that you have made a great achievement. Russ
Brass Pedestals Installation
russ replied to BareHook's topic in Metal Work, Soldering and Metal Fittings
Nick: You stll have to screw them into the keel because the screw has to go up through the baseboard to hold the pedestals in place. The only way for the screws to do their job to hold the pedestals is to screw into the keel. Otherwise, there is no point in using the pedestals. Russ -
I think the finish on the hull looks very good. It has an antique look to it. Very pleasing. I think scratching the pintles and gudgeons is a good idea. Make some that fit your hull, not what they thought would fit. I think you can pad out the sternpost with a thin strip of wood to make up that thickness right under the gudgeon. If it is the same width as the gudgeon and the same color as the sternpost, no one will notice unless you point it out. Russ
The rake of the masts will tell you a lot about the postion of the channels. Most times the forward end of the channels will be at or slightly abaft the mast. The channels will have slots cut into the outer edge into which the neck of the deadeye strops will fit. Then a separate cap will be fastened onto the outer edge of the channels to hold the strops and chainplates in place. Russ
Sam: Those chainplates are not appropriate for an early 19th century navy schooner. They would have had the metal strop on the deadeye, along with the U shaped links, and a backing link. What they have in your kit is really closer to what you would see on a late 19th or early 20th century working schooner. The holes in the plate are for fastening into the ship's hull. If you look at the illustration that Tom posted, that is how your chainplates should appear. And yes, they should follow the angle of the shroud that they support. So, the chainplates are at different angles along the hull. Russ
colour of waterway
russ replied to hamilton's topic in Building, Framing, Planking and plating a ships hull and deck
Hamilton: The waterway is part of the bulwarks so it should be painted. Russ -
Blackie: I do not think there will be any hard and fast rules for mast rakes on Baltimore clippers. I think each captain probably had a favorite rake for each mast that had worked well for him and that is what he used. You can use what you found on the Pride of Baltimore if that looks good to you. Russ
Henry: I am familar with the flexible rope rammer. I have used that on models before. However, he was talking about the breeching and how to deal with installing it and the guns. Russ
- 601 replies
- constitution
- revell
