russ
Everything posted by russ
  1. Do you not have the carriage and cannon? There is a table of dimensions for carriages in Ship Modeler's Shop Notes, from the Nautical Research Guild. The table covers 4 pounders and larger. Russ
  2. Pete: Thanks. I appreciate the kind words. Russ
  3. Alex: Beautiful work. Congratulations on a fine looking model. Russ
  4. The filler and transom look much better now. You can take some of the planking and hold it up against several frames and see how the fairing goes. Fairing is a long process of sand, check with a pank, sand some more, fill, check with a plank and so forth. Russ
  5. Guy: Yes, those drawings are what we used in developing the plans for this build. Russ
  6. Shot diameter will do. There was a slight difference between shot diameter and caliber as I recall, but it should be close enough for your modeling calculations. Russ
  7. According to Charles Davis's book, The Built Up Ship Model, the sill height would be 3.5 times the caliber. Russ
  8. Guy: Thanks. Glad to see you back as well. Russ
  9. Adam: That is a good looking model so far. You have done good work framing her. Russ
  10. Yes, the floor timbers are forward in the forward part of the hull and aft in the after part of the hull. Russ
  11. While silding ways are interesting, one thing that most modelers want when they place their model on a display base is that it NOT move. Your choice though. Russ
  12. For the display, the options are wide open. You can do anything you please. Brass pedestals or launching ways, either sounds good. Russ
  13. Alfons: That looks good. If the joints are good, you will be able to give them a slight tug or bend without any issues. Russ
  14. Pete: That jig is a very good idea. Excellent work. I also agree on the fillers for stiffening. I have used that on a cross section model and it worked well. Russ
  15. Dick: Thanks. It has been good to be able to work on it a little bit. Russ
  16. The shape of the filler looks pretty good so far. Still needs some fairing though. You are on the right track with it. The bottom planks will curve up to end at that horizontal line at the transom. Along the side, you need to smooth it out from the end of the last frame through the transom. Russ
  17. The answer will depend a lot on how accurate you want to be and what sort of ship you are building. The short answer is that the framing dimensions can be whatever you want them to be. Without knowing more about the ship in question, scale, time period, it is difficult to say more than that. Russ
  18. Try bending them over a steel machinist's square or a small anvil. A piece of machined metal will give you the sharpest angle over which to bend the wire. Russ
  19. Thanks. It is very enjoyable working on this model. Hopefully, I can get a little more done this weekend. Time will tell. Russ
  20. Kevin: I have used hidden dowels like that to attach things on models and it really helps. Good work. Russ
  21. Carl: Thanks. I will be the last person on earth using imperial measurements, I have no doubt. Russ
