KeithAug
Everything posted by KeithAug
  1. Richard - yes it was intentional. Much easier to adjust from being too deep than adjust from being too shallow - being too shallow might involve correcting multiple slots or alternatively making the majority over deep and just a couple correct.
  2. Thunder - see above post. Im not sure what size you need but these blades are available in many diameters and thicknesses - although you might need a spacer for the bore.
  3. Amazon:- They have a 22mm bore - not 0.5" as on the Byrnes saw. Jim used to sell spacers but I guess they are not available at the moment. Making spacers is very easy if you know someone with a lathe.
  4. The hull turned out rather well.
  5. You should have been a plumber. Beautifully neat pipes.
  6. Rick - it really is dark green - if the colour chart is anything to go by.
  7. Rick - I have been meaning to ask - can you remember what colour she is? She sometimes looks very green and sometimes very blue.
  8. Andy - I didn't try water as I was a bit worried about distorting the frames. I was probably being a bit over cautious. Richard - I tried alcohol but probably didn't leave it long enough. Never mind there is always a next time. Rick / John / Tom - thank you.
  9. Roger - Too true. I constantly think I would be much more productive if i just spent my time building the same model over and over again. On the other hand the most interesting bit is the problem solving. The hatch cover removal process seems like a nightmare. I assume they don't do it that way anymore. I'm not quite sure how the jig is working. Is the taper peg just a holding (tensioning) feature?
  10. I am taking my time preparing stuff before I commit to the glue. I sorted out the small frames at the bow and stern. I spent a happy day stripping the cutting templates from the frames. I didn't find any of the usual solvents worked particularly well on pritt stick adhesive but peeling / sanding worked ok. The cut line for the deck made the frames very flexible and I wanted them to be a little stiffer for the future hull sanding process. I therefore temporarily glued small strips of wood across the deck cut line to increase the stiffness. I also sorted out the correct vertical position of the keel. The keel slots were cut deeper than needed so I cut the keel strip and then assembled it into a few of the frames before setting it to the correct heights fore and aft. With friction holding the keel in place I glued tabs to the frames to fix the keel position. The line of the keel is broken at frame 61 and the next job is to sort out the position of the aft section of the keel. Not very exciting but progress is progress.
  11. I agree. I tend to use the thinnest blade I can get away with to reduce waste. In practice I never find anything less than a 1/32" (0.8mm) slitting blade is stiff enough to prevent it flexing and wandering off line. If the wood is difficult (pronounced grain, hard, high moisture) I tend to use a .040" (1.0mm) blade. I always go for a slitting saw with large teeth.
  12. Bigcreekdad - One other possible cause is the grain direction on the wood you are cutting. If you are using a narrow blade and the grain tapers away from the fence then the blade tends to follow the grain and the resulting planks can have a taper. If this is the case try flipping the wood over lengthways so the grain taper is towards the fence. This usually improves the accuracy of the cut plank.
  13. Andy - It would make a nice lamp base. That is the sort of thing I say to my wife when I am in need of a tongue lashing. I like the thinness sander.
  14. Nice little model Phil. It seems like the rule is "the older you get the quicker you get". I'm looking forward to my imminent speed increase!
  15. Eric - I find the older I get the quieter they get! Nice progress and a great way to see the old year out.
  16. Thank you Keith, Richard and Andy. Happy new year to everyone, as now hopefully we have all made it safely into 2024.
  17. I have a combined belt and disc sander. I don't think I have ever used the belt sander for model making. The disc sander is single speed and I constantly find myself wishing that I could turn the speed down. I am thinking of buying a variable speed disc sander and relegating the combined machine to non modelling work.
  18. Happy New Year to all of you in 2024 from the rest of us still in 2023.
  19. Valeriy - That is the same for me, but i really am running quite short of sheet. Hopefully I will run out before it does.
