Everything posted by KeithAug
Byrnes saw belt source in UK/EU?
KeithAug replied to bruce d's topic in Modeling tools and Workshop Equipment
Bruce - where please? -
Keith - Interesting technique for the rat lines - must remember. I'm impressed - my head is rarely in the game for long periods these days!!!!!
Cap San Diego by mikegr - 1/160
KeithAug replied to mikegr's topic in - Build logs for subjects built 1901 - Present Day
The deck structures somehow jar with the sleekness of the overall ship design. The designer must have gone into utilitarian mode when he drew them.😀 -
Tom - as you rotate them they move closer to the hull - hence they clamp against the hull. If they were concentric they wouldn't do this. In effect they are acting like a cam.
Lovely work on the deck beams. Like the jig. I hope you got the drum sander in your birthday present pile - if not perhaps next year! Like you I don't have a drum sander but I can't decide if I really need one. I have a sanding drum which I mount on the mill which sort of works. The issue I have with drum sanders is that I am sure that I would constantly want to change between coarse and fine grades of sand paper and most drum sanders don't seem to make this a quick and easy operation (unless someone knows better).
Despite the continuing cold weather and many hours discretely studying my next build I did brave the worksop to finish the display cradle. I wanted the model to be lightly clamped by the cradle at deck level so I turned some eccentric rings to act as clamps. I also machined an "o"ring groove in the rings to provide a soft bearing surface. I also machined a spigot at the lower end of the supports to fit into a cross brace. The cross brace is necessary to prevent the supports splaying under the weight of the model. The cross braces were machined from 1" x 1/4" aluminium bar and polished to finish. The base was given 5 coats of wipe on poly and wire wooled between each coat. The supports were then attached to the base using 6mm screws. Then it was time for germania to say bye bye to the building frame that she had occupied for the best part of 3 years. The critical element of the move was the tolerance between the model and the keel slot. Fortunately I got the cradle dimensions right. The position of the clamping rings was also a bit tricky but this also turned out well. And finally the most critical check------------ That was a bit too close for comfort - about 3/8" Now just a few finishing touches required - a good clean, make the pig stick and burgee and the ships flag. Then it will be time for a major photography session. I must think about starting my next build log. P.S. Damn - I just remembered that I installed the for top fore mast back stay as a single fixed back stay when it should have been a pair of running back stays. Im sure no one will notice but that's not the point!!!!!!!!! 5 more blocks required and some rigging rework.
Brian, Ouch! Somehow I missed this. It’s good how you guys can plan your health issues around the annual insurance cycle. Get well soon and remember to thank your driver! 🙂
A man after my own heart. I’m all for open ended commitments and flexible targets. At our age it’s good to have a bit of wriggle room. Lovely neat work on the rigging. May the sun shine brightly on your next task.
Today my wife caught me on the computer studying images for my next build. She commented "there are plenty of other jobs to do before you get into that".
Maximizing Model Work Area: Lathe Table
KeithAug replied to Thistle17's topic in Modeling tools and Workshop Equipment
Nicely done. How do you avoid the artists wrath when you create your dust? -
Roger, Tom, Andy, Keith, Brian, Druxey, Veszett and Gary thank you all for sticking with my lamentably slow progress. Also thanks to everyone else for their visits and likes. The workshop is rather cold at the moment as I am trying to do my bit for the energy crisis (as well as monetary prudence). The lack of heating is persuading me to sit in the lounge while drinking tea and researching my next build - quite pleasant but not conducive to completing Germania. Anyway here is a bit more progress:- Having glued the keel slot insert in place I moved on to covering the edges with mahogany strips circa 1/2" x 3/4" section. For years I have been thinking that I need to buy some sash clamps - but I never do - so improvising with rubber bands is my default option. The masking tape is to stop the PVA glue spreading on to the prepared board surface. With the edges attached four holes were drilled to take the pedestals of the cradle. As with my previous builds the door handles from a previous household kitchen were pressed into service. I had just enough left for Germania so this is the last time that they will feature. The next model will need a different solution. The bearing service for supporting the hull was made from nylon rod. This was machined to the correct cone angle to bear against the hull. The support ends were drilled and tapped to take the base mounting bolts at the lower end and clamping cams at the upper end. More next time - if the temperature improves.
My mental picture to explain why the sails are not full is as follows - After a good days sailing the wind is failing. The force 5 of the early afternoon has progressively moderated and has it has done so more and more canvas has been hoisted. The lengthening shadows and calming seas has encouraged a degree laxity and the crew broke out the gin a couple of hours ago. Germania is only a couple of miles from the anchorage and the Captain is reluctant to hoist the brass sail and so ruin a perfect days sailing. The wind has now all but failed and progress towards port is pitifully slow. Cats paws of wind occasionally disturb the mirror like surface of the ocean and ghost Germania on the odd few yards at a time. Part of the crew are are starting to agitate for a more rapid, engine assisted, transit to the delights of the local bars but the majority, in their gin induced stupor, are reluctant to expend the energy necessary to stow the sails. In this state of limbo the crew sit and watch the setting sun slowly sink into a golden sea only challenged by the piles of beer cans inhibiting their frequent transit to the heads. In consequence all the sails are hoisted but flapping gently and the boat has no heel. P.S. the scenario described isn’t entirely fictional.
