Everything posted by kurtvd19
The scriber from UMM is very good - have used one many times UMM03 UMM™ Third Generation Scriber SCR-03 "Universal" I have used it mostly on plastic to delineate door and window seams/openings in scratch built tugs where there is a line visible where panels and components join. However, I agree with Roger that scribing the deck will give you an unrealistic appearance.
Stay-Brite has plenty of strength to with sand any amount of tension that can be put on rigging a model ship. I have used it with wire rigging on 1/12 scale models. I would say that the yards or even the mast will break before a Stay-Brite joint. Used to use silver solder all the time - started with radio control boats and needed it for certain joints - rudder, control arms, etc. Tried Stay-Brite on those joints and tried to break them and gave up and it's very rare that I use silver solder today.
Glad you resisted the urge to get a photo floating on the river
- 599 replies
- sidewheeler
- arabia
(and 4 more)
When I want wood to be smooth I use an automotive body filler meant to fill scratches in final or close to final sanding. It adheres to wood w/o any problem. Bondo Glazing and Spot Putty. This isn't meant to fill massive dents, dips are voids - that's regular body filler Bondo. I use an old credit card as a squeegee to force the filler into the wood grain - don't let it build up. When cured I sand it and see how smooth it is. If you want the part to look like metal or fiberglass multiple coats might be needed. Some use Spackle wall hole filler the same way.
Unless the motor is classed for use in a spray booth with combustible vapors (NEC Class 1 Division 1) you are just asking for trouble. Using a house fan in place of a properly classed exhaust fan is an accident waiting to happen. It's not IF a fire will occur but WHEN. Water based acrylics are the only safe paint to use in a spray booth not using the proper type of fan. No amount of filtration in front of the motor makes this safe - filters only trap particulate matter not the dangerous fumes. The rate you mention is the lower and upper combustible limits of a combustible or flammable liquid - the % of combustible vapors to air mix. Good luck.
BUYING A "PAINT SET"
kurtvd19 replied to MadDogMcQ's topic in Painting, finishing and weathering products and techniques
I agree with Grant - buy what you know you will use and then add colors as the need arises. -
Eric: Feel even better about it because I had absolutely no input on the selected images so the model made it without my positive bias toward riverboats. Kurt
- 599 replies
- sidewheeler
- arabia
(and 4 more)
Check the directions (page 12) - the rabbet is only needed on the last scale foot of the plank ends. Sanding will work as shown in the photo from the instruction book (below). However, the gains on this boat are different. Each is a sloping rabbet, rebate or recess, cut along the last scale foot or so at each end of the plank. This gain is a scale inch wide. You can measure this using the scale rule (page 7). Mark this distance on the edge of a paper strip, then transfer this measurement to the plank. Carefully cut along the line with a sharp blade. Don’t press too deeply! Then shave the slope using a chisel blade in your craft knife handle. Make the deep end of the rabbet no more than about ⅓ the thickness of the plank. At the transom the planks fit as shown here (below right).
- 53 replies
- norwegian sailing pram
- model shipways
My Space Saving/Mobil paint Booth...Mario
kurtvd19 replied to Cap'n Rat Fink's topic in Modeling tools and Workshop Equipment
Images are to be attached to your posts here - not on 3rd party sites. -
350's are real workhorses. Also capable of good paint jobs. I can point to 6 models that took gold at Manitowoc where the paint jobs didn't hurt the results. They have to be the easiest to clean too.
- 40 replies
- best airbrush
- compressor
I recommend the Badger Modelflex Marine Paints - acrylic paints ready for spraying. MSW sponsor USA Airbrush Supply carries these paints. Simple shake to use. Note that when you go to the sponsors on the right hand side of the main page here there is a line of text that says to use a NRG discount code at check out. USA Airbrush has the lowest prices for these paints and then an additional discount.
- 40 replies
- best airbrush
- compressor
I rinse with water, then a cleaner I mix. Use it between colors and then at the end of the day I do the same, remove the needle and reapply needle juice when I put it back into the brush. Final thing I do when done for the day is to spray a short eyedropper of Lacquer thinner through it. Have never had a problem with a dirty brush but have cleaned many up for friends who were not as thorough.
- 40 replies
- best airbrush
- compressor
One tip on using the tilt table. If the saw is kept level using the tilt table is a bit awkward. Use a couple of wedges under the saw so the tilt table is level with the bench top and it does away with the awkward working on the tilt table and the tendency for gravity to work against holding the wood against the uphill fence.
2021 NRG CONFERENCE
kurtvd19 replied to kurtvd19's topic in NAUTICAL RESEARCH GUILD - News & Information
How about the Nat'l Museum of Toys and Miniatures in KC? The collection they have of miniature tools, tool boxes, etc. is someplace I am going when I go to see the Arabia Museum again. -
2021 NRG CONFERENCE
Chuck: We constantly hear from E & W coast members that a mandatory element of a NRG conf has to include salt water. Here by the Great Lakes we like to say that Doctors are always saying to cut out salt. Also, our waters are guaranteed to be free of sharks! Not that you would be likely to swim in Lake Superior - it makes the Atlantic and Pacific Oceans feel like kiddie pools temperature wise. Duluth is also one of the busiest ports in the US. -
2021 NRG CONFERENCE
Roger: We lost the third vote for Duluth when Steve died. Toledo is on the short list. You are probably correct about the CA airport situation but good spots near to airports are very expensive and already been done. There are many of our members who can't get to anyplace on a non stop flight but they bite the bullet and do it. Then you have a place like Boston - easy to fly to - but traffic worse than LA. It's a real balancing act. -
AZTEK AIRBRUSH SET This is the deluxe set of the Aztek Airbrush – I think it was produced by Testor’s. I have never used this brush and have not tested it. But it was formerly owned by the late Steve Wheeler and he took great care of his tools and it appears to be immaculate. This does not include an air hose or instruction book. SOLD Cost is $25 plus USPS shipping (at exact cost) US & Canada only. PayPal preferred. Please reply by PM.
