dafi
Everything posted by dafi
  1. @shipmanHere they are 🙂
  2. These "side"-davits were not present at Trafalgar for sure, the earliest proof I know is about 1860. Even the aft Davits do not show up as evidence before 1824. All contemporary drawings, paintings and plans I know do not show these davits until 1807- The last one without is from Robert Dodd, published in 1807, still with the old beakhead bulkhead. First appearance are on drawings John Christian Schetky 1824 and 1827 and Edward William Cooke 1828. Ever since these are a prominent feature on all following illustrations. The same goes for the stern davits, who first shown up in 1920 if I am not mistaken. But these are my little thought after looking at this detail for a long time already. Take your own conbclusions 😉 XXXDAn PS: Clarkson Stansfield´s "Victory being towed into Gibraltar after Trafalgar" was made after 1857 afaik, so I would not take too much into consideration for the details.
  3. Hourrrrraaaaaaay, pictures are working now. It looks like there was a Rich Text Format among. Do not know why, but ok to know for the next time. Had to reinsert the links in an unformatted form. XXXDAn
  4. Its always great to have friends that keep an open eye and give valuable hints. Special thanks go to @Morgan who helped me so much already and here came his updates. The bolster of the anchor lining was to be extended more to the front. Possibly to have the possibility for someone to stand there if the catting needed an action from there. And the small flap on top of the carronade. Most carronades had ports that were higher than the normal ones. As the solid bulwark was not high enough that was an easy way to protect the wood. Thank you tons Gary! So the bolster needed a good base to adjust the height ... ... and the extension was fitted. With a lil´bit of color it looks like it was already always there. And the flap was an easy Task to be fittet 🙂 And then we took the chance to go and see some modeler mates ... All the best, DAniel For some reasons the pictures do not show ... 😩 😩 😩 [ edit: pictures rescued 🙂 ]
  5. In our german forum we had a nice discussion about the "single bar was 1/3 the maximum beam" . On my Vic it fits perfectly for the lower capstans, but not for those on higher decks as for the curving in of the hull (tumbledome?) as also for the capstans on quarterdecks of frigates with the deck already getting more narrow on top. The conclusion was that the 1/3 beam must have beeb defined by the place and deck the capstan is situated. Here are some thoughts I had some years ago on my Vic Red is the 1/3 beam, the others were variations. The small circles are the stanchions that have to be taken out for the bigger circles of the same color. One can see, that the 1/3 beams works there if the guns are moved. But as the aft capstan was basically worked from the middle deck, these long bars would already touch the hull 😞 XXXDAn
  6. Thank you Gary and druxey. Very nice detail the small flap. Could it also be to protect the bar from the side effects of the shot? Often the ports for the carronades were higher in size for that reason. Also I realised the bolster being extended forward. My interpretation was - as I realisd it mostely underneath gunports - that it would perhaps allow an temporary extension for the board. The step is a great explanation too. I do not think this was for sounding the lead I know it being done out of the channels or another small platform amidship. There too the breaststrap could be fixed more easily that allowed the men to lean against and have the hands free. Difficult to be seen, but the strap is there 🙂 XXXDAn
  7. This is the jack to lift up the deck beams on english ships to remove the pillars as described by Blaise Olivier ... As Commander Data would express: Fully functional 😉 XXXDAn
  8. And sitting on the gun is not unusual to be seen on paintings. Also later on to be seen with the french ... And a fresh picture of Hermione, giving a hint what it would mean 😉
  9. Not a really early ship, but still to be seen in the Vasa. The two first guns on each deck only can fire forward seen the angle of the port, the two rearmost guns each deck only aftwards. Also the big gun on the forecastle points very much forward, as its port shows. This also can be seen, as this gun is colliding with the cathead as result of the 90° position in the 1:10 reconstruction 😉
  10. So the trilogy of the 4 slices is almost done 🙂 - 1765 to 1780 (as build) - September 1805 mid Atlantic on the chase of Villeneuve - 1920 before docking - and the latest revamp 2018 Still have to make a nice frame. XXXDAn
  11. Luckily @Morgan discovered a small detail in the large Turner painting: The anchor lining, almost hidden by the fallen fore sail. Looking at the Turner scribbles there is a line, that could be interpreted as the bolster for the lost lining. Looking at the Queen Charlotte of the the same time, one could see how it should have looked. First the frame was added ... ... then I realised that the lower batten should have been the bolster. Took one step that was left from the entry port and it fitted 🙂 Unfortunately it broke while fixing 😞 The replacement part was bent the wrong way, so I took the time for a cup of tea and did hang the part inside to make it flexible, bent it the right direction and let it cool down in its new shape. After fixing it, I realised that it sat not properly ... ... even the paint did not help. So another disassembly took place ... ... and then it fitted 🙂 As the anchor lining was to protect the hull and the irons from the anchor, I wanted to show some scratches. First I took a spare anchor to simulate its way up ... But how do those scratches look like? It was not a metal hull with clean rounded scratches, but I opted for some splinters on the edges of the planks and some flakes of paint coming off. The color I oppted for a warm siversih grey, like old exposed wood is showing. Need some black ink to simulate depth. After the lanyards was fixed ... ... things were done 🙂 Cheers, DAniel
  12. It is possible, that the quarter Davits were not present at Trafalgar, as they are missing on the Turner drawings and all post-Trafagar drawings too and are shown for the first time on a drawing of 1822 if I recall well. The stern davits were already disassembled several years ago. All the best, DAniel
  13. two pieces of masts that claim to be original 🙂 HMS Victory 1803 Great Britain 1855 🙂
  14. The bolt rope is a good hint. My personal guess would have been single pieces from stanchion to stanchion with a decent overlap, tied down with an eye or loop like you wrote. If the sides are longer on the outside with overlap on the deck (gangway) or bulwark (q´deck), then the water should not come in but easily get out, and if the inside is just a bit shorter to allow water to go out (gangway) and to air properly. Sounds at least reasonable and a good working guess. Thank you, DAniel
  15. Thats why I like to call it an "Almost-Replica". And I do not mean it bad. The did a good job imho to keep this wonderful heritage alive, regarding the money and the existing knowledge about the times. And this knowledge was expanded a lot within the last years, thank god. XXXDAn
  16. Thank you rkwz Nice still from the film, one can see nicely both colors and how messy the wood is 🙂 From Victory in her true Colours: https://www.youtube.com/watch?v=KmNXRWtQ-P0 XXXDAn
  17. Hello Gary, thank you! That is a very good base for reconstruction. And thank you for the hint I missed the lining completely! Have still to fix it. All the best, DAniel
  18. Gary thank you!!! Lesson learned, look back to the sources you worked already on 🙂 Need to double check the other Turner drawings for the details he emphasizes ...
  19. Thank you Sirs! O Goody, I missed the 215th anniversary that happend 4 days ago of that little depicted scene. Logentry on the 08/08/1805, somewhere in between Gibraltar and Spithead "08.08.1805 painted quarter deck and hull" 🙂 🙂 🙂 And that was only 16 days before the ship underwent a short refit at Spithead. Within 7 days she got the guns removed, the spars sent down for check, the sails checked, and plenty of caulking was done. Afterwards she went to sea immediately but the delivery of a larger quantity of paint suggests, that the painting went on on sea. Recorded is the 10/09/1805 that the Breadroom was whitewashed. But still good to know, that exactly today, 215 years ago on the 08/12/1805, the main topgallant sail split in a squall. XXXDAn
  20. After missing information on how the covers were fixed, I opted for easy folds and will change that as suitable information comes. Still got some netting on the face side and fixed an iron hook. After a transatlantic voyage, I suppose the ship to look a bit tattered. So some man are meant to do do a small face lift 🙂 So the last slice is done. Still need to clean the others up and fix them on the frame. Soon this project is finally to be finished 🙂 Titel: 1805 mid Atlantic, return from the Caribbean, ... Enjoy, DAn
  21. One question I have is about the hammock crane covers. Sources say it was sail cloth either painted or tarred. Very nice detail for smaller scales to omit the nettimg 😉 Interesting also for larger scales - like my 1:100 ( 😉 ) to apply some extra detail. But the question is, how was it fixed? Was it simply thrown over and fixed on the cranes i a way to be open from underneath? Was it in multiple parts like a bag with a separate flap or cover on top? Was it also covering the cranes or was it inside with the cranes visible? Are there any contemporary sources giving clues for that? Here is one of the few models of the days of the hammock cranes with cover. Still the question ist, if this is original or was it added in the said restoration? https://collections.rmg.co.uk/collections/objects/66307.html SLR0346 Scale 1:48. A contemporary full hull model of a frigate (circa 1805) built plank on frame in the Georgian style. Model is decked, equipped, and fully rigged with a full suit of sails set. The hull is complete with copper sheathing which was added in the 1960s by Jim Lees in the Museum's workshop.This contemporary model is fully rigged together with sails, which are thought to be original. The hull has the solid bulwarks on the upper decks and an enclosed waist, both of which offered greater protection to the crew when under fire. It is has a full complement of boats from the large launch to the smaller jolly boat mounted on davits hanging over the stern. The copper sheathing below the waterline was introduced by the Navy in the 1780s. Its purpose was two-fold: it prevented weed growth, which would reduce the ship’s speed, and to stop damage to the timbers by the marine boring toredo worm. Date made circa 1805 Here some details: In the last pictured one could guess that there is a flap on the outside of the gangwax hammock cover, just onderneath the rope. Here some pictures of later days, when the cranes were replaced by boxes. XXXDAn
  22. Back to the slices 🙂 Luckily found some old spare decks to cut a small stripe for the visible Gangway. Then "tarred" the hammock netting, this time a bit darker than I usually do. Used some paper stripes for easy assembly ... ... shortened the inboard side ... ... and fixed it. Then fixed the net on the rope on the outboard side, always giving a touch of gravity into the ropes. Made the hammocks with Magic Sculpt. Dry test ... ... and the colored with all the colors of life ... ... and put in place Still thinking how the cover should be fixed in a contemporary fashion ... XXXDAn
  23. @Morgan Yes and I thank you for pointing the lining out to me. But are there references how this looked as the chain board was set up one deck higher at Trafalgar? XXXDAn
  24. It is a very interesting model with many features rarely seen: All the scuppers on the decks Open Top of the side galleries Side gallery windows with different rhythm of battens D-Blocks for mizzen and main mast different colors of the inside of the ports! number of eyebolts on the port lids Lid of the quarterdeck ports have the lanyards up to the poop Axiometer Gratings Qurterdeck Skylight with flat top All the different colors of the inside hull Eyebolts beside the Preventer Chains for tightening the shrouds form of the side entry steps Scuttles for Top Tackles straight chimney Preveter chains for the rudder, leading to the poop (!) And many more features 🙂 🙂 🙂 The only thing I do not understand are the stantions for the hammock netting on the quarter deck. This does not make too much sense to my understanding. Any idea about that? XXXDAn
