dafi
Everything posted by dafi
  1. Thank you Druxey and Jaager, the staples of the Vic are still in place and give a good impression, but I found no picture that could reveal the dimensions. As the Vic has two false keels, one as build and the other added probably around 1800 one has to also to take care, what staples are for which keel. http://www.google.de/search?hl=de&q=hms+victory+keel&gbv=2&sa=X&oi=image_result_group&ved=0CBQQsARqFQoTCOKg877dhMYCFcy3FAodwUkAaw&tbm=isch Luckily these are about the only original staples of the golden age of sails :-) Cheers, DAniel
  2. Very enjoyable build, love it, cheers, Daniel, also master of rebuilds ;-)
  3. Very nice result, thank you for showing!!! Congratulations, Daniel
  4. The false keel was fastened by vertical copper staples. At what distances were those placed? Cheers, DAniel
  5. I think the "official" butt schemes are an ideal solution, that ensures maximum strength of the deck which is a integral part of the structure of the ship and not "just some planks to walk on". But reality then collides with plenty of issues, the biggest probably is dealing with the material available. Also repairs will easily give some deviations to the pattern. Also the Vic there are some parts where a 4 but shift can be recognized, but most is a irregular pattern. Whatever patter you prefer for what year is up to you, nobody can prove how it was in the year 1XXX. Just there are some remarks: It was never as neat as we would like our models to look ;-) I think important is to respect the deck beams, get near to a 4 butt shift system and avoid short ends and butts in between coamings and near the start and end of the decks. Cheers, Daniel
  6. Thank you sal, Pop, Izzy and Ian. @Izzy Thank you for the pictures. The modern model making version that I use and that works very well is the one shown from RB Productions and come in all necessary sizes: http://www.google.de/search?hl=de&q=rb+productions+rivet+tool&gbv=2&sa=X&oi=image_result_group&ei=ZUVxVdzDJILkUoG_gpAD&ved=0CDAQsAQ&tbm=isch Those I already tested but it was good for the seam of the plates but it was great to find the dermaroller as there the points are still finer - necessary for my scale - and also to see the trick of having the parallel rolls for an even appearance of the surface nailing as Popeye mentioned. Cheers, Daniel
  7. Smells like danger ... ... big danger ... ... enormous danger ... ... one of these days, I was in the bathroom and I found a new torture tool belonging to my wife: a Dermaroller! Iron Maiden just inverted, spikes outside - how that could help the skin I will never understand. But if you believe that that thing is dangerous, you are on the wrong track - the danger lies somewhere completely else!!! I suddenly had a flash of inspiration and wanted to have a closer look at the thingy, and believe it or not, it crumbled into pieces just in front of my very eyes, I solemnly declare I did not touch it - I just looked ... ... but if it is already prepared for needing reassembly I thought that I could try out something. So I took out the 1,5 mm thick pinky spacers and replaced them by 0,5 mm sheet. Used the old ones as template, so it went rather fast ... ... and reassembled the bit with only five spikewheels :-) And here it is the patented Dr. dafi Rivetroller®© :-) :-) :-) Immediately tried it out on the copperplates to get an even and parallel surface-riveting ... ... which worked wonderfully as the roller had the right thickness for the row of plates ... ... and afterwards just gave the tighter riveting on the edges of the plates with the Riveter from RB . The small vertical lines come from the nut on the back of the small riveter, me doofus did not pay attention to this small technical issue. So if it takes some time to come back to you, it could be that I am trying to learn how to drink out of a sippy cup and also I do strongly believe that it will be difficult to type with broken my fingers ... ... as I am quite sure that it will come, the scream: "Daaaaaaaarrrling, have you seen my dermaroller?" ... ... and yes that is the true danger ... ... XXXDAn
  8. Why?!? Why did this gem did escape my attention so far? Wonderfully build and thank you for showing so much of the "how to". Cheers and congratulations! DAniel
  9. Very nice work :-) For the gun tackles: There are plenty of ways to store them your version I saw on the Costitution :-) But if nobody is holding the free end, I would advise to secure them somehow. Either like I did behind the pulley with a kind of half hitch that can be opened like a lacet, or Boudriot shows something secured around the breech, in your case a nice tie around the faun´s head. Cheers, Daniel
  10. Great tool :-) I think there are some little tricks that could still improve the outcome: First when cutting the thread unravels. Better pass the whole length though PVA or wallpaper glue to stop this. Second before cutting put a drop of superglue onto the knot and the 1 mm underneath - so the will keep the direction. Cheers, Daniel
  11. Thank you Izzy, Popeye, Steve, OC, Jerry and all the kind likes! Special thanks for information about Brown Betty, very appreciated! Great picture you and Bess :-) Looks like mine are 135 cm, have to lengthen the next ones by a 1/10 mm ;-) Luckily the strap is hiding the lump :-) Cheers, DAniel
  12. Slowly hunger was shifting the mood and there were some concerns about the two sentinels being able to handle their mates ... ... so back to plan B and deliver the goods in form of the earlier proposed 10 course dinner. But small oupsy happened ... ... the meal was historical, but 107 years to young, I found hints it was from the 14. April 1912. So thinking about the side effects of this meal, the marines discussed and with an ice cold mood decided to opt for the normal stew. We should have a small look into the bucket, that would give us a hint, which day of the week is displayed in the small setup: Sunday 1 pound pork, ½ pint peas
 Monday 1 pint oatmeal, 2 ounces butter
 Tuesday 2 pounds beef
 Wednesday ½ pint peas, 1 pint oatmeal, 2 ounces butter, 4 ounces cheese
 Thursday Same as Sunday
Friday Same as Monday
 Saturday Same as Tuesday An overview over our gay* party shows an increasingly raising mood, as the mess on the right is already served - with a lovingly elegant gesture the wooden spoon scratches out a blop of food out of the bucket and conveys it to the square plate with the metal dish *floush* Also the mess on the left is starting to giggle in anticipation as their bucket full of delicious food is coming nearer and perhaps even can be guessed through the olphactorical chaos of the lower deck. And dinner is served :-) Usually a mess consists of 4 to 8 man that shared cooking and eat together. One had the duty to bring the food to the Brody stove a deck above and take care that nobody stole food from it while being cooked. In case of the Victory there were about 160 messes. Next bucket with food for souls is drawing nearer. Now that is party time! See some already took off their jackets and hung them up on the ceiling. But nobody dared to throw them over the gunz ... One can see it simply is a tight and cosy place :-) XXXDAn PS: The drawings of Bray´s album still show the pre-1803-uniforms. http://collections.rmg.co.uk/collections.html#!csearch;searchTerm=bray * and gay here in its original meaning ;-)
  13. Hy Izzy, I have a similar piece in even better condition. I do believe it is to coarse for the pulleys. Perhaps for the windlass of the grand barge? Cheers, Daniel
  14. It follows the rope sizes :-) It is indicated in the rigging tablature in the end of McKays AOTS :-) XXXDAn
  15. Thank you Jason and Jan. The return question is: Will the lower gun deck ever be 'done' ... ;-) XXXDAn
  16. And what does one do, if one has a bunch of hungry marines waiting for food and sitting in front of the gun room? Of course, one should take precautions. Preparations include getting the equipment ready ... ... and the arms too ... ... and to dress the guards. Ok I missed the epaulets ... ... but I shortened the tails according to the 1803 regulations. Just the officers had long tails, thanks to Foxy for that detail! Larger than life :-) And very important: place them in front of the gun room ... ... for that the Haute Volée can stay in peace and quiet. And the long tails of the to red men in the background clearly show. Yes, we are officers :-) Cheers, DAniel
  17. And always remember: There is not such a thing as one specific length of the plank, as the butts always had to be atop the deck beams, which had different distances! XXXDAn
  18. Makes sense, as the waves would slam it close and not open, which facilitates emergency closing. I already respected this for the etch parts on my Vic :-) Cheers and thanks, Daniel
  19. For that there will be no mutiny because of the empty plates, here is the proposal for the menu, according to historical sources: First Course
Hors D'Oeuvres
Oysters
Second Course
 Consommé Olga
 Cream of Barley
 Third Course
Poached Salmon with Mousseline Sauce, Cucumbers
 Fourth Course
Filet Mignons Lili
 Saute of Chicken, Lyonnaise Vegetable Marrow Farci
Fifth Course
Lamb, Mint Sauce
 Roast Duckling, Apple Sauce
 Sirloin of Beef, Chateau Potatoes Green Pea
 Creamed Carrots
Boiled Rice
Parmentier & Boiled New Potatoes
 Sixth Course
 Punch Romaine
 Seventh Course
 Roast Squab & Cress
 Eighth Course
 Cold Asparagus Vinaigrette
Ninth Course
Pate de Foie Gras
 Celery
 Tenth Course
 Waldorf Pudding
Peaches in Chartreuse Jelly
 Chocolate & Vanilla Eclairs
 French Ice Cream *dream* XXXDAn
  20. Simply a dream! Thank you for sharing with us all, Daniel
  21. Even a better source is Bray´s album in NMM Shows chest everywhere and being seated on :-)
