Roger Pellett
Posts posted by Roger Pellett
  1. Nice work, Larry, and an interesting subject too.  Wooden camp boats bring back great memories.  The camp that I went to had a fleet of wooden catboats for beginners.  “Wood Pussy” or “Beatles,” I don’t remember which.  If I modeled the one that I sailed it would have a lot of scrapes from hitting the dock.
    The camp should be delighted to receive this handsome gift.
    Roger
  2. Ships boats were specialized tools intended to assist the parent vessel in accomplishing its mission.  Their design, therefore, reflected what it (the parent vessel) was intended to do.  Even “lifeboats” assumed to exist on ships built by neophyte modelers were actually specially designed to perform a specialized service- to shelter the maximum number of occupants safely in the case of a maritime disaster.
    I am not familiar with the Mermaid and cutters as a vessel type served in many roles where small fast vessels were  preferred.  Knowing what Mermaid was designed to do would provide some idea of the types of boats that she carried.
    Roger
  3. I am on my second Badger 350 and find it to be great for spray painting a model with acrylic paints.  (I don’t represent the company.). It is foolproof and easy for a ham handed person like me to clean without damage.
    I use this with a small air compressor with air tank.  The air tank allows the compressor to maintain a constant pressure at to the airbrush.  As posted above, one of these at a big box home improvement store will cost slightly less than $100.  The air brush uses a surprising amount of air and I second the comments about the “canned air.”
    In my opinion, a secret to using an air brush is having a good supply of air at a CONSTANT CONTROLLED PRESSURE.  My compressor stores air at 125psi but the airbrush works at about 25psi.  It is therefore important that the compressor include a regulator valve to control pressure to the air brush.
    The body of the Badger air brush is made from cast resin and the nipple connecting the air supply is machined brass pressed into the body.  Overpressuring the air brush will eject the nipple from the body and require buying a new one (CA or Epoxy doesn’t seem to stick to the resin body.).
    Over the years, I’ve tried all sorts of poor boy paint spraying setups and this is the only one that works reliably.
    Roger
  4. The current issue of the Nautical Research Journal includes an article  by Ian McLaughlan on this very topic (The fake Lexington and the Enterprise mystery).  In the article, Mr McLaughlan an expert on small sailing warships, compares Davis’ plans with those for a British Cruizer Class brig and plans that have been found that supposedly apply to USS Enterprise.
    Well worth reading!
    Roger
  5. Brian,
    I went back and reviewed the series of posts for Cairo’s sister, USS ST Louis that Kurt referenced above.  On the first page there is a photo of the plan view of USS Cairo that they got from the NPS.  It is different from the one that you are using as it shows the chine running back to the stern post as we discussed.
    On the fifth page there is a photo taken during the CAIRO salvage that shows the stern with rudder attached being lifted from the water.   It clearly shows what we have been discussing.
    Roger
  6. Brian,
    Sorry if I am causing you more heartburn but is it possible that although  frames 10 and the one preceding it match the drawing they are also wrong?  If the bottom began to narrow further forward the stern lines would taper to a finer point at the stern post as your photo seems to show.
    Roger
  7. Your plan is wrong.  The line that you highlighted in red is the boat’s “chine” the line between the flat bottom and the angled side.
    The plan and the photos of the actual vessel indicate that the stern post is vertical. Assuming that the bottom continues to be flat on either side of the paddle wheel well, and the sides continue to be straight lines, not curves then the chine must intersect with the bottom of the sternpost as you show with your green line.
    This means that the slope of the side frame relative to the flat bottom will gradually increase as you move aft until it becomes vertical at the stern post.
    You need to redraw the chine in this area.  Unfortunately I don’t believe that you have sufficient information to actually plot this so you’ll have to use your best judgement- a nice smooth convex curve.
    Roger
  8. As someone who built, or rather tried to, build models old fashioned hide glue, a brown smelly liquid was available.  Animal based and water soluble.  This is where the expression about sending old horses to the glue factory came from.
    A higher tech glue especially used for building balsa/ tissue model airplanes was an acetone cellulose glue that went by the brand names, Duco, Ambroid, Testers.  Quick drying and water resistant it later acquired a bad reputation for kids sniffing it.
    Both of these glues are are still available.  Hide glue is sold be specialty woodworking suppliers and I bought a tube of Duco Cement the other day at our local Ace Hardware.  It is good for temporarily gluing metal military figures to wood bases so that they can be handled while being painted.
    Roger
  9. What makes Jim Byrns’ Tools unique is their high quality, but he did not “invent” the model makers table saw.  Years ago before CAD when engineering firms built scale models, scale plastic structural steel and piping was cut with a similar saw; I think a Jarmac.  Later, Plans for building a model makers table saw were published in the Nautical Research Journal.  Shortly after that the Preac Table saw was offered.  I still have mine.  I tried to sell it when I bought my Byrnes saw but no takers.
    In this case, I really don’t think that the Chinese are stealing anything.  They’re merely making a small saw.  It’s up to the buyer to decide if it meets their needs.
    Roger
  10. I would have built it in about 1974.  It was a 17ft and as I remember there were two types; folding and non-folding.  The one that we built was non-folding.  It came as a kit with cut out bulkheads,wood strips, and the vinyl covers.  It was like building one of the old balsa/ tissue airplanes.  You first erected the bulkheads on a strongback, ran the longitudinal stringers, and covered the whole thing with the vinyl cover.  The cover for the hull was two ply, the second ply being cemented to the first with contact cement.  The deck was single ply.
    I now have two Old Town wood canvas canoes, a 1915 Charles River and a 1945 OTCA both rescued and rebuilt.  Haven’t paddled either of them lately.
    Roger
  11. Michael,
    Wonderful!  Will you have  crane operator riding in your overhead crane?  When I began my career we still had crane operators riding in our overhead cranes; later replaced with floor operated pendants operated by the pipe fitters themselves resulting in arguments and a fight once over “waiting on the crane.”
    The first shop where I worked had a floor made from wood blocks standing upright with their end grain exposed.
    Roger
  12. The Aluminum base plates are home made- 1/8in plate from the scrap bucket.
    Many years ago while living in Ohio I tried to play golf and even joined the Company golf league- 9 holes every Thursday night and pick up the ball after 10 strokes.  After a while, my golf partner suggested that I keep score by keeping track of the number of strokes less than 10 on the few holes where I didn’t pick up.  Lessons helped but when I moved to Duluth in 1989 struggles to revive a business and the opportunity to take part in a Wednesday night and Saturday sailing league effectively ended my golfing.
    I got the golf ball from my son to use as a final check to ensure that the bench top was flat and level.
    Roger
