![](https://modelshipworld.com/uploads/set_resources_21/84c1e40ea0e759e3f1505eb1788ddf3c_pattern.png)
Roger Pellett
Posts posted by Roger Pellett
For the past 15 years I have worked part time as a volunteer historian/ technical advisor for the SS Meteor Whaleback ship museum in Superior, Wisconsin. Over time we have accumulated a large mass of information documenting the vessel’s history and studies for future preservation and restoration.
A couple of years ago the Executive Director began a formal process to archive this information. I assumed that she would have it scanned and saved as digital information. I was surprised to learn that the museum standard is hard copy paper. A big reason for this is apparently the fear that digital media saved with a particular technology; eg. floppy discs will become unusable by rapidly changing technology.
Roger
I have both volumes and of the two I prefer Volume I as much of the information contained is from years before I became a NRG member. Some of the information in Volume I is somewhat dated. For example I doubt that many readers will need to know how to mix Japan pigments. On the other hand, it also includes some real gems like complete frame patterns to build one of Harold Hahn’s New England schooners.
Roger
I agree with Frank. For a small, space limited vessel like this the cable would be stowed wherever space allowed. I doubt if hemp anchor cables would have been stowed on deck as they could be easily washed overboard in a low freeboard wet craft like this. I see no reason why the cable could not have been led down through a small opening in the main hatch.
Roger
- mtaylor, davyboy and aviaamator
3
Prior to the mid 1800’s most colors were derived from pigments that occurred naturally in nature. Bright, vivid colors were rare and expensive. For example, the bright colors found on the Vasa are believed to be a deliberate attempt by the king of Sweden to flaunt his wealth and even then they were used only on decorations.
Most ships would have been painted much more modestly using common pigments, the most common being dirt, or more specifically earth bearing iron ore. Two common earth tone pigments were a dull red and a “dirty” yellow called yellow ochre. This is still used as a basic artist’s color today so should be easy to find. If it is too bright, try mixing it with a little grey to tone it down.
I wouldn’t worry about the colors on the kit’s box as this is more about marketing than historical correctness.
Roger
Objectively, the term “best” should refer to how well a ship fulfilled the specifications that its designer attempted to satisfy. In the case of a capital warship this is closely tied to the foreign policy objectives that the Navy was required to uphold. This however ignores the fact that these objectives change over time causing ships to be used in roles not intended by their designers.
While it could be argued that the French could afford to build light scantling vessels because they were not expected to remain at sea for long periods of time, 74’s were intended to be heavy weight sluggers and if their light scantlings allowed the British to knock them to pieces in battle then they cannot be considered to have been well designed. Likewise, events did require them to remain at sea for long periods as much of the French fleet’s operation (at least in the 1700’s) was spent defending lucrative possessions in the Caribbean. Speed was also an overrated characteristic in a line of battle ship as their name implies these ship were intended to be an element of a fleet that moved at the speed of its slowest vessel. At the time of the American Revolution the British were able to gain a significant speed advantage over the French by coppering existing ships. This had a significant effect on the American Revolution as during the Yorktown Campaign the coppered British ships sailing faster than the uncoppered French reached the American East Coast first after both sailed from the Caribbean. Not finding DeGrasse in the Chesapeake the British sailed on to New York and the French ducked into The Chesapeake behind them.
While by all accounts USS Ohio was a beautifully designed ship, she really served just as a powerful warship, not a line of battle ship as the US Navy never succeeded in establishing a battle line.
Roger
Even though your model is large it may still be too small for this technique but I offer it for what it’s worth- Rolling and Tipping, I have used it on several wood canvas canoes where I had trouble with brush marks. It involves rolling enamel on and then very lightly stroking it with a dry brush to level out the paint. A small foam roller would probably work. I have used it with standard semi gloss alkyd boatbuilding enamels. With these,enamels a drop of Penetrol also helps to eliminate brush marks.
Roger
In times past, naval architects attempted to deal with paper distortions by the use of a graphic scale on the drawings. All of Chapelle’s drawings include such a scale allowing measurements to be picked off the drawing. As real ships built in the later Nineteenth Century were lofted, drawing distortions would be likely picked up and corrected then. This lofting process means that when we build a model from a design drawing we are building an approximations of the real thing as we usually don’t know what changes were made in the mould loft. For example, the depth of the Great Lakes Schooner Clipper City was increased 18in during lofting. Many of Chapelle’s drawings were drawn from lines lifted from half models in the Smithsonian’s watercraft collection that may be different from the real thing as hull lines could have been changed during subsequent lofting.
Roger
- Canute, grsjax, thibaultron and 1 other
4
The real answer to this question is “it depends.” First the standardized framing shown in the NRG monograph is a stylized model making convention as no one knows how the Lake Champlain row galleys were framed. Like most war vessels built on the lakes during wartime these were built in a remarkably short time and were considered to be expendable so shortcuts would have been taken. I personally believe that these galleys may have been built by erecting widely spaced mould frames with filler frames added as planking progressed. These filler frames were probably semi detached segments- quick and dirty but the galleys held together long enough to delay the British.
Framing practice was highly dependent on location and the methods that the shipbuilder was able to use to translate the hull shape in his mind into a finished hull. The Swan Class Sloops, and Niad Class Frigates being replicated in detail on this forum were built for the British Admiralty where a clear record exists. Similar documentation exists for vessels built for the French Navy. Documentation for large American ships built for the US Navy and for merchant vessels built to classification standards in the second half of the Nineteenth Century also exists. Similar information may exist in the archives of other countries, but if you are trying to build a vessel built before the mid 1800’s in a location other than a government yard you are pretty much on your own. The book Coffins of the Brave includes Archeology evidence for a War of 1812 American Row Galley.
Roger
- druxey, uss frolick, mtaylor and 3 others
6
The exact Hyde Windlass/ Capstan arrangement was housed in the fore turret of the Whaleback steamship Frank Rockefeller built in 1896, now the museum ship SS Meteor. The worm geared steam driven windlass still exists but the capstan that sat atop the turret was removed, probably around 1905 when Great Lakes steamships changed from hemp to steel wire mooring lines.
Fortunately, I have a copy of the Hyde drawing for the capstan / windlass. Send me a PM with your address and I’ll send you a copy.
Roger
Joe,
Please forgive me if you already know this but the Civil War mortar schooners with dimensional data, build location and date are listed in Paul Silverstone’s Warships of the Civil War Navies. There are a number of two masted coasting schooners described in Chapelle’s National Watercraft Collection. To build a plausible model your modeler could to try to select a vessel from the collection that has been documented that best matches the characteristics listed in Silverstone.
I noticed that one of the mortar vessels was built at Mystic, CT. There is a paper in the Internet by Maynard Bray listing drawings held at the Seaport.
Roger
The Sherline also has a hollow spindle, so with the right chuck you can incrementally turn very long pieces.
Roger
- Don Quixote and Canute
2
Yes, that’s right, I like to think that I have built my present effort at least threw times!
Roger
- Omega1234, Mahuna, thibaultron and 2 others
5
The typical response is often “I wouldn’t have the time or patience to to that.” This totally ignores the research that went into the project, the ability to figure out the ways to fabricate the various parts, or even with a well equipped workshop the skill required to use the tools. Great work!
Roger
I am about to rig my longboat model and while the rigging is simple, I would like to do a good job of it. There has been discussion on the forum about the use of fly tying thread thread and some mention of fly tying tools.
Can anyone who has used fly tying tools comment on which tools they have found to be useful and how they are used?
Thanks,
Roger
Whither goest thou, print magazine?
in Book, Monograph and Magazine reviews and Downloads. Questions and Discussions for Books and Pubs
At the Mystic NRG conference in 2015 we visited the Ships' Plans Department at the Seaport their primary storage medium is paper. They will not sell digitally scanned plans in an effort to discourage piracy.
Roger
