Roger Pellett
NRG Member-
Everything posted by Roger Pellett
Proud owner of a Dremmel drill stand
Roger Pellett replied to DaveBaxt's topic in Modeling tools and Workshop Equipment
I bought my drill press back in the early 70’s. It’s chuck accepts drill bits up to 1/2in dia. and the fractional hp motor that drives it never lacks power. The depth between the centerline of the chuck and column is about 10in. At the time it cost enough that it was a major purchase. Since buying it, I have used it almost daily in my shop. Today, a similar bench top drill press bought from a big box home improvement store costs less than $100. At this price, I cannot understand why anyone would spend money trying to adapt a Dermel tool as a drill press. Roger -
Worx Makerx Tools
Roger Pellett replied to rhephner's topic in Modeling tools and Workshop Equipment
I have a no name air compressor that I bought at Menards, our local big box home improvement store. It retired a home made air system that I rigged up. At approximately $100 I consider it to be a bargain. First, it gives me an unlimited supply of air delivered to my air brush at the correct pressure. Air brushes use more air than you might think. in addition, it gives me a regulated air supply for use around my shop and inflated my wife’s car tire when she arrived home from the grocery store and told me that a women in the parking lot told her that it was flat- she drove home any way. I hate battery powered tools. They always need to be charged when I want to use them and they seem to lose power quickly. -
Dutch yacht by henry x - RESTORATION
Roger Pellett replied to henry x's topic in - Build logs for subjects built 1501 - 1750
I just hope that Henry’s restoration plans include removal of the tacky name plate presently attached to the transom!😏 -
Ok, let me put my oar in the water. I count my self as a serious ship model builder interested in advancing the state of the art. I have been trying to do this my entire adult life, longer than I care to admit. Unfortunately, I have no artistic ability, and struggle to produce the clean work of the masters that post on this site. In spite of this, I do have a collection of models that I am proud of. What I am able to contribute to the mix are good research skills. Over the years I have refined these to the point where I do know what ships being modeled should look like. When I joined this forum, I was disappointed by the time and $$$ that forum members expended on ship model kits that don’t produce models that accurately portray the subject. I continue to be amazed that modelers obsess over details such as the shade of paint when the model’s hull lines produced by the kit are obviously inaccurate. In this case, Henry, has spent his money on something that he thinks that he might enjoy restoring. He has asked for our help. We have pointed out that this is not a priceless antique and never will be. Henry could have spent a lot of money on a poorly engineered kit, become discouraged, and given up. Why not help Henry learn what he can about our craft while he restores this model? For example, to rig the model, he starts with a clean slate. Let’s encourage him to rig it properly. When he finishes, he’ll have a better appreciation of our craft. Maybe he’ll be interested enough to buy the SeaWatch book/plans to build a proper Dutch Yacht. Roger -
Are there any decent clamps?
Roger Pellett replied to bigcreekdad's topic in Modeling tools and Workshop Equipment
Thanks Allen. I barely made it through freshman university chemistry. I was happy to get a “C”. The instructor either felt sorry for me or more likely didn’t want to see me again. I’m certainly not qualified to dig into the details of Glue chemistry. The effect of glue thickness on joint strength is interesting. I tend to instinctively believe that if a little works, more should work better. In the future I’ll be more restrained in my clue application. Roger -
Hide glues used before the advent of PVA glues are water soluble. Another old standby, the “Ambrose” type glues are soluble in acetone. The more modern PVA glues are soluble in alcohol. If this were were mine I would make an effort to remove the gun carriages to thoroughly clean the deck. -
The lighter appears to be rigged with a combination of metal and wooden blocks; metal for the wire rope lifting the plane itself and wooden controlling the boom doing the lifting. The wooden blocks are not those sold by most model ship fitting suppliers. They are internally stropped. The typical blocks that Syren furnishes are the older pattern blocks intended for external rope strops but they do offer laser cut kits that can be assembled into the internally stropped blocks that you require. Bluejacket offers metal blocks. These are castings. There are also posts on this forum that describe making both metal and internally stropped wooden blocks. Do some browsing on the scratch built build logs, 1900 and later. Judging from the workmanship displayed by you so far, you might want to try making your own. Roger
Proxxon Planer DH40 Issue
Roger Pellett replied to ChrisLBren's topic in Modeling tools and Workshop Equipment
This past week, I just finished changing blades on my jointer. I will get the. Old ones resharpened. The cutter head for my Rockwell jointer looks exactly like the one on the Proxxon planer posted above. Two tools drastically simplify the project: First a dial indicator on a homemade stand. By rotating the cutter head by hand the dial indicator tells when the cutting edge of the blade has reached top dead center. Second, something to fix the blade at top dead center while the blade is being changed. In my case I made a simple plywood clamp to immobilize the drive pulley. My jointer is belt driven, so this may not be necessary for equipment with integral motor drives. With the cutter head immobilized at TDC, the old blade is removed, the blade channel is cleaned and the new blade is installed and very lightly clamped with the clamping screws. The dial indicator indexed at zero relative to the outfeed table is then used to adjust the blade until it registers zero at both it’s right and left sides. Some experts recommend setting the blades .001in higher than the outfeed table. If all this is done correctly all blades will be set at the same height and parallel to the outfeed table. I realize my Rockwell jointer is not a Proxxon planer but the principles should be the same. Finally, properly sharpened blades are wickedly sharp. Be Careful! Roger -
Allen, It is my understanding from reading posts here and elsewhere that the bond strength of PVA Glue is dependent on clamping pressure. More is better. If that hat is true, it would seem that some clamping pressure would be desirable. Perhaps readers with a better understanding of glue chemistry than me (none) will weigh in. Roger -
I would not try applying paint on top of tung oil, and I don’t see any reason to do so. First, find out what kind of paint that you intend to use; acrylic, alkyd enamel, etc. Look beyond the brand name to get a technical description of the paint. These paints can be applied to bare wood, but several coats with sanding between will be required to build up a decent finish. If the poor quality of the kit supplied wood requires some sort of “pore filler” make sure that it is compatible with the paint that you intend to use.
From the “Nelson Period”On Boats were often trimmed with a distinctive color as a way to recognize them at a distance. They might be mentioned in logs as the red cutter or the green launch, etc. This does not mean that the entire boat was painted this color, just an identifying strake. As Bob says, the rest of the boat would have been painted white. The instde of the boat was often painted “drab,” a mixture of burnt umber and white, or “lead” grey. “straw” color was permitted for the interior of US Navy Boats in the mid 1800’s. Thwarts and floor boards were left unpainted. Paintings of US Navy Boats in the 1850’s show exteriors painted black. Roger
Adding numbers to yacht sails
Roger Pellett replied to dcicero's topic in Masting, rigging and sails
This is worth what you paid for it as I have never tried it. Glue up silkspan or light paper strips into a rectangle. Tape it to a carrier and run it through a printer to print the number. Cut out the sail and add bolt ropes, reinforcements, etc. I’ll leave it to those far more computer savvy than me to work out the details.- 8 replies
- small boat
- sails
Vasa was built by Dutch shipwrights and her longboat is typical Dutch Ships Boat construction; Flat bottom with side frames (futtocks) arrached to the bottom planking and not attached to the floor timbers. These boats are also accurately shown on many Van de Velde drawings. Interestingly, the structural details for these Dutch built boats are exactly the same as those for the American Revolutionary Gundalow Philadelphia. Although, the sides of Vasa’s Longboat were lapstrake, Philadelphia’s are carvel. Philadelphia and her sister gundalows were built in an area originally settled by Dutch colonists. The shape of Vasa’s boat is also similar to Dutch inshore Craft; wide, shallow, with a blunt scow shaped bow, narrower stern. Although by no means technical draughts, the boats towed by ships shown on the Anthony Roll are more like the that Steven has modeled. Roger
- 740 replies
- Tudor
- restoration
(and 4 more)
I have decided to build a steam box.
Roger Pellett replied to Osmosis's topic in Modeling tools and Workshop Equipment
Perfect! -
Why is it that when we want to buy something it is desirable and scarce, but when we try to sell it it’s common, defective, junk?
Die Kogge Von Bremen by kentyler
Roger Pellett replied to kentyler's topic in - Subjects built Up to and including 1500 AD
Accurately deducting planking thickness is not as simple as it might appear. You have to consider the angle at which the planking crosses a station line. For my last model I made a table of offsets from a lines drawing, entered this into an Exel spreadsheet, along with the required angle for each offset data point. I then multiplied the planking thickness by the sine of the angle and subtracted the result from the offset. It was then necessary to replot and fair all the data points. My advice to you; don’t bother! The lines that you have, were developed from reassembled wreckage, so they are an interpretation of what she once looked like. When completed you will still have an accurate representation of a Cog. Roger -
In 1950, my mother took me to the auditorium in O’Neils Department Store in Akron, Ohio to see a traveling exhibit of model ships. These models, built by a renown builder named August Crabtree are now a Crown Jewel in the Collection of the Mariners Museum in Newport News, Virginia. That experience and the presence of models at home built my father convinced me that I wanted to build model ships. I have been trying to do so ever since. As soon as I graduated from college, I started to amass a collection of tools. As a newly minted USNR Ensign, one of the few things that I owned to be shipped to my duty station was my toolbox. I still have and use many of these tools. Over the intervening years, I have gradually outfitted what I consider to be a first class workshop without stress to personal finances. To the contrary, these tools have paid for themselves several times over completing dozens of projects unrelated to ship modeling. I should add that I live in a region where homes with space for a workshop are the norm. Complimenting my tool collection is a collection of books that I began buying in the 1960’s. I consider these to also be essential to the building of quality models. My point is that $1700 will buy a lot of tools and books. The quality of many of the completed kits built by members of this forum is astonishing! I can only marvel at the talents and skills that I lack that went into building these, but in the end they are still kits. If your circumstances allow, spend your money building a proper workshop and library, and build something unique from scratch.
I’m assuming that you’re referring to the typical cast metal parts supplied with kits. If so, I have been recently been painting cast metal soldiers. The ones that I like were made by a company now out of business so I buy them on EBay and have no control over their date of manufacture. This means that some are lead alloy white metal and some lead free pewter. I have had good results with Tamiya white primer. It is usually available at our local Hobby Lobby and also on Amazon. It comes in a spray can, and covers with light coats that don’t hide detail. It is compatible with acrylic model paints. Roger
The lines drawing presents the shape of the hull in three two dimensional views; a half breadth (top view), sheer (side view), and body plan (end view). Each view shows a set of curves arrayed like contours on a topographical map. The half breadth shows waterlines, lines parallel to the vessel’s waterplane. The sheer shows buttocks, lines parallel to the vessel’s centerline. The body plan shows sections cut through the hull perpendicular to the vessel’s centerline. Each view shows only one set of curves. The other two appear in the view as straight lines. For example, the half breadth shows waterlines as curves; the buttocks and sections appear as straight lines. Although these three sets of curves adequately define hull shape, naval architects will often plot a set of diagonals as a final check to ensure a fair hull; a smooth shape without lumps, kinks, or other discontinuities. These diagonals show up in the body plan (end view) as straight lines radiating diagonally downward from the centerline. They often show up as curves on the half breadth. In your case, the draftsman has flipped them over to the unused side of the half breadth to avoid confusion with the waterlines. If I correctly understand your construction scheme, you intend to use the existing drawings to carve a plug from laminated lifts. The shape of these lifts should be derived from the waterlines. The angle of the bow and stern can be determined from the sheer view. You will then need templates to guide your carving. These are copied from the body plan sections. That’s all that you need to carve your plug. In carving your hull you will ensure a fair hull by eyeball. The diagonals can be ignored. Roger -
Where can I get TINY letters for my ship?
Roger Pellett replied to Brenticus's topic in Plastic model kits
There was an article several years ago in the Nautical Research Journal about using the Cricut foe ship modeling applications.
