Seventynet
Everything posted by Seventynet
  1. Greetings shipmates, thanks for looking in. I'm getting closer! Lots of fiddly bits: transom boom holders, chainplates, posts, channels and boarding ladders, only some of which have been installed. Unassembled catheads Jib outhaul block: Carronade carriage assembly line: Carronade factory: Trunion cap jig: Eye-bolt jig: Uninstalled carronade: Rudder works: Bowsprit assembly: Current state of progress:
  2. Gorgeous Don! Good to see you back in the shipyard. Ian
  3. Derek, this is beautiful work. I am not sure what deliberate mistake you are referring to. I am not at this stage yet but it appears to me that your upper counter is less prominent than it might otherwise be - you know the place where the "Victory" is written? Or is it just the camera angle?
  4. Good job B.E.! I think it looks great. I’m sure you will feel a tremendous sense of accomplishment when you’re done. Keep the faith. ian
  5. Well this thing has been gathering moss hasn’t it! Hi Ronald. It’s been a while but I think I used masking tape, cut to measure after laying it over the bulkhead edges and then spray painted (can) the interior. I sort of wonder why I would even have done that but I may have completed the fairing process beforehand. thanks for looking in. Ian
  6. It’s hard to turn away once you are hooked. Best Regards, Ian
  7. Beautiful work Robert and ingenious solutions, methods that I am sure to employ myself. Ian
  8. Very nice job! The wood type really seems to suit the type and age of the boat. What kind of wood is that? regards, Ian
  9. Thanks a lot Jim. I used a flat black acrylic. I think, but not positive it is what Chuck originally recommended. However I painted over it with satin wipe on poly which makes it shine a bit more than I like. Regards, Ian
  10. Thanks B.E., honestly your build is absolutely beautiful and there has been more than one occasion where I had wished I was behind you so that I could have followed your lead. I have said to myself many times that I have to build another Cheerful so that I can do a better job next time. Al thanks for the compliment. I know your work and you will do a splendid job on it. You will also enjoy it as much as I do. Chuck has put together a beauty. Ian
  11. Thanks for the encouragement Kurt and Don. I really would like to see more of your build Kurt. Don I wonder what you’ve been cooking up in that shipyard of yours? Any undocumented projects you’ve been holding back? I cleared the Cheerful deck for action this morning . It feels good to be back at it. Best Regards, Ian
  12. Nice work B.E. I actually miss the hull planking part. It reminds me how much I liked working with boxwood. Cheers
  13. Thanks so much for the (overly) kind words and for hitting the like button. Jim: Thanks for the encouragement. I am intrigued by the picture of your yellow cedar deck. Where can I find your beautiful model? Antony: Thank you. I have come up with a pretty reliable approach to removing planks by first treating the area with rubbing alcohol and then heating up the area with a heat gun (after the fumes have cleared!). The planks come off with ease. And clean up is easier too. Much appreciated Joe. I found your Atlantis restoration project the other day. Wow is all I can say! Thanks so much for following Niles. Love your work! Regards, Ian
  14. Beautiful model and exceptional work Joe. It is going to be hard to part with this. I am sure the client must be happy! regards, ian
  15. Decking 1. I used Alaskan yellow cedar for the deck. I’d also used it for the deck on my Brazzera. It is perfect for this application. 2. Decking layout. I would do it slightly different next time. I would let some of the bow planks close to the center plank taper so that I could end up with all of the planks except the center plank being the same width at the bow. I could have been more careful to achieve the same objective at the stern as well. This is where I am at today. It may be a few weeks before I have any updates. I hope these are of some interest and value to those starting out. Best Regards, Ian
  16. Deck Structures I bought and assembled all of Chuck’s kits. They are well worth it. Even the windlass which I built but can only conclude was eaten by my shop vac and dumped in the garbage after my semi-annual filter clean. Sigh, I guess I’ll have to order another one from Chuck.
