Everything posted by Chuck
both. I will use a metal straight edge and a sharp #11 blade to cut most of it off close to my line. Do this with several passes of the blade. Dont try and cut th excess off in one pass. Then I sand the remaining bit off to my line carefully with a sanding stick or emory board. I use one of those wide nail files. They are 180 grit on one side and 100 grit on the other.
I took a stab at making some videos that show how I plank the bow of any ship model. Specifically how to taper and edge bend a strip so that it lays flat against the bulkheads. This is basically how I plank every hull at the bow. I shot these videos at 720 HD quality so rather than string together the four videos into one long 20 minute session, I kept them individual. They take forever to upload to you tube when they are 20 minutes long. Literally hours. So these are four short 5 minute videos instead. A lot easier to upload and process. I will edit this post and add the other 3 as I finish processing them for upload. Basically each part is split into an intro.....then tapering.....then edge bending.....and test fitting on the hull. Let me know if you have any questions. Keep in mind its weird making these when I am alone in my shop and basically talking to myself. I had to reach around the tripod i order to get to the model and I was hitting it and had to start over many times....not my cup of tea all this video stuff!!!! 😂 Let me know if you think its worth the time as it is a real pain in the biscuit . But I will continue if you guys get anything out of it. I also must have had the camera too close to the hull so the first two videos are not as crisp as the others. Live and learn.....next time it will be better but I tried to get as close to the hull as possible so you could see everything. The videos are posted here.....in the discussion about chapter two.
- 1,784 replies
- winchelsea
- Syren Ship Model Company
I took a stab at making some videos that show how I plank the bow of any ship model. Specifically how to taper and edge bend a strip so that it lays flat against the bulkheads. This is basically how I plank every hull at the bow. I shot these videos at 720 HD quality so rather than string together the four videos into one long 20 minute session, I kept them individual. They take forever to upload to you tube when they are 20 minutes long. Literally hours. So these are four short 5 minute videos instead. A lot easier to upload and process. I will edit this post and add the other 3 as I finish processing them for upload. Basically each part is split into an intro.....then tapering.....then edge bending.....and test fitting on the hull. Let me know if you have any questions. Keep in mind its weird making these when I am alone in my shop and basically talking to myself. I had to reach around the tripod i order to get to the model and I was hitting it and had to start over many times....not my cup of tea all this video stuff!!!! 😂 Let me know if you think its worth the time as it is a real pain in the biscuit . But I will continue if you guys get anything out of it. I also must have had the camera too close to teh hull so the first two videos are not as crisp as the others. Live and learn.....next time it will be better but I tried to get as close to the hull as possible so you could see everything. Planking the bow of HMS Winchelsea....part one - Intro to tapering PART TWO.....Tapering your plank... PART THREE....Edge bending with heat PART FOUR.....Testing the plank on the model
let us know what you find out....
Welcome to the forum. It probably is Chinese....what brand of kit is it because we have a ban on some Chinese kits because they are pirated from legitimate manufacturers. A good place to start is here....click on this topic below. If you have any questions about it please contact me and I can tell you if it is in fact a banned or pirated kit. We do not allow these to be built on our site for obvious reasons. If its the one I am thinking of (huasong) which is only about 20" long then you will have hard time building it. The kit itself is not a copy BUT......Its an awful kit and although it is cheap, you will get very frustrated trying to build it. This particular company does have a pirated copy of two other smaller subjects....a Harvey kit and an albatross kit. And because of this they are banned from our site. These were copied from long standing MFGs. Better to start with a smaller and simpler subject from a quality MFG rather than a 3 decker 100 gun ship in a very small scale from cheap Chinese site. Not really recommended for a first time model builder. Chuck
That center hold-down is good....just remember that everyone using yellow cedar....you will need to place a scrap on top of the strip when you clamp the ends. The cedar is soft and will dent without some protection under the clamps. Otherwise this is what I do using a travel iron for heat.
- 607 replies
- winchelsea
Really looking great Bob......you have one clean and precise longboat there!!!!
- 87 replies
- medway longboat
That is a term used to signify a section of the lower hull for planking. For example.....the hull has 25 strakes from the wales to the keel. To make it more manageable, these were divided into four sections referred to as "belts" of planking. It is far better to concentrate on each smaller belt as one task to do than an entire hull. The winnie has for such belts of planking below the wales and each should be treated as its own small project. The goal being to complete one belt at a time......something to be celebrated by a pint or a shot at the end of the day once you finish one. I am currently working on my second belt of planking on the starboard side of the hull......almost ready for that Rolling Rock!!!!!
- 607 replies
- winchelsea
You wont find holly anywhere. Boxwood will be tough too. But Cherry is easy enough to find. You will find many places for Cherry in strip and sheet form. Anyway...this guy in Europe supposedly sells Boxwood and pear strips. But his website is kind of poor. Folks speak highly of them though. https://www.arkowood-lossburg.de/ Remember that the boxwood strips from model expo are NOT boxwood. They are cheap died soft wood veneer cut into strips. Its also bright yellow.
HMS Winchelsea (1764) 32 gun frigate GROUP PROJECT INFO
Chuck replied to Chuck's topic in Group Projects on Model Ship World
Mike...you can wait until you are ready to set up a build log. Also download the materials list for each chapter which will detail all the wood sizes you will need. It’s all listed. But hurry up and finish that model do you can join us.
