Garward
Everything posted by Garward
  1. Augie, tell please, of what threads (or from ropes - on a photo it is badly visible) the rigging is made?
  2. Yes, to such experts sometimes it is necessary to apply preventive measures.
  3. Here still link http://modelisme-naval-bois.lebonforum.com/t1044-hms-victory-par-j-c-steckmeyer
  4. I agree, without knowing the correct methods and receptions of performance of any work, anything good you won't make . Dr Nazarenko well taught you!
  5. The chemist - he also is the chemist, slightly that - organic solvents, acids...
  6. This photo - an example of application of a bituminous varnish of Maimeri 710 divorced with white spirit. All model, including a rigging becomes covered by it. Wait a little, I will look, somewhere I had links to Victory constructions on other sites.
  7. I wrote that will be about what to talk ! More safely forward, Sjors, you will find more many interesting Corel in drawings .
  8. Look at the last pages of the report on which I gave the reference.
  9. If to put a varnish on details in such condition as they are shown on a photo, the fleecy surface will turn out: the varnish "will lift" the insufficiently well polished fibers on a wood surface.
  10. As information: construction of the similar HMS Victory model from Caldercraft http://forum.modelsworld.ru/topic9206.html
  11. Very well, will be about what to talk, without waiting San Ildefonso!
  12. To put it briefly, let's build models, colleagues modellers!
  13. Hi, ReD BuLL, welcome to Kiev! Certainly, the big detail should be heated previously separately from small if to heat them together, the small detail can will melt earlier, than big will heat up to soldering temperature.
  14. Acetone can be used generally before drawing on a detail of a finishing covering. It can spoil this covering. This restriction for acetone application.
  15. When it is necessary to solder two details, one of which much more another (on weight), sometimes it is necessary to warm up separately in addition this detail that more fine detail thus didn't overheat.
  16. Ahoy J.Pett When using СA it is more best not to make mistakes as it is difficult to eliminate them. I spoiled not one detail while learned to use this glue . Usually, if it is necessary to disconnect incorrectly pasted СA a detail, I on connection several times smear acetone, it dissolves СA.
  17. Hi, Bob! Unfortunately, I have no own experience of work with this nut, but I agree that it needs to be darkened much more better to see details.
  18. Cherry wood well is suitable for a decor and finishing of details, for a deck flooring it too dark.
  19. Especially I like the slow (two-minute) СА glue PT 30 shown on a photo for a tree.
