CDW
Everything posted by CDW
  1. A dry fit of the bomb bay doors before moving on to another step. Will leave the doors off until the end. One less thing to work around when masking and painting the overall aircraft, and one less thing to knock off or break.
  2. Beautiful finished model Yves. The painting brings the model alive.
  3. Mike, the applicability of acrylic glue is going to vary on particular jobs depending on the specific parts (as you referenced) as well as the experience the individual has in using acrylic glue. Like a lot of other things, we get better at it with time and practice. One thing for sure, you don't use it exactly the same as you would use CA, as with CA, you're trying to use as little of it as possible to avoid a big mess. With acrylic glue, you can use more of it and clean it all up later with a wet paint brush before the glue completely dries. I find acrylic glue is particularly well suited for ship railings. Sometimes the difficulty comes from trying to use too large of a section of railing at a time. I often cut my railings into smaller sections and find it makes working with it much easier. I cut the railing to the length I want at a vertical post, then use a smidgen of overlap of the rails on the subsequent vertical post to mate them together. When using it, don't be afraid to use a larger drop of it where the photo etch is to be attached as it will be very easy to clean up later. A good way to get practice is to use scrap pieces of railing and just glue them down on a piece of sheet styrene plastic. The little blobs of glue you put down will be enough to hold the railing in a vertical position until it starts to get tacky and once tacky use your wet paint brush to clean up the excess glue around your posts.
  4. Try here. You'll need to email the seller. http://www.gatorsmask.com/gatorglueorder1.html
  5. Oh wow...didn't see this. What a disappointment. Hope Hasegawa comes through for you with flying colors.
  6. Your Hasegawa Dauntless will look great right out of the box. Can't beat Hasegawa and Tamiya models for a positive out of the box experience. Looking forward to your progress. Love the tri color scheme as well.
  7. The Avenger model comes with a set of bi-fold bomb bay doors. The doors are enhanced with a fully photo etch lined inner door detail provided stock in the kit. Often, modelers ask what type of glue to use for photo etch. While CA glue has it's place in the scheme of things, my personal favorite most of the time is acrylic glue. Why? *The slower drying time gives plenty of latitude for positioning the part without it inadvertently adhering too soon. *It dries completely clear with no fogging. *It dries very thin without a buildup. *It cleans up with water. *It's a more flexible bond, not brittle like CA. I can easily clean up any excess glue with a paint brush wetted with water to eliminate any sign of the glue on the finished model. Another question modelers often ask, what is the best primer for photo etch? My choice is Mr Metal Primer. *It is a solvent based primer, and completely transparent. *It adheres very well to photo etch and mostly eliminates the chance of the finished paint color peeling away from the photo etch. *It can be brushed onto delicate photo etch parts and is self leveling. *Dries quickly. *Since it has no color pigments, it will not obliterate the fine surface details that photo etch is meant to provide. The kit provides pre shaped bomb bay hinges for the doors to attach in a bi-fold fashion.
  8. The Mossie is shaping up very nicely OC. The photo etch inside the cockpit is paying dividends.
  9. Hi Denis Just found your build log for the Agilis. Wanted to follow along to learn a thing or three. There are more than a few wooden ship models in my stash, but it's outside the sphere of my comfort zone. I'm a neophyte wood ship modeler. Maybe following some guys who are experts such as you and JCT will give me the confidence boost I need to start one of my own.
  10. As others have said, the order to follow is: gloss coat where the decal is to be placed microset under the decal microsol over top of the decal flat clear coat over decal when it's dry I've run into the same issue with model master flat clear - it dries milky. Tamiya flay clear is my go-to for that purpose. As you said, never over brush. Let the clear settle itself over the area where applied. Otherwise, you will leave brush marks. PS: if you have any Future, it works perfectly as your gloss clear coat under decals and it works perfectly when brushed on.
  11. It's well known in Florida, bull sharks are man eaters. Last time I checked, they account for the majority of shark attacks in Fla. They swim far upstream in rivers as well, well beyond brackish water.
  12. There are a lot of critters to ruin your swimming in Fla lakes. Water Moccasins, gators, parasites, etc. As a Fla native, I don't swim in lakes but we used to do it a lot as kids. The water was cleaner back then before the massive population increase and urbanization which brought a lot of pollutants to our lakes through rainwater runoff, not the least of which is fertilizer and heavy metals (from automobiles).
  13. Not enough natural light in my room. It's definitely navy blue which is a very dark blue. When you look at the photo of the gator, you'll see water lilies. Ahead of the lilies are floating roots called tussocks. The gators root up the water lilies and the roots float to the surface of the water where the gators lay out to catch sun (reptiles do that) and to lay/hatch their eggs. Often, you'll see baby gators 8" long sunning themselves on the tussock beds.
  14. My brother pulled this big spec out from the gator's lair yesterday. He's fishing at Lake Kissimmee in Fla
  15. Glad there is something here that helps just a bit. The Avenger was the largest single engine aircraft of WW2.
  16. With this aircraft and many other WW2 US aircraft, you want the inner canopy frame colored zinc chromate. To achieve this, the canopy is first painted (on the outside) with zinc chromate. After the z.c. is dry, then a coat of the exterior color is painted on the canopy frame, in this case navy blue. Twice I glued on and subsequently knocked off the photo etched turret gun sight. Finally decided to wait until just before the turret glass was installed to glue it on for the last time. I have finally arrived at the time to join the fuselage halves.
  17. Wow, the Mercedes weighed over 5,000 pounds. What a beast! If a guy could afford a car like that, he would not have been concerned at all for the cost of poor fuel economy. Maybe more concerned about range, but it probably had a huge fuel tank. Look at the size of the differential on that car...it's huge. 100+ MPH was WAY faster than those tires could be trusted I'll bet.
  18. Best way I've found is to use a tooth pick/cocktail stick to pick at an edge and make it rise up just a bit so you can grab it with tweezers. The wood stick won't scratch the clear plastic. Sometimes I just carefully use my tweezers which have a pointy end to lift the mask, but that's more risky of scratching the plastic.
  19. Brother, if you ever wanted to realize what dark looks like, live on top of an isolated mountain in West Virginia like my wife and I did in the early 80's. It was one of those places where you literally could not see your hand directly in front of your face on many nights. Made the mistake of staying at my father-in-law's house too late one night and when I got to the gravel road that led up the mountain to our house, realized my truck could not make the climb, too much ice even with chains on all four of my 4x4. No flashlight, hiked a mile uphill in total darkness to our house. Ridiculous is what that was.
  20. Thanks Denis. I am so ready to close up the fuselage and finish this beast. The tri-color US Navy scheme should prove interesting to do.
  21. Yes, i am using Vallejo chromate green. Yes on the tape, there's just way more than $6 worth of taping on this model, and that's approximately the cost of the masking set if you can find one. I searched hi and low for this set. PS: for some odd reason, the Vallejo chromate green is not easy to find on hobby shop shelves. You can make your own chromate green by mixing Tamiya green with yellow. In hindsight, I would go with Tamiya if I had to do it all over again.
  22. Just an hour or so after I posted the last photos, the canopy mask set arrived in the mail from England. Because of the complexity of the masking required for this model, the pre cut masking set is a huge benefit for a small cost.
  23. There's a good sized window on the port side and a door on the starboard side at the bombardier's station that will enable a limited view. Once the turret frame is painted, there will be a limited view from that direction. Will decide whether to use the open canopy at the pilot's area or closed. Leaning toward open right now. Bomb bay doors will be left open.
