CDW
Everything posted by CDW
  1. My brother pulled this big spec out from the gator's lair yesterday. He's fishing at Lake Kissimmee in Fla
  2. Glad there is something here that helps just a bit. The Avenger was the largest single engine aircraft of WW2.
  3. With this aircraft and many other WW2 US aircraft, you want the inner canopy frame colored zinc chromate. To achieve this, the canopy is first painted (on the outside) with zinc chromate. After the z.c. is dry, then a coat of the exterior color is painted on the canopy frame, in this case navy blue. Twice I glued on and subsequently knocked off the photo etched turret gun sight. Finally decided to wait until just before the turret glass was installed to glue it on for the last time. I have finally arrived at the time to join the fuselage halves.
  4. Wow, the Mercedes weighed over 5,000 pounds. What a beast! If a guy could afford a car like that, he would not have been concerned at all for the cost of poor fuel economy. Maybe more concerned about range, but it probably had a huge fuel tank. Look at the size of the differential on that car...it's huge. 100+ MPH was WAY faster than those tires could be trusted I'll bet.
  5. Best way I've found is to use a tooth pick/cocktail stick to pick at an edge and make it rise up just a bit so you can grab it with tweezers. The wood stick won't scratch the clear plastic. Sometimes I just carefully use my tweezers which have a pointy end to lift the mask, but that's more risky of scratching the plastic.
  6. Brother, if you ever wanted to realize what dark looks like, live on top of an isolated mountain in West Virginia like my wife and I did in the early 80's. It was one of those places where you literally could not see your hand directly in front of your face on many nights. Made the mistake of staying at my father-in-law's house too late one night and when I got to the gravel road that led up the mountain to our house, realized my truck could not make the climb, too much ice even with chains on all four of my 4x4. No flashlight, hiked a mile uphill in total darkness to our house. Ridiculous is what that was.
  7. Thanks Denis. I am so ready to close up the fuselage and finish this beast. The tri-color US Navy scheme should prove interesting to do.
  8. Yes, i am using Vallejo chromate green. Yes on the tape, there's just way more than $6 worth of taping on this model, and that's approximately the cost of the masking set if you can find one. I searched hi and low for this set. PS: for some odd reason, the Vallejo chromate green is not easy to find on hobby shop shelves. You can make your own chromate green by mixing Tamiya green with yellow. In hindsight, I would go with Tamiya if I had to do it all over again.
  9. Just an hour or so after I posted the last photos, the canopy mask set arrived in the mail from England. Because of the complexity of the masking required for this model, the pre cut masking set is a huge benefit for a small cost.
  10. There's a good sized window on the port side and a door on the starboard side at the bombardier's station that will enable a limited view. Once the turret frame is painted, there will be a limited view from that direction. Will decide whether to use the open canopy at the pilot's area or closed. Leaning toward open right now. Bomb bay doors will be left open.
  11. The Avenger crew consisted of three men. A bombardier-radioman, turret gunner, and the pilot. The bombardier-radioman sat in a bench seat underneath the turret gun, where a .30 caliber machine gun was mounted pointed to the rear to serve as a ventral defensive armament. The gun turret was electric powered, the gunner having his own seat and a .50 caliber machine gun to help fend off enemy fighters. In order to join and cement the fuselage halves, the turret glass must be installed first as it will not fit after the fuselage halves are joined. Consequently, this will cause a delay as the canopy mask set is inbound from a vendor in England. Because this model was originally produced in 2005, very few aftermarket items can be found for it now. If you find one you're almost forced to buy it even if it must come from across the ocean. I've been checking the fit of the internal details to the fuselage halves as I'm progressing, trying to avoid any unexpected fit issues when the halves go together. So far so good, as everything seems to be very well engineered and fits well.
  12. Yes, I did in the early 2000's, owned several different helicopters trying to master flight. 99% of the time, there are no "minor" RC helicopter crashes. The slightest rotor blade ground strike does major damage and misalignment of parts that take hours to replace and adjust. Very expensive to repair as well. It's so easy to become disoriented as control becomes completely different when tail out or tail in. Generally, orientation is tail in, as if one were sitting in the cockpit. When the helicopter turns and heads toward you (tail out), control is then reversed so to speak as right becomes left and left becomes right. In addition, it's hard to tell how the tail is oriented once the helicopter gets a couple hundred feet out. Last, an RC model helicopter can hurt you or spectators badly, even death. Those blades turn so fast with so much mass, they can cut you open like a buzz saw.
  13. B-25 models in general are notorious tail sitters. Remember the company that used to specialize in nose weights made specifically for certain models? I can't recall the company name, but they made weights in the correct shape to fit perfectly in the nose of your model. I've wondered if they were still in business but I doubt it. Things like that come and go.
  14. Guns are very well done. Holy mackerel, that's a HUGE dime!
  15. Hi Mike I just caught up with your log. Your work looks great! Looking forward to following your progress in the future.
  16. In the middle of my hobby fun, chores around the house have gone front and center. I have some things to take care of that are due, so must spend some days finishing those up before I can return to this big bird. Meanwhile, I'm waiting for a set of canopy masks to arrive from England and paint from New Hampshire. As MacArthur said, I shall return.
  17. Your Wulfhound is looking beautiful Denis. It's going to be a very unique piece when you're through with it. Keep up the great work.
  18. Don't ever assume you're good with a hard drive because they can fail without any notice whatsoever. I learned that lesson the hard way when I lost everything stored on two separate hard drives. 1.5 terabytes in total. I lost pictures, documents and plans I had stored for many years. Only way to give yourself some confidence is to have redundant backup systems including the cloud. Costs money so that's something to keep in mind.
  19. Considering how many warbirds Kermit Weeks owns, it's amazing his recall of all the control functions in the Mossie cockpit. And when you watch his videos, you'll notice he has this recall of every aircraft he owns which tells me he gets in a hella lot of flying time as well has having a great memory. These aircraft were fairly complex and each different type had their own peculiarities.
  20. My buddy was at a blues festival just a couple of months ago here in Florida, and ran across Kermit Weeks who was attending the same festival. He's really a cool, regular guy who is lucky enough to own and fly literally dozens of warbirds including the Mossie in these videos.
  21. OC What color are you going to use for the cockpit area. Do all British WW2 aircraft share the same cockpit color? For US aircraft, it's almost universally zinc chromate green. You can get that color by mixing Tamiya's green and lemon yellow, but they (Tamiya) don't sell a premixed color for zinc chromate. For my current project, I've been using Vallejo Model Air zinc chromate, but recently found out I had bought the only bottle of it in town. If I had known it was that scarce, I would have mixed my own with Tamiya paints. I had to order some Vallejo from another state and am waiting for it to arrive.
