Posts posted by CDW
She's coming along beautifully. Take your time and keep doing things the way you're doing it.
Scott
I've never tried it myself, but my guess is that most all the Warspite photo etch sets will work with the Trumpeter kit. There may be certain pieces included with the various sets that won't work without some modification, but most parts are generic enough you should not have a problem, like ladders, armament, railings, etc.
If you buy a wooden deck, make sure that it is specific to your Trumpeter kit as those are designed specifically for the particular kit.
Very nice. I really like this model, and it will fit very well in a display alongside the Mikasa.
- Canute, Captain Slog, CaptainSteve and 1 other
4
Popeye's analogy is an saying I used to hear my old boss, a US Army Major General, say all the time when we had big, complicated tasks to take on - "just eat this elephant one bite at a time."
- BLACK VIKING, EJ_L and Elijah
3
Who or what company actually produces the Scharnhorst model? It looks like a Woody Joe kit to me. The 1:250 Yamato and Akagi kits sold by DeAgostini, which sells in installments, are actually Woody Joe kits. But I have not seen the 1:200 Scharnhorst model in any other form except Partsworks. Maybe it's an exclusive done for Partsworks?
I thought I would use the Tamiya color, NATO Black, to paint the hull. I like it because it has a hint of white in it that tones it down. However, once I tested the paint on some scrap, found it dries looking very "chalky" and I don't like it. I guess I will end up using Tamiya gloss black and mix in some white to get the tone I want. Everything will end up getting dull coat clear once all hull painting is done.
- Old Collingwood, mtaylor, yvesvidal and 2 others
5
The Pontos photo etch is quite remarkable and arguably the best in the business. If there is anything else out there (photo etch) that's better, I would like to know what it is and where to buy it so I can get me some.
Here, the otherwise barren stock plastic pieces are transformed by the Pontos photo etch magic.
- cog, Old Collingwood, Piet and 11 others
14
I had an almost identical problem as RMC described using Opera, just after the recent site update. I could not add any text to a post.
In Opera settings, I found a box unchecked that was evidently the cause of the problem. Once I "checked" that box, everything went back to normal. How or why the box got unchecked after the site update, I cannot explain. Everything was working fine, then all of a sudden it wasn't.
Anyway, in Opera, the box that needs to be checked is: "Enable auto-filling of webpages". If that box is not checked (in Opera), you will not be able to add text.
I mis spoke saying, all gray. It's (the alternative color) actually as you said, gray topside and oxide red below WL.
There is a lot of detail that must be attached to the hull. I am thinking it may be easier and more practical to paint a lot of those details before attaching to the hull, such as the doors on the gun ports.
These little hand hold pieces could easily be knocked off and lost during the construction, painting, and detailing of the hull. To help prevent that, used some scrap styrofoam and cut a small channel in it, then taped it in place over the small details. That should keep everything in place while the rest of the photo etch details are added before painting.
Then, I need to decide how I am going to paint this model. It seems the Mikasa hull was originally painted black above the water line, red oxide below the WL, light gray superstructure, black funnels with light gray stripes. In other renditions of the model, I have seen it painted all gray. My only reference book states the colors formerly mentioned, so I think I will go with that VS the all gray. All gray seems rather dull to me and as long as there is a more colorful option that's authentic, I would rather go with that.
- Ryland Craze, yvesvidal, cog and 10 others
13
1/16" sounds like such a small strip of leather for the straps. But once those finished straps are attached to the boat davits, it's just right. Beautiful work.
- xken, Canute and CaptainSteve
3
To an old Marine, "adapt and overcome", comes to mind as well.
- popeye the sailor, mtaylor, Canute and 2 others
5
I might have solved my problems of breaking micro drill bits so often while using my pin vise. It's my belief that half the problem comes from unwanted lateral movement caused by hand drilling and that ends up breaking the bits. The other half (at least half) is caused by using cheap, hobby grade bits. While I haven't yet locally sourced industrial grade bits, I have found a solution for keeping a steady, straight drill bit while drilling.
I am now using a little hand held cordless screw driver that accepts 1/4" quick change bits. Then, I found a micro drill chuck with a 1/4" quick change shank. Found mine at Amazon.
Now, I am breaking bits far less often, drilling small holes with much less effort, and far faster.
There are quite a few hand hold locations to drill out on the Mikasa hull.The Pontos set includes some nifty little templates for getting all the holes lined up properly for drilling. I'm glad this feature is included as I find it a real pain to get all the holes marked out evenly using just a pencil and ruler.
- Old Collingwood, Captain Slog, Piet and 6 others
9
Yes, much easier on the eyes at 1:200 scale. And with this ship, the larger scale does not create a model too large to fit on display being approximately 27" in length.
- Piet, popeye the sailor, mtaylor and 1 other
4
33 minutes ago, RGL said:
Do a google translate search for mikasa torpedo booms in both Russian and polish. Then look at the images, there are a LOT of amazing modellers in Eastern Europe.
I had no idea I could do a Google translate search or that there is such a thing. Will look into it and explore. Google translate is an app I need to install?
Finding reference material for the Mikasa has proven to be difficult. Most of what's out there are shots of the ship's current state on museum exhibit in Japan. The hull is encased in concrete there.
- Piet, mtaylor, popeye the sailor and 1 other
4
IJN Mikasa by CDW - Wave Models - 1:200 scale - PLASTIC
As you may know, this 1:200 Mikasa kit is produced and sold under at least two labels, Merit, and Wave Models.
Today, I was talking to a hobby shop owner, asking if he could acquire a couple of different items for me. One of those items is the 1:200 Merit USS Hornet aircraft carrier kit.
Sad to say, but he advised his sources tell him that Merit is discontinuing all their warship line, all scales.
As you may know, Merit, Wave, and Trumpeter are all the same thing, just in different boxes. But most ships are sold exclusively under one label. This Mikasa is the only exception I know, being boxed and sold both under the Wave Models label as well as the Merit label.
I'm only saying all this to give you a heads-up just in case you've been contemplating buying the 1:200 Mikasa model. Better get off the fence and do it now, or perhaps it won't be available later. Maybe it will come out (as the rest of the line) under a different label, I don't know. Sometimes better to be safe than sorry. Been there and done that.
