dgbot
Gone, but not forgotten
Everything posted by dgbot
  1. 5 ply Model plywood will work great for bulkheads. It is stable and you can cut it any shape you want. David B
  2. Before you can walk you must learn to crawl. I would advice a Model Ship ways kit beginner level or Midwest Models Pick something you would be interested jn. Tha way you will no get discouraged. You will receive support and advice from the forum. The only way is to jump right in. David B
  3. I would double check your frames. Then check the keel. Something is not right. Unless you let a politician put it together. David B
  4. Nice gratings Toni. Why Costello instead of holly or pear?
  5. Your sloop is turning into an interesting vessel. David B
  6. I hope you were wearing a mask and made sure that honeybunch wont clobber you for making a mess.
  7. Now that you have the planking double check the hull symmetry. David B
  8. Great idea for mass production of pesky piece of material. David B1
  9. Agreed I also had mixed result. David B
  10. At the scale I work at not very often. I am not a fan of maritime measles. I have seen many a model downed by this disease. David B
  11. Nice job. However if you go out on a wooden deck. You will see that the truunel can barely be seen. David B
  12. Should have no problem. However always make up a few test samples and try out the way you want to do it. That way you will know what the end resul will be. DavidB
  13. When using filler it is better I think to prep the deck. That way the deck will not get stained. Once trunnelled you then smooth and scrape the deck and refinish it. David B
  14. Congratulations it looks absolutely decrepid. David
  15. Impressive work. I would agree that you should no install them yet. It would be easy to snag them. David B
