Posts posted by Gerhardvienna
Hi Lou
The jig system for small turned wooden parts is "stolen" from Johann @archjofo. I could not work without a lathe, that is one of the most worthful tools for model building. And useful for some repair works in the houshold too!
The patrol boat was my first attempt in scratchbuilding a boat, I must buy two new contollers to bring her back to the pond!
Regards
Gerhard
34 minutes ago, Torbogdan said:
A very good build so far! Just hitting the "like" button is not enough. Top notch!
Thank you!
There is a lot more to come, just working on the plans for the ship. There are no infos about her, so I will have to adapt other plans for the hull, maybe the plans to the russian Vladimir. But first comes the Cairo, lots of work on her too!
Regards
Gerhard
- mtaylor, Canute and popeye the sailor
3
8 hours ago, Nirvana said:
Tor,I am crying seeing the receipt for gas of yours.
My last fill up cost me 36 dollars for 13.1 gallons.
Now let me try to convert it to Swedish units......
That will be 50 liters and 290 kronor for 87 octane gas.
Now that makes ME cry
We have to pay about € 1,11 for only one liter......................
Regards
Gerhard
- Torbogdan, davyboy, thibaultron and 1 other
4
9 hours ago, lmagna said:
Thank you for the video Gerhard. I will try and find the other videos on YouTube as well.
Lou
Hi Lou
Thank you, here`s my channel :https://www.youtube.com/channel/UCaAcbBL8UapzflEoUs_fgiw
Regards
Gerhard
Hi Nils
She`s alive! RESPECT.
All that wires, figures, boats, etc. so well done!
Regards
Gerhard
- Mirabell61, Omega1234, mtaylor and 1 other
4
Hi Folks
As I wrote in the "What have you done today" thread, I`m working on redrawing the plans for the Lippisch WIG Craft. I use Open Office for the first steps, and later import them into Design Cad 3D Max. This mthod is useful, when the original drawings are not larger than A4 format, larger drawings can not be made with open Office! They must be redrawn directly in the 3D Program, in 2D Mode.
Here comes the video!
Best regards
Gerhard
You stunn me! That are fine boats!
Regards
Gerhard
33 minutes ago, CDW said:
Uh, ohh....photo bucket strikes again with it's 'third party hosting' message.
http://blog.photobucket.com/please-review-latest-changes-photobucket/
http://photobucket.com/pricing
Photo Bucket has changed from a hosting service to "robbery"!
No external links unless the user pays up to € 40,-- per month, or € 400,-- per Year
Regards
Gerhard
- Canute, popeye the sailor, Torbogdan and 1 other
4
Hi Nenad
Unless the hardened colours, what a boat! Great job!
Regards
Gerhard
- Piet, CaptainSteve, Omega1234 and 2 others
5
8 hours ago, popeye the sailor said:
the cannon looks top notch Gerhard
very nice progress indeed!
Not too much progress this week, the heat almost kills me, above 30 degrees here in Vienna
But today i will go to the store, and buy some extra materials for the ship!
Regards
Gerhard
- popeye the sailor, mtaylor and Canute
3
Hi Nenad
Great job!
Regards
Gerhard
- CaptainSteve, Piet, Omega1234 and 1 other
4
- goetzi73, NenadM, johnhoward and 12 others
15
Hi johnhoward
WOW!!
Thank you, this is one of the most worthful photos from the engine(s).
Regards
Gerhard
Hi Pat
Thanks again!
Was not too hard to make the carriage, the wheels were not easy!
Hi Gerald
If you watch the thread from post #178 on, you will see there is no plastic used, everything is made from brass. I used 0,5mm brass sheet, for all metal parts of both carriages. In 1:36 you will need 0,8 mm brass sheet.
Regards
Gerhard
Hi Carl
YES, was a bit easier than I thought.
Now the endcaps for the axels are soldered, and the whole thing is painted flat black. The blackening fluid did not work on the soldered spots, so I had to use paint instead.
I wanted to have the wheels moving, so I had to use baking paper between the endcaps and the wheel, and the same behind the wheels to the carriage.
The finished carriage, beneath that lies the boat carriage
Just the elevator screw missing, this little part will be set to the carriage with 5-min. epoxi. Soldering would not be good at that place, I`m in fear that the whole carriage would break into parts from the heat!
Regards, and thank you all for watching!
Gerhard
On 27.6.2017 at 1:56 AM, BANYAN said:
Very good metal-smithing Gerhard, that small wheel turned out nicely.
cheers
Pat
Hi Pat
Thank you again
And many thanks too for all watching, hit the button, or just enjoying it!
The next step I made were the front wheels, just to make some progress.
I printed 2 sheets of the scaled carriage for each wheel, glued them to 2 mm balsa wood, and cut the spoked part out from one of them. The inner and outer radius was then sanded to correct size.
Then I drilled 3mm holes to the centers of both parts, and glued them together to create the form
Then I cut grooves for the spokes
As next I made a ring from 1mm brass sheet, 2mm high, and layed it into the form. The 1mm was a bit too thick, so I used 0,5mm sheet later!
Some spokes are set to the ring, and a piece of 3mm and 2mm brass tube into the center, the inner 2mm tube is around 1mm longer.
First test wheel, a bit too thick I think!
The carriage with new wheels from 0,5mm sheet, barrel still not mounted
There are still 2 parts missing, the endcaps for the axels. I will make them from 2mm brass tube, 1mm logn, and solder them to the axels.
Regards, and thank you for you interest!
Gerhard
- cog, johnhoward, popeye the sailor and 8 others
11
1 hour ago, johnhoward said:
Great job Gerhard,
Bill just finished the rear wheel for 12 pdr carriage for our USS St. Louis model at 1:24 scale, twice the size of yours, which really shows how tiny your wheel really is. I'll post a photo on the USS St. Louis build sight.
johnhoward
Hi johnhoward
Thank you!
Have seen it in an earlier post in your build thread, wonderful workpiece! Now I`m working on the soldering form for the front wheels, will take some time to solder 14 spokes as shown in all old drawings to center and outer tyre ring.
For the "nonmetric" folks here, the diameter from my rear wheel is 0.2362 inches (6 mm)!
Regards
Gerhard
Hi johnhoward
Thank you! But I have only four of these rings
, because I had no 1,5mm brass tube. But as this wheel is almost invisible, I will go with it.
Regards
Gerhard
- johnhoward, Canute and mtaylor
3
Licorne 1755 by mtaylor - 3/16" scale - French Frigate - from Hahn plans - Version 2.0 - TERMINATED
Great to see you back at work Mark! Nice carriages!
Regards
Gerhard
