bartley
Posts posted by bartley
  1. Completing the lining out
    This is quite a time consuming process but, as Chuck says, this process will be a good check on the process of planking and is good practice for future projects.  It is now complete and as a check I found that it followed Chuck's templates quite well
    BowView.jpg.3370f59e9dd79581af2e822522a9d8bd.jpgBowView.jpg.3370f59e9dd79581af2e822522a9d8bd.jpgBowView.jpg.3370f59e9dd79581af2e822522a9d8bd.jpg
    It might be a while before  I start on the planking as my other hobies need to take prcedence for a couple of weeks.
    John
  2. Lining Out the Hull
    Perhaps not strictly necessary here but it is an good to practice this important part of the planking exercise.  I have started at the stern and here is what it looks like so far:LiningOut.jpg.e3dffb4553f19a8ca7586f9d982b9bca.jpg
    The distortion in the photograph makes it look as if the  planks deviate amidships.  They are in fact quite parallel at this point.  I also found that some of my tick-marks were a bit out so I will adjust them once I am happy with the lining out.
    John
  3. Frames Attached and Fairing Begins:
    The frames are now glued in place
    I then commenced with fairing the frames.  These frames are very delicate (1/16") compared to ships that I have builtin the past so I was a bit tentative.  You can see from this photo that I added some balsa blocks between the frames  as a safety measure:
    However, when I showed this photo to Chuck he advised that I had a way to go and that I needed to keep going until the laser char was removed.  So here is where I am at now:
    John
  4. The transom and installation of the frames:
    The transom needs to be installed perpendicular to the keel.  There is a slot cut into the frame so the "vertical" alignment  is accounted for but to ensure it was perpendicular ro the keel I made this simple jigand clamped the trasome otself to this:
    Time to install the frames there are two types - two in the bow ( G & H)and three in the stern ( 10 , 11& 12) are flat one piece frames.  These are installed onto the baseboard first and the keel dry fitted to these.
    The remaining frames are "double" with a floor piece glued to each frame
    These frames are the each dry-fitted to the keel and the alignment checked.  Each was found to be perpendicular to the baseboard with no adjustment needed
    John
  5. On 6/3/2023 at 10:19 PM, glbarlow said:
    Nice to see you back at it again.
    Thanks Glenn,
    Yes, my other hobbies took up some time plus a commissioned non- ship model.   This looks like and interesting model.  I have never built an upside-down model like this.  Fairing could be a challenge as the frames are only 1/16" wide!
    Regards,
    John
  6. 7 hours ago, Chuck said:
    Excellent start...enjoy the project!!!   Its so good to see another get started.
    Thanks, Chuck.
    It never ceases to amaze me how well designed your models are.  I have just dry fitted all the frames.  Not only to they fit perfectly in the slots but every single one is dead vertical.  I checked with my square!!
    I hope I can maintain this perfection when I finally glue them'
    John
  7. 9 hours ago, Ryland Craze said:
    Nice start.  It is good to see another Medway Longboat being built. Also, do not forget to install the simulated bolts on the keel at the stern.
    Thanks, Ryland.  Yes I have done the bolts fore and aft and both  port and starboard.  I didn't take the right final picture really.
    John
  8. I am starting another of Chuck's builds today and am excited as I have never used this method of construction before.
    The first task is to construct the keel.  There are two versions - one with scarf joints and the other with lap joints I am going to build both but hope to use the one with the lap joints.  Here are the laser cut sheets involved:
    The Scarph version is quite simple:
    The lap joint version is more challenging.  I started by paring away the joint with a sharp blade and then once close the required depth I finished it off with one of these sanding blocks which have sandpaper on the top only and not on the sides
    and the two joints assembled:
    The two versions are shown here:
    The lengths were identical so I concluded that the lap joints were OK.  The parts for the notched keel pieces are nicely etched on the following sheet
    Bolts for the lap joints are simulated with black monofilament:
    These are then trimmed flush with the surface.
    After a coat of poly the completed keel looks like this:
    John
  9. Luggage and final tweaks:
    A few Items of luggage such as a suitcase, a trunk and a hatbox were all constructed in essentially the same way.  A wood frame was constructed and then ech was covered with dark brown Nappa.  Hinges and detail were added an the items placed on the roof rack.
    =SuitcaseBoxS.jpg.21f33b82e0ca8d38ae04e6900ce3e75a.jpg_MG_6779S.jpg.d6bd17b8b9440da5c3600ab1f7e94dc4.jpg_MG_6781S.jpg.4b1eb6842bc930d3be142457f56816af.jpg
    BegimmingTrunkS.jpg.9ade4605505de36b81118e71c85b7b54.jpgTrunkbeginningS.jpg.f1177d204ab6879406d79b632ad03bc1.jpg2022-06-3012-35-04(BRadius8Smoothing4).jpg.31a4d1c1c1e22490fe82f4a742b1b844.jpg
    _MG_6777S.jpg.5acee730f8adac76e9f0e03dd3bea8c0.jpg_MG_6778S.jpg.906f8f9947e650373a02679e4840a3f5.jpgHatboxcoverS.jpg.5f8ed3921b7825499ff4453963c667b8.jpg
    And now the completed model:-
    RearviewB.jpg.991a1467bcba336602e788fd7c1d7941.jpgFrontViewa.jpg.c784b3edb4ced8a2556b25371fdf0290.jpgSideViewb.jpg.dd2290de07e917e3fb32fce8159df070.jpg
    Thanks for all the "likes" and comments during the course of this build.
    John
  10. Attaching The cabin to the chassis:
    Before the chassis is attached the mounting steps need to be constructed and attached.  These have several components all made from 1.5 mm brass tubing:
    Upperstairstraight_MG_6975.jpg.62d964b3f79527650b26a7fdcb5deeeb.jpgLowerstairs_MG_6974.jpg.5f247c6685ce7e7062770d6e37868c2a.jpgCombostairsoothing4).jpg.1b1bf1d4973712678cc5ead1c8a9e0c9.jpg
    The upper (straight part is bent to shape as shown in the last picture.  The lower part is bent into a U shape/  All the parts are drilled with 1 mm holes  so that  they can be held together by the brass plate as shown in the third picture. A step is glued to the loerer part and the whole assembly attached to the under the cabin like this:
    You will also notice a strengthening strap made of 3mm brass strip has been added.  The Idea of this somewhat complex arrangement is that the lower step could be folded up when not in use.
    As yo can see the cabin needs too be mounted upside down in order to attach the chassis.  The method of attaching the simulated leather suspension can be seen here:
    Before the front part of the chassis is attached, the Whippletrees are assembled. For those who do not know what these are they are attached to the draw-bar and are designed to spread the load of the horses.  The method of fabrication is shown below:
    A sheet of 5mm cherry is cut roughly to shape and rounded as shown in the top photo.  A strip of 5mm brass is wound around the enter and two holes drilled in the ends which will take eye-bolts.  Thee whole assemble is painted ice yellow to match the rest of the chassis.
    They can be seen attached to the draw-bar in the following photo
    The harness which ran either side of the rear horses would attach to those eye-bolts.
    So now with the wheels attached and the coach the right way up it looks like this:
  11. On 3/12/2023 at 12:45 PM, CDW said:
    Turning out a magnificent piece of history. I admire your work on it.
    Thanks for your kind words, CDW and others for your likes.  Yes, an interesting period of American History - at least in the case of the Concord coach.  Stage coaches were operated in Australia as well by a company called Cobb & Co which was in fact set up by two Americans.  They were run initially to the goldfields in the 1850's and later between cities and ran well into the early 20th century since our railways were established later than yours.  However, they were of much simpler design than this one. The cabin was simply a straight planked box with no decoration, although they did sport  the Concord suspension system.
    John
  12. Decorations and Embellishments:
    Although these are not in the plans I have seen some pictures of Wells Fargo coaches with scrolls below the side windows and in other places.  I have made these before from brass plate for scrolls on ship models but for some reason I had much more trouble this time.
    Anyway here is the final result:
    Now it is finally time to attach the cabin to the chassis.  This was constructed at the beinning of this project.  As a reminder here it is:
    I have made up four brackets like these to clamp onto the simulated leather straps which constitute the suspension
    So next time the chassis will be attached.
    John
  13. Roof Railings.
    Back to modelling after an extended holiday.
    The front part of the railing was constructed as for the drivers cabin using 2mm Brass rod, bent to shape and silver soldered together using a jig to ensure uniformity
    The rear part of the railing was constructed from 1,5 mm brass rod and 1-hole stanchions again silver soldered together:
    As the construction proceded the framework was tested out on the roof and holes drilled in appropriate places to take the vertical stanchions:
    The assembly was painted black.  My standard method for brass is to use an etch primer and a topcoat of Humbrol Matt Black.
    The final assembly looked like this:
    Finally the whole assembly was attached to the roof and secured with a few drops of CA to the in the holes:
     The next step will be to attach the cabin to the chassis.  I have already prepared the brackets for this step since the cabin needs to be inverted and this could damage the roof rack once it is in place.
    John
  14. The Luggage Rack (completed)
    This has taken me a while to complete due to several distractions (including my tax!)
    So, the cover for the luggage rack (which actually obscures most the good work done earlier)
    Forming the cover starts with cutting a piece of black Nappa approximately 155 X 120 mm
    Staps are then attached to these with 5 mm nails
    Finally some strengthening bars are added
    The buckles were made from 0.5 mm brass wire and then a small piece od f Nappa folded over these so that they could be glued to the back of the straps
    _MG_6964.jpg.ee75b86af1a67fbd986a896d4ead736a.jpg  _MG_6965.jpg.2622de649eefe0f9ec7f0c9d85bd1333.jpg
    This final cover was then folded over the frame constructed in the previous step
    A few bits and pieces such as the blinds became detached during the construction of the luggage raxk so once they are repaired I can proceed with the roof rack
    John
  15. You are quite correct, Blacklab.  Before I retired I was an Industrial Chemist and at that time there were only two manufacturers. So basically there is a lot of 'badge engineering' going on and marketing is the key.  Having said that the companies who purchase the stuff do sometimes adjust the formulation particularly the solvent and the concentration of the actual CA.  So some products may penetrate more into timber or dry a little more quickly but this adds to the cost of course.
    John
  16. The Luggage Rack.
    I actually began construction of this some time ago but needed to wait for some more black nappa in order complete the task.  This  is quite a complex item The first task is to create the luggage rack itself.  This is then covered with brown leather which would have protected the luggage from dust and stones etc.
    First the base frame  on which the luggage rested  is constructed from 2 X 4 mm and 3X 1.5 mm walnut battens:
    This is then covered with brown nappa:
    _MG_6869.jpg.d6243e50817a93444083cc153b4e1e66.jpg_MG_6868.jpg.7af3c56db4da038a37e1150ca276f763.jpg
    Now another framework is constructed on the rear of the cabin (presumably to protect the rear wall from damage if heavy items moved during the journey}. This is constructed from 1.5 X 3 mm Sapelly battens.  For vertical battens are glued to the rear wall and then five horizontal battens are nailed to these.
    _MG_6867.jpg.8339fbe06ff3b8c181fc0547457c4338.jpg_MG_6870.jpg.e84fb882ec234d237afcc36c6dfae369.jpg
    The frame of the luggage rack will rest on the 4 X 4 mm beam  which see under this frame.  The base frame is supported by two 3 X 1mm brass straps:
    Mucjh of this good work will in fact be obscured by the leather cover which come next.  First the sides are covered with a triangular piece of leather.  A triangular piece of brass wire is glued to a square piece of nappa which is folded over and glued to form the triangluar shape:
    _MG_6934.jpg.7dacbe59ac526d5a986c33e0879ecebd.jpg_MG_6937.jpg.359d8700ec2ff23e40a08bf3bdde7acf.jpg
    Staps are then attached to two of the sides using brass nails:
    These straps are wrapped around the brass supports and the lower luggage frame:
    I found this part quite tricky since the leather needs to be cut to fit the gap quite precisely otherwise unsightly creases will appear.  The next stage is to make a leather cover which is fixed over the rear of the luggage rack.
    Work on this item continues.
    John
  17. On 8/30/2022 at 12:24 PM, glbarlow said:
    I got some of these, they broke so fast and so easy I tossed them. Glad your experience is different.
    Yes Glenn,  one thing that is very important is the quality of the drill press.  Many of the cheap ones "precess" ie the move like a spinning top.  This will break drills real fast.  So in such a case, as many have said. a better approach is to buy cheap ones and live with the breakages.  Incidentally, my Dremel on its stand does this but the Proxxon drill press is good.  I may have just bought lemon for the Dremel!
  18. Completion of the Drivers Box
    You may remember sometime ago I fabricated the railings for the Drivers box.
    _MG_6735_1small.jpg.fad33c522dc5e2c0d1c58b3c127ac8cc.jpg_MG_6787small.jpg.1cdb5e287695836cad15413064bf7639.jpg
    However, these proved difficult to install until the roof was in place.  Now that tat is done this section has been now been completed
    1659086039_Detailofboxsmall.jpg.9825099afa1d610c6a2f2d62efb1f6ed.jpg1620491998_Frontviewsmall.jpg.f24ebdb43d5dc0a1fbfa8d176aae8583.jpg
    and the seats installed
    This completes this area and fabricating the luyggage rack is next.
    John
  19. On 8/18/2022 at 10:48 AM, mtaylor said:
    I've never seen that last photo before.   Was the roof seating considered "first class" with fresh air and a view?  The "smoking" section?   Or another form of "steerage"?
    Yes, I suspect that in this case they might have been posing for the photograph but I have seen other examples with a few people on the roof.  You would hope they paid less than the inside passengers!
    John
