Ian_Grant
Everything posted by Ian_Grant
  1. OK Bill I managed to confuse myself re-reading about xxxhaul lines last night but now I have it sorted. That photo is not mine; it is incorrectly rigged. As shown on pg 235 the jib stay attaches to a thimble which is located between the arms of the shackle for the outhaul. Yes your thimbles are too big. I used eyes cut off from my etched brass eyebolts. For the flying traveller I gave up and had no thimbles. As for rigging, I now remember that by mistake I rigged the jib outhaul using the block on the left side of the traveller, which should have been for the downhaul. But after realizing this I just decided to leave it and rig the downhaul to starboard. The run-off effect of this was I rigged the flying outhaul to starboard, not to port, since they're supposed to be on opposite sides. So don't get misled by my earlier comments above regarding the jib outhaul being to port. But I made another mistake. For the outhauls, the block on the bowsprit cap should be on its lower front face, not the side. See Longridge pg 234, "....a single 9in block, hooked to an eyebolt in the lower end of the fore face of the bowsprit cap." This makes sense since the outhaul exits the sheave at the bottom of the round jib boom. On the same page he states two sentences later that the standing end of the inhaul is made fast to an eyebolt in starboard side of the bowsprit cap i.e. the opposite side of the outhaul. The jib outhaul eyebolt being on the front face of the cap is shown by Petersson in the drawing I posted in post #804. So to summarize, you need two eyebolts at the lower end of the front face of the cap, each having a single block attached. Port is for the jib outhaul, starboard for the flying jib outhaul. You also need an eyebolt on each side of the cap. Port is for the flying jib inhaul, starboard for the jib inhaul. When you make your flying traveller the block on its right is for the flying downhaul, its left for the flying outhaul i.e. opposite to the jib traveller. Longridge did not show a drawing for the flying traveller. As for the outhaul tending to lie in the thimble for the martingale at the bottom of your traveller, I would simply tweak it to port since it uses the port eyebolt on the cap's front face. One more thing to note - all flying jib lines running in and out along the bowsprit must pass above the sprit topsail yard or it would not be possible to set the sail. Good luck Mr. Phelps.
  2. Forestay and fore topmast stay added. I really should get on to those bowsprit guys, but I've not been looking forward to trying to thread through the netting 🤪. And of course the brackets for the chimneys when folded down 😁
  3. Bill, referring to the traveller diagram you showed from pg 235, the block labelled 8 is for the jib downhaul. The foot of the jib is held by the hook on the traveller, and the peak of the jib by the jib halyard which we see on Plan 9 coming through the sheave immediately below the sheave passing the jib stay. The halyard is used to haul the jib sail up the jib stay to set it. The jib downhaul from the traveller passes up the stay and is also fixed to the peak of the jib. It is used to haul the jib down when reducing sail. The jib and fore topmast staysail halyards belay on bulwark cleats seen about the middle of pg 266. The flying jib halyard is not shown, I think I tied it to an unused timberhead near the jib halyard. As you say, neither the jib nor the flying jib downhaul is shown in Longridge's belaying diagram; I tied them to convenient timberheads on the forecastle rail. EDIT: Yes, Hackney shows them leading to the centre two timberheads. My dinner is ready, must go. Will read the rest of your post later.
  4. Terry (I presume?).......Scalemates doesn't seem to mention any new tooling since 1979 unless I missed it. See below: https://www.scalemates.com/search.php?fkSECTION[]=All&q=heller+victory*
  5. HI Bill, yes he is a little vague here. I rigged the flying outhaul similarly except I didn't bother making a long tackle block I just used a small double block. The single block is attached to an eye on the starboard side of the bowsprit cap, opposite that for the jib outhaul on the port side. I can't recall if I actually found that info somewhere but it makes sense I think. I used the plastic flying job boom so I was able to drill a small sheave hole near the end. With your brass boom you may need a small block. I rigged the flying inhaul the same as that for the jib; starting at the end of the jib boom, through the block on the traveller then to a timberhead. I didn't glue the travellers in place. They are a very loose fit on the booms. The haulers retain them. These lines interest me. I'd have thought the wind on the sail would be trying to push it forward thus the inhaul would require more force thus more winding through blocks for mechanical advantage than for the outhaul but it is in fact the opposite.
  6. Remember Bill that you have my spreadsheet specific to Victory. The rigging sizes are given in it as per Longridge, and at 1/100 scale. Actual threads only come in given sizes, such as 0.1, 0.25, 0.5, 0.75, 1.0 mm. Larger sizes tend to come in shorter lengths. Your hearts would be good for the upper hearts on the stays, but to be accurate the lower hearts are open. Look again at Fig 140.
  7. Bill, I strongly advise you to buy some larger thread sizes despite what Heller may say. In general, the higher up the mast the lighter the rigging. The model's appearance will not be as pleasing to the eye if light threads are used lower down. The main stay is the largest rope in the ship apart from the anchor cable. Even the fore and main lower shrouds are 1.0 mm at scale; your 0.6 will be too slight. For example see post #801 and see how my fore stay and preventer are much more robust than the topmast stays. It just looks better balanced as a mechanical construct. As always though, it's your model.....🙂
  8. Bill, I assume you meant you are ok with the main stay but confused with the preventer 🤔. The preventer stay collar differs from the mainstay collar in that the ends are spliced to form a continuous loop of rope, unlike the mainstay collar where an eye is formed in one end and the other passes through it (after passing through the gangway, knightheads, and gammoning knee) and is then seized to itself. Fig 140 shows the structure of the preventer collar. It shows that the splice is positioned at the heart ("laid in the groove of the lower heart"). The two ends straddle the bowsprit and are lashed together beneath it. In practice I cannot splice thread so I concealed the join beneath one of the lashings at the sides of the heart with a little CA to keep it together. You can see these collars in Plan 6 Standing Rigging (yes, the big foldout. It's surprisingly useful!), with the mainstay collar passing through the knightheads and on down, but the preventer collar passing round the bowsprit only. Incidentally, on the old Pete Coleman Victory Modelling website, there was a bit of a debate about "the bend in the main preventer stay". You can see in Plan 6 that it passes by the knightheads before bending. If you build the Heller kit as supplied, this bend does not happen since there is no crosspiece between the two knightheads to support the rope in this manner. Thus the preventer collar lies against the main collar resulting in the main and preventer stays being too close together. I don't recall whether you bought Daniel's resin knighthead piece. It includes a crosspiece which allows realistic rigging of the preventer stay. I made the hearts out of wood; they're large enough to not be too difficult. Have you obtained large threads for some of these lines? The nearest thread diameters for fore and main stays is 1.6mm thread at scale; both preventers are 1.3mm at scale. Mizzen stay is 0.75mm, preventer 0.5mm. The fore and main topmast stays are 0.75mm; their preventers are 0.5mm. At the time I could not find 1.6mm black so I bought natural and fabric-dyed it. Hope this helps. EDIT: Oh, I just bought the smallest thimbles I could find, the 2.5mm ones.
  9. I just passed the ends through the gangboard eyes and seized them because even those 2.5mm thimbles looked oversized. No, the diagram does not appear to show the thimbles on the stay collar but they might be hard to depict, being so small. You could just lash them, I think that's what I did. Bill, I suggest you buy some of these thimbles. I used a lot of them for example at the bases of the main topmast and mizzen stays, where the mizzen stays reach the mainmast, at the boomkins, and a pair on each topgallant shroud. They were just too fiddly to make with the groove around the edge.
  10. Bill, a bullseye is round like a deadeye, grooved around the edge, but with only a single central hole. Also called a thimble. You can get them from model fittings suppliers although they seem to be harder to find lately since Model Dockyard closed due to retirement. Now that I look again, I see them here though oddly named. https://www.cornwallmodelboats.co.uk/acatalog/32571-Cording-Roller-Wood-2.5mm--Pack-of-10--32571.html#SID=67
  11. In fact I did. I used just seed beads, I think size 15/0, painted black. It is tiny so I omitted the wood bits between.
  12. In your first photo: Fore royal stay which goes to end of flying jib boom see Fig 166. Flying jib stay goes from taveller on flying jib boom to sheave of fore topgallant mast Fig 178. Fore topgallant stay also seen in Fig 178; goes to grommet at end of jib boom see Fig 165, then to port knighthead. Jib stay goes from traveller on jib boom through sheaves on topmast head see Plan 9. Topmast stay and preventer. Forestay and preventer. Not shown: fore topmast staysail stay. I think Longridge omits this as not being a permanent part of the rig as he states pg 225. It is also absent from the belaying diagram. One would think it would be near the jibstay and flying jibstay purchases..... The royal, topgallant, topmast, and fore stays are set up taut and then pretty much left alone unless they stretch. The jib stay and flying jib stay. being connected to the travellers, increase or decrease in length as the travellers are adjusted. That's why they go through sheaves and down to the deck with tackles; they need to be hauled in or let out if the travellers are moved, in order to set the jib and flying jib sails properly.
  13. Interesting! Thanks Veszett! Now I need to make those holders somehow 😉 😄
  14. Exquisite model! You are an amazing talent! Love your sculpy statues. I can't believe this is a card model. Since you asked, on a scale of 1 to 10, I give you 15!! 😉 Looking forward to your next build 😀
  15. Somewhat of a milestone - all five masts are now glued in. The lower and topmast stays are installed except for at the foremast. At the foot of each mast, all rigging lines to the bitts are attached with the groups coiled and dangling over the bulwarks. A less happy milestone - I knocked the starboard chimney off the boiler hut, for the third time! This time I am leaving it off for now; it's obviously a snag hazard. I think I need to rig the lower shrouds next, but before that I want to pre-attach all lines belayed at bulwark pins. The molded pins are mere tiny bumps, even smaller than those on the bitts. Probably small brass rod will be substituted for those pins actually used (I'm omitting all the bunt lines and probably staysail halyards and downhauls and definitely their sheets). I calculate 45 pins used per side....ouch! It adds up quickly with 5 masts.....Also need to think about the lower tacks and sheets.
  16. Bill, yes I built the Revell CS and Connie many years ago. I think I still have the instructions. No, I don't recognize the blocks tied to the gammoning (which incidentally is drawn incorrectly wound). Can't see which lines they want to tie to these blocks but I would guess they are the ones that ought to go to the knighthead blocks.
  17. Bill, one shortcoming of my Longridge's book is that many rigging lines are depicted only partly in diagrams, and there are critical bits of related info in text, often many pages away. It makes for a lot of page flipping back and forth. As you say, the information is right there in front of you, but difficult to connect sometimes. Are you aware of "Rigging Period Ship Models" by Lennarth Petersson? I bought it partway through my Victory build. This very useful book depicts each line in a beautifully clear single diagram. Just look the name up in the index, flip to the page, and behold - crystal clarity. There is no text at all in this book other than a foreword and page titles. If you want to familiarize yourself with the rigging this is a great book. However, it does not go into the actual purpose of any given piece of rigging, although the purpose can often be inferred when viewing the diagrams. Further reading may be necessary .....ie yet other books. Note that Petersson made these detailed sketches from contemporary models of a particular ship, namely the frigate "Melampus", so the details such as the belaying pin location need to be adjusted. Also, first rates like Victory differed in other details compared to a frigate. However, Petersson can be used to get the idea, then consult my Longridge's book for further nitty-gritty. Here are a couple of examples from Petersson, a propos of what we have just been talking about. And another just for luck:
  18. Bill, re your query about pics of bowsprit rigging: apparently I didn't take many shots of this area but here are a couple I found which may be of use. This one shows an early stage. You can see the three threads from the single blocks attached to eyebolts over each roundhouse, ready to rig into tackles for the guys (see pg 266) which each end in a double block (see bottom pg 227 / top pg 228). Also seen are the collars for the main stay and preventer, which you should think about now as access rapidly diminishes in this area. You can also just make out the blocks attached to the front of the knighthead. This pic shows the boomkin guys rigged with thimbles. Also the block for the fore tack to which I added a small piece of wood to create the shoulder. This shot shows how very busy the forecastle rail gets with multiple ropes belayed on each timberhead. Of note is that the forecastle hands were the oldest and most experienced in the ship since they had to handle both the foremast and the headsails etc. At the extreme left you can just make out the jib traveller, with the jibstay and inner martingale attached to it. Sadly the traveller inhaul and outhaul cannot be made out. I took a couple of new shots through the case (then the camera battery died 😭). This shot shows the blocks crowded above the spritsail yard through which the martingales and fore royal stay pass (see pg 227 "Martingales"). These then connect via tackles to some of the blocks on the knightheads (see notes at top of pg 266). This shot shows the guys rigged with the aforementioned blocks over the roundhouse. You can also make out the tackles at the knighthead. Note the multiple ropes per timberhead, it must have been a bear to operate. Lastly, Longridge lacks a clear diagram of the inhaul and outhaul arrangements for the travellers. Here is a shot from my notes, where I was trying to make sense of it. It's pretty sloppy so I will summarize: The inhaul is straightforward; from an eyebolt on the bowsprit cap, through a block on the traveller (see Fig 164 pg 235) and back to a timberhead. The outhaul runs from the shackle on the traveller, through the sheave hole at the outer end of the jib boom, and back to a long tackle block which I made by gluing two blocks together. The pendant for the outhaul starts on the ar*e (Edit: I had the full word typed in but when submitted it changed to ****, LOL) of a single block on the port side of the cap, runs through the long tackle block, back through the single, again through the long block, then to a timberhead. That should help you out................
  19. Oh damn, we were in Oxford too but didn't know about pitt's River. I'm still kicking myself because we also went to Bath and I didn't know the "Great Britain" was nearby!
  20. Although I'm busy now rigging another ship, I still mull a galley over in my mind as I walk the dog. I've looked into waterproof servos and they are $$$, nor are they truly "waterproof". The IP-67 standard defines a waterproof servo as one that will continue to operate for about 30 minutes while immersed to a few inches, or something like that. Although I was not proposing to fully submerge them, only the lower half of their housings, I worry about the prospect of water getting in where the wires enter which always seems to be at the bottom of one end ie where the motor is, which makes sense. Or past the gasket between the case bottom and centre portions. My latest thought is to connect metal-housed servos to the water via aluminum heatsinks bonded to the housings with thermally conductive adhesive. Either the heatsinks are immersed in water in an internal "well" beneath the servos, or they pass through the hull bottom and there is no wet well. They might be quite vulnerable hanging down while boat is being handled, but on the other hand there may be a torpedo ballast under the keel anyway, which could protect them. It will be many months of further thought before I complete my current build. Happy new year everyone!
  21. We took the kids to the UK and started in London for a while. I hated it too! Nowhere near as much fun as Paris. Incidentally, we made an effort to get off the tourist track in London. Highlights included the "Old Operating Museum", and especially a short train ride to "Bletchley Park" where they show one of the enigma code breaking machines in action and explain it all. Very interesting and sparsely attended. As for the rest of it, meh! The Cutty Sark, I don't really like the view from outside with the glass arcing upward; might have been better like a flat "sea". I may be biased by the fact that I went to the Kensington Science Museum solely to see Longridge's model of the Victory only to find that not only it, but the entire model ship gallery was gone and replaced by some crap about the internet. When I asked about it, the nice lady working there told me that, "Oh, we get lots of people asking what happened to the model ships, they must have been very popular". 🙄 But she had no idea where they might be now. Then I went to the National Maritime Museum hoping to see some models. Very disappointed by the new museum; the usual huge empty atrium in the architecture to awe the visitor but very little to actually see. I was through it in about 45 minutes as there is nothing to read about etc. Apparently all the navy artifacts were moved to the new Royal Navy Museum beside Victory in Portsmouth, but I didn't know that. Might get there someday. Modern museums are a pet peeve of mine as they seem to spend hundreds of millions building an architect's fantasy only to discover that the vast atriums etc take up so much volume that display space is limited. A prime example is the History Museum here in Ottawa. I've been in some museums in Austria and Germany in beautiful old buildings, internally just chains of interconnected rectangular rooms; no doubt a modern architect would be dismissive, but you know what they were crammed with interesting stuff. Also what is anathema to modern museums, lots of printed explanations to read, and not an interactive button-pushing display in sight Sorry Kevin, for sidetracking your log but Shipman touched a nerve. Your decks look great by the way!
  22. Marc, she is a composite clipper with teak planking on an iron frame. The steel spars suspending her are welded/bolted to her frame. When you tour her now, you enter through the hold and they explain that metal bits that you see painted a different colour are not part of the actual ship. I agree that it is much nicer than her old display. This picture shows how fancy the hold is now.
  23. Bill, The weight of the lower yards is borne by their jeers and their sling, see PLAN No 8 (from outer space?). [As an aside, I had that plan pinned up at my desk at work for many years. One day someone who was talking to me asked, "What IS that anyway?] The yards are restrained to the mast by the truss pendants, see Fig 171 (the pendants don't appear to be shown in PLAN 8). These pendants, when loosened, allow the yard centre to move forward away from the mast. This allows the yard to be pivoted slightly farther around before its leeward arm hits the leeward foremost shroud, allowing the ship to sail a little closer to the wind. Topsail and topgallant yards have parrals, see Fig 139, to allow them to slide up and down the greased masts. The sprit topsail yard also employs a parral since it must slide in and out along the jib boom. The spritsail yard has no parral as it remains in place, see Fig 167. For model building purposes, I drilled small holes in the masts and yards and used pieces of brass rod to locate the yards. The rods are invisible after rigging. I made parrals from seed beads and little slivers of shaped maple. It was relatively simple to lash these to the yards since yards were attached by the brass rods. Here is an example. The topsail yard is lowered because I am rigging "bare poles". Please excuse the dust.....🙄
  24. Yes, that's correct. Don't forget to tie the main buntlines to the bitts before adding shrouds, because the area gets caged in as you can now imagine 🙂
  25. HaHa!! We love watching Jeopardy! (I already knew the names and purposes of most of the lines before the build)
