Everything posted by Baker
No jig has been used. Everything is done "on sight". Make the deadeyes, drill holes and put in place. For me, plastic ship model building is easier than wooden ship model building. Let's say it is something like the"fingerspitzengefühl" build up after more then 1400 plastic models.) Thanks, The space to work easily on this scale is indeed rather limited. And this space is becoming less and less as more and more ropes are added. So the hardest part is yet to come
None, i cheat First assemble the deadeyes on the right place and glue with extra thin glue (Tamiya) Allow to dry (24h !) Only after that tie it to the lower schrouds Ready
Beautiful models and a great story.
Thank you all for the nice comments and likes Some progress is made on the standing rigging I encountered a problem attaching the deadeyes to the crow's nest. The solution found is not correct as it really was, but well suited for this small scale. The photos probably explain the method better than a long text in my google translate English. Current state Thanks for following
As always great work. But, why is someone from my family glued to your model? Greetings from Backer ( My last name is De Backer)😉
- 2,633 replies
- heller
- soleil royal
(and 9 more)
Magnificent work, and great to follow this build 👍.
- 168 replies
Thanks, To add extra detail to these small scales, is the simplest solution usually the best. Unless an extra kit with PE and resin parts is available. (We both do not have that luxury on our models)
This is difficult indeed on this small scale. That's how I solved it with my model Btw. nice work
Welcome from Belgium
Welcome to MSW Patrick
What I mean. These beams are too long and so come together on the deck. If the building description says so and you want to build it this way. Then you can do this. Actually, nobody wont say you're wrong (I certainly don't) I have been working on my GH for over 3 years now. Building a correct ship from the 16th century is almost impossible. No plans, of course no photos, only unclear drawings and some hull parts of shipwrecks. Only incorrectly built replicas.
Roter Löwe 1597 by Ondras71
Baker replied to Ondras71's topic in - Build logs for subjects built 1501 - 1750
Congrats. Nicely made cannon barrels. -
Standing rigging update Slow progress. Some parts of the rigging has been done 2 times. The first time bad, and the second time a little better. (instructions in the kit) Lower masts almost ready The hull is only 25 cm (about 10") long Thanks for following
Using pins
Baker replied to Oddball's topic in Building, Framing, Planking and plating a ships hull and deck
Looks logical. But, Planks, wales and beams are attached with : nails, bolts ,treenails And every era has its own methods The hull of a ship from the 16th century is different from a ship at the beginning of the 19th century. If it was that easy -
Patrick
