Posts posted by Baker
Thank you .
The "demolition work" has now been completed successfully on both sides. And the (3rd attempt) reconstruction is going in the right direction.
If everything goes according to plan, an update will be released over the weekend- scrubbyj427, mtaylor, Jeff T and 1 other
4
Great models
And
- AJohnson, mtaylor and Keith Black
3
The ships stand is ready, currently with a temporary name on it.
the planking above wale 3 went quite smoothly.
But,
The frame of section 1 is strongly bent inwards at the top. And the stem is straight at the top.
This result is an unnatural shape of the hull
So, removing these planks and start again for attempt 2. The advantage of PVA glue is that it softens again if you carefully apply isopropyl alcohol to the glue seams.
The planks can then be removed fairly easily.Surgery...
Attempt 2 : better
But...
I think I tapered the planks between wale 2 and 3 too much.
Wale 3 currently has no smooth line. I'm considering attempt 3 (this means more redoing) -
Very nice planking 👍
You can access the instructions in PDF via this link
- Keith Black, allanyed and mtaylor
3
In English would be nice.
Golden Hind?? (And the name Baker is purely coincidental)
Welcome back
- Keith Black and mtaylor
2
Planking update
The planking between wale 2 and 3 is ready and has received a first sanding.
The intention is to apply 3 more strakes above wale 3 and then sand the hull further and finish it with nails, treenails, etc.Part of the plywood bulkheads are also removed.
indeed,
And this is also an indication that this ship was built to last for a long time.- Knocklouder and mtaylor
2
No a post about progress, but solving a "wale mistery".
In a previous post I was annoyed by the strange shape of the wale.
well, solution found.
the notch at the top does have a reason. This prevents water on the wale from seeping in between the seam of the wale and the plank above it.Source : Het statenjacht Utrecht.
- GrandpaPhil, mtaylor, Ondras71 and 8 others
11
Congrats,
A very beautiful result
Congratulations, a very beautiful model.
Hello from the Thames Valley, UK
in New member Introductions
