Posts posted by Baker
On 11/4/2021 at 12:54 AM, henrythestaffy said:
If any members would like to make use of any of these cannons for a model then let me know.
If you log in to this forum again.
I am interested in the Mary Rose cannons- mtaylor, thibaultron and scrubbyj427
3
A very neat first planking 👍
Researched the planking of the hull of a galleon for my previous model.
(Starts in post 47)
Very impressive.
Great work
the bottle is not empty yet...
Need help ? 😁
congratulations, nice work 👍
- Ferrus Manus and Jeff T
1
1
Welcome back
- mtaylor and Keith Black
2
With the holidays over, time to start up again.
The second wale has now been placed. So now the planking between wale 2 and 3 can begin along with working out the gun ports.
Only the hatches of the gun ports have been found on the port side. and it turns out that they did not always have the same dimensions as the starboard side. Discovered too late to adjust, so they stay as they are now.(On their drawings in scale 1/100 they are neatly the same width on both sides...grrr...)
The bow cannon should fire fairly well forward (see drawing of the Great Harry). And between the stern and this gun are only 2 planks and not 3 as further aft.
I accidentally came across this while chopping wood. The right shape as support for the bow area.
Planking between wale 2 and 3 has started. I started on the port side, nothing left of this side. So this is the big exercise before starting on the starboard side.
Still a bit messy and a lot of thinking, touch up and sanding, but it seems to be going well this way.
Thanks for following, comments and likes
Welcome to MSW.
(also 59 and retiring next year)
- Swordfish073 and mtaylor
1
1
Yes, not a galleon. But a carrack.
But a good example
- Ferrus Manus and GrandpaPhil
2
1 hour ago, Ferrus Manus said:
Should i include all four, or only two.
if you have room at the channel of the fore mast. Then you can tie both 2 to this channel 1 in use and 1 in spare anchor.
in - Build logs for subjects built 1501 - 1750
Small update
The planking of the starboard side goes smoothly.
The bulk heads are adjusted in advance and the frames of the cannon ports were already partly made.
It's simply taking the dimensions from the port side to the starboard side and start planking.
and the laser also comes in handy.
I had some sawing work for another project and so I sawed wood for the base plate.
