Everything posted by Baker
Great work. But the way you attach the anchors is quite unusual. Normally these are attached to the channels of the fore mast.
- 16 replies
- Duyfken
- Modellers Shipyard
Before. This way you can do this easily and comfortably while sitting (And also much better for your back ...)
Roter Löwe 1597 by Ondras71
Baker replied to Ondras71's topic in - Build logs for subjects built 1501 - 1750
Russian modern armoured vehicles by Baker - ACE - 1/72
Baker replied to Baker's topic in Non-ship/categorised builds
Thanks The BTR'S are better cast than Ace's older models.But still sometimes a mess and a puzzle to assemble ... -
Hello from Duluth, Minnesota - and request for direction.
Baker replied to Joseph Lapp's topic in New member Introductions
Planking of the stern. First to do The cannon deck will become almost completely invisible later, so I don't put much time and effort into it. The sides will be further finished later. To further plank the stern, I first need to determine where the cannon ports should be placed. And discovered that the stern was not completely symmetrical. Fortunately, I used PVA glue that can be loosened with isopropyl alcohol. Error corrected The lower stern planked and with the 2 cannon ports Low quality interior I first have to consider what the next steps on the model will be. And, the hobby room urgently needs a makeover. As well as two bedrooms, the wife says....
Canadian movements from D'Day to the end of August. https://www.canada.ca/en/department-national-defence/services/military-history/history-heritage/casualty-identification-military/normandy-france.html After that. Northern west France and then West Belgium (map) left Canadian (coastal side) middle Polish units (corresponds to my mother's stories) right english Be careful with a Mk.VII in Canadian service at this stage of the war. Scots guards? a Mk.VII = ok
Update. The BREM 2 is ready and tagged. A BTR 70 under construction. and the NONA mortar carrier is started -
I came across this a long time ago in a Kit from Heller or Revell. What I remember about it from back then. Tested a few times and then it ended in the trashbin, either I'm clumsy or the thing is unusable.
Hello from North Haven, Connecticut, USA
Baker replied to PatLynch's topic in New member Introductions
Hello & HNY on 123123 from Philadelphia
Baker replied to ChiefScienceOfficerDrew's topic in New member Introductions
- 11 replies
- racing sailboats
- commercial ships
Ship in trouble by Ab Hoving - FINISHED
Baker replied to Ab Hoving's topic in - Build logs for subjects built 1501 - 1750
I'm glad the operation went well and you're feeling better again. A wrecked ship. This will be an interesting project. -
Thanks. No. I had no gaps in my little planks. But remember, on the original ship these planks were 10cm thick, 40 or 50 cm wide and meters long. Not easy to handle and to adjust once placed on the ships hull. So, if there is a gap between 2 planks under the waterline. Nail a batten over the gap, once the ship is launched. Gap, batten....? Where???😇. (My opinion 😉)
