Posts posted by RGL
All spray so far, one black section is the wrong colour so I overpainted it by hand.
- popeye the sailor, CDW, mtaylor and 2 others
5
Enjoying your build old boy! Don’t fret about the little guns, you can hardly see the things anyways.
Pre drill the holes into the hull, then predrilled Blocks of wood glued into the hull.
Same, the stuff for their DDG was just horrible, I’ve taken to using Tamiya rattle can Primer on big bits of PE after I wipe them down with acetone.
This is is an easy fix as I’ll just dab some little bits of black and red and overspray again with diluted grey.
Glad to see you on this forum as I believe youre from @cog ‘ s part of the globe so you can instruct him as well, and you can join our next joint build later this year.
- mtaylor, popeye the sailor, Canute and 3 others
6
Yes, they're a bit stark. As they are so adhesive, it'll need a scrape back to bare hull then repaint on that section/s.
I keep nagging Mr Park on FB what he’s going to include in the upgrade. I don’t think his English is that good but the masts alone are magnificent
I’ve made a start on the upper hull. A little bit of a wash to bring out the highlights on the hull plates I scribed in and degaussing cables. I then gave it all a light dry brush of white to highlight everything. It actually looks a lot better in real life.
I have to do some streaks yet but im going to wait until I’ve done the Walrus Catapult as I have to scratch build the ends which were not included in the kit (or upgrade set) and a solid shields amidships.
- Dubz, hexnut, Old Collingwood and 7 others
10
- Jack12477, popeye the sailor, Dubz and 7 others
10
I’ve tried to calculate it so I can mask and spray, then add things afterwards (ie; Carley Floats). The big bits will still need to be modulated to bring out details/highlights.
- Canute, lmagna, Old Collingwood and 4 others
7
True, so many lies out there.
Dirk, I completely agree, I suppose the issue is with the Internet photos are copied everywhere without references and it becomes impossible to find their original source after a while. Russian sites are a wealth of information for photos but as I only speak one language I have no idea what their captions are.
The IWM site is not really user friendly for searching. The AWM is a little better, and since the death of photobucket a ginormous amount of reference material has died never to be replaced.
- mtaylor, Dubz, Old Collingwood and 3 others
6
Very true, the IWM mentions the status of their photos as does the AWM. It’s when they are going to be used for a commercial venture.
- popeye the sailor, mtaylor, lmagna and 2 others
5
They’ll done down with a matte coat
- Jack12477, popeye the sailor, Canute and 1 other
4
Thanks, I have scoured the net for every photo I can, and only found 3 or 4 from 1943. So much rubbish with people just labeling photos of the wrong ship as KVG (or any other ship for that matter). Most research is open source these days and once your head is around what was fitted when makes it a lot easier to build.
Thanks, I’ve just added the boot strap. Next will be the depth markers, then the deck will be laid down. I can then drill the stanchion holes as the deck will give me the boundary.
Then weather the hull, place stanchions and rig it with ezyline. Every other time I’ve rigged the stanchions the superstructure has been on and it’s that little bit more fiddly.
Out of the set I’m going to use 2 shades, one of which I can probably replace with Mr Color or Tamiya, water dilutes it OK but it’s a pain to find how it works differently to the other acrylics.
Nice flogging you’ve given her!
- mtaylor, popeye the sailor, Canute and 2 others
5
HMS King George V by RGL - FINISHED - Tamiya - 1/350 - PLASTIC
Feel free to join in, if you use the Pontos upgrade you’re better off getting the Prince of Wales as that’s is what they designed the PE for (and it has aircraft for it unlike the KGV. You have the option of 1940 to 1943 that ways. If you want to do the 44/45 version you’ll need more AA guns for the modified boat deck.
