Posts posted by RGL
Small soft brush, only needs a tiny bit.
- Old Collingwood, cog, mtaylor and 5 others
- 8
- popeye the sailor, cog, Jack12477 and 11 others
- 14
- Canute, Jack12477, John Allen and 10 others
- 13
The old B&W photos make it look white really. I think it’s actually lighter than it’s supposed to be but I like it.
I may have destroyed a couple of sprue cutters that way. As such, never again!!!
i spent the entire day priming, then pre shading, and base grey coat. Nothing worth photographing. Light grey coats to go then pinwashes and a light dry brush, and start gluing again.
Hehehe.
Its easier to fix fix if it’s paint and not plastic that’s cut.
Yes, the PE that is fairly useless to me. So overpriced.
You don’t need need to make a tool, just a couple of rattle cans. Once you get it about .1mm thick you can just press in the hull plates. Much easier and safer than cutting plastic.
- Jack12477, Old Collingwood, lmagna and 3 others
- 6
What’s a G type?
Is Mushasi getting finished?
Sang Yan Park is planning to release a Soviet destroyer upgrade from Infini Models late this year ( I hope) so that would be the third of the Russians.
- Old Collingwood, Piet, lmagna and 3 others
- 6
I reckon it’s because the water goes down the sink with the opposite spin that causes the Vajello not to work down here. Ive just picked up the next build which is going to be an exercise in hull grunge.
What resin did you order? I’m thinking a few days on the airbrush will have me ready for weathering.
- Piet, popeye the sailor, Jack12477 and 3 others
- 6
Thanks, I think if I hadn’t done the ribs I would have made it a lot dirtier. There’s a guy called Koppeleski from up Cogs way who has posted his finished models on here, who has build logs on another site that I pretty much try and emulate.
- mtaylor, Old Collingwood, Piet and 3 others
- 6
Light hull grey from Gunze, I won’t use Vajello as it does not like me.
- mtaylor, Piet, Old Collingwood and 2 others
- 5
Well done Cog, you’re flying ahead of me.
- Canute, mtaylor, popeye the sailor and 2 others
- 5
HMAS Vendetta 1925 by cog, popeye the sailor, and RGL - FINISHED - Showcase Models -1/350 - PLASTIC
Posted · Edited by RGL
All the ladders added, stays added to the masts as per the plans.
Catching up Cog.
