Posts posted by RGL
26 minutes ago, CDW said:
Does this ship carry cruise type missiles in those large launchers?
She looks lean and mean.
Go to page 1 for photos
- Canute, popeye the sailor, robdurant and 1 other
- 4
Much to the dismay of Banyan, I have done a bit of weathering. Salt, rust, grunge, some light pastels. You can just see the anchors which are resin aftermarket for Japanese ships, with the stock cut half way down the shaft, the kit provided blob was just horrible. The chains and stoppers were replaced, the hawser holes drilled out and rusted chains added to the tops of aftermarket anchor stocks jutting out of the holes. Getting there.
- hexnut, Ryland Craze, Haliburton and 8 others
- 11
Mr. K is very good. His logs are excellent
7 hours ago, CDW said:
Very realistic. Beautiful model.
I noticed you don't have your IJN ISE listed in your completed builds. An oversight or ?
Just never got around to it. The bloke I’ve learnt a lot from has just posted photos of a DDG in completed models, he is an awesome modeller.
- mtaylor, Canute, popeye the sailor and 2 others
- 5
- lmagna, Dubz, Ryland Craze and 14 others
- 17
- hexnut, harvey1847, CDW and 8 others
- 11
I read in an online forum the other day how those who make models tanks and model planes are better modellers. I’m calling BS as they have a) never made a tall ship and (b) work in much bigger scales.
There is a LOT of aftermarket for both air and land, and an increasing amount for sea. The plastic blobs can only be beaten up so much to look real.
The main gun, the CIWS (think Darleks from Dr Who, see if you can pick the kit provided one) anti submarine rockets and the kit screech fire control radar are all available in aftermarket.
It is very red isn’t it, almost orange! I won’t grunge up the rest of the decks until all the details are added, (there’s a lot to go), and then I’ll probably use pastels. The upper hull has not been touched yet as I wanted to add the frames that’s hold the SS19’s as they have scuppers on the real thing (which I have added) and the railings as well so I know where the rust and grunge streaks will orintate themselves on the hull.
I think Soviet propaganda would not allow photos of dirty ships, and this beast is circa mid 70’s. HD photos of him these days show a lot of sins covered by paint.
IJN grey, modulated with gull grey then oversprayed with 50% light grey all covered with a blue filter.
- amateur, Canute, popeye the sailor and 2 others
- 5
- mtaylor, harvey1847, robdurant and 11 others
- 14
The main superstructure was glued down today. There is a heap of aftermarket to go on this, a radar, rocket launchers, CiWs and probably about 10 whip arials (as they are acupuncture needles they need to go on after also I don’t put them through my hand).
I’ve grunged it up a bit and tried to dry fit the 16 rocket canisters on the side which should fit flush to the hull but they don’t. Meh.
- Ryland Craze, CDW, robdurant and 6 others
- 9
- Canute, Captain Slog, BANYAN and 6 others
- 9
- mtaylor, hexnut, Ryland Craze and 10 others
- 13
One update PE set plus scratch/spares. I have finally received all of the other aftermarket for him being the guns and rocket launchers
- cog, popeye the sailor, mtaylor and 2 others
- 5
Apart from a pedestal that will belay part of the cage arial assembly (in the centre of the circle of railing), I’m pretty much finished this bit. I will paint the whip arials black (they are acupuncture needes) and rust her up a tad.
The two black blobs immediatly in front in front of the stacks are great big fenders. In the drone footage from 2017 in Hong Kong they are visible I’ll grunge tho area up a bit yet.
The little platforms on each each side with the target rings are the same as the real thing and I used spares glued onto pedestals.
- hexnut, mtaylor, Ryland Craze and 10 others
- 13
USS Carl Vinson by Wolfman_63 - FINISHED - Trumpeter -1/350 - PLASTIC - Conversion of Nimitz Kit
Awesome work mate, what’s next!?!
