Posts posted by RGL
Sweet ship, very nice. L'Arsenal probably have some French aftermarket for her.
Im in.
- Piet, Old Collingwood, cog and 3 others
- 6
The kit provided anchor is pretty much rubbish, the stock is a curved piece of plastic! There are also no stern anchors provided.
I widened the hawser holes holes and used a North Star anchor set, joined to the Artwox chain, running strait through to the capstans. Hawser holes covers, chain stoppers and brake handles, as well as covers for the bit where the chain runs into the chain locker.
The bit where the chain runs was recessed into the deck after the wooden deck was used, so I used the cut outs as stencils to cut plastic strip to fill the holes.
Mall of the bollards from the kit were shaved off ages ago and are brass on plastic strip.
Little bit of weathering, and railings to go.
- Beef Wellington, coxswain, BANYAN and 9 others
- 12
I read as it was just the platforms and practice barrel, the rest remained in place.
- popeye the sailor, mtaylor and Canute
- 3
Cog, there are 28 triple mounts to go yet, but only 9 singles. There seems to be a lot more details on these older Dreadnought type ships.
- popeye the sailor, Canute and mtaylor
- 3
- WBlakeny, Captain Slog, Canute and 12 others
- 15
Now the hull is done, I can paint the rear flight deck or veranda. This was poured concrete so I have made it lighter in colour and will weather it and the rails later. Next, the stick on deck, which required some trimming due to the gunnels I added so I can put the individual stanchions in. Finally a dry fit.
Given the ship on 1944 would not have been that beaten up prior to removing the catapaults, I have lightly weathered the hull (port side so far), and added some scuppers. Green, black and light grey overspray on the lower hull for a little grunge, then AK's streaking grime, crusted rust, slime, rust streaks and salt. It's come up ok so far. Once this is done I can work on the deck.
Breaking it up, the main cannons. I sightly disagree with Flyhawk placements of the 25mm's on top that does not consider the ammo boxes.
I used the Tamiya stanchions again as it looks a lot better. The training equipment on the barrels does not include the stands (I have not used them this time), as apparently they were only used when in training and the actual bit that clamps into this bracket is not included.
You can see the difference between Yamato and Ise main guns.
Very true, my grey primer seems to have gone off so I used the black. I'm still new to the airbrush gig (this is number 3), and I want to do a grey grunge coat plus a little bit of green.
- 3
- Kevin, Captain Slog, Dubz and 8 others
- 11
The hull has nice lines but the armour belt run continuously the length of the hull. I gave the hull 2 coats of Tamiya rattle can primer then measured up individual plates, then etched them into the primer coat with a strait razor. Then a black primer coat with the airbrush. I'll leave this coat for 24 hours now.
IJN Ise 1944 by RGL - FINISHED - Fujimi - 1/350 - PLASTIC
The Pagoda has been lightly weathered with grime, rust and salt. The lugs that go into the deck were cut off and it sits almost perfectly snug without glue. I'll weather the funnel next, then once attached I can add the crane and it's rigging. You can see from the close up there is a lot of detail to add, and I still need to add 9 25mm's, and do up the remainder of the 13.7cm guns plus one barrel which has gone god knows where.
