Everything posted by FriedClams
The water and steam piping turned out very nice, Keith. Tricky indeed and fiddly as well, especially in 1:120. I mostly use phosphor bronze wire now instead of brass because it’s harder and resists kinking and slumping. Tichy Train sells the stuff in 8” and 3’ lengths - .008” up to .04”. Just an FYI. Gary
- 732 replies
- Lula
- sternwheeler
Beautiful work, Glen - and now I know what parrel beads are. Gary
- 301 replies
- Constitution
- Bluejacket Shipcrafters
Looking really nice, Keith! I bet that girl frothed up some water getting some of those loads moving. Gary
- 732 replies
- Lula
- sternwheeler
Very nice progress, Jacques. Really like that toned down blue. I find weathering to be a process and I’m often not happy with an initial result. Try stepping away from it for a few hours, or better still overnight. Sometimes a fresh look will tell you what it needs. Gary
- 312 replies
- Chile
- Latin America
(and 6 more)
Very nice final photos, Eric - compliments to Mrs. Cathead. Congratulations on another beautiful river boat. I'm heading over to grab a seat for the model RR project. Gary
- 392 replies
Lula is coming along great, Keith. I do love that beam engine! Gary
- 732 replies
- Lula
- sternwheeler
Fantastic work, Glen! Great soldering and well - everything else too. Clean, crisp and as Keith said, handsome. Gary
- 301 replies
- Constitution
Greetings Fellow Modelers, Thank you Valeriy for your kind words, and thanks to all for the "likes." Here’s an update on the Pelican’s whaleback. First, the toerails along the P/S edges of the deck are cut to shape then heat bent. Next, the ventilator and its mounting/rotation flange got some color. I used a product on the cowl from AK Interactive that I’ve not tried before called True Metal. This paint was recommended to me by @TOM G and it works great although I haven’t yet mastered how to apply and polish it for best results. It’s a wax based colorant similar to Rub’n Buff, but whereas that product is more of an architectural hardware restorer, True Metal paint is produced for the model hobby and comes in a dozen or so colors that modelers can use. An interesting product that so far, I like – thanks Tom. The cowl below is a mixture of TM “steel” and “iron” applied with a colour shaper. Almost looks galvanized. A beveled coaming/plinth is added. The “wave break” is a diverter whose purpose is to keep water coming over the bow from flowing aft onto the main deck. It’s made from .03” (.76mm) sheet styrene which scales to about 1.4” (36mm) thickness. It’s dirtied up a bit and holes were drilled at each bolt-down location. The unit was temporarily located on the whaleback and selected bolt-down holes were drilled through into the deck. Leaving some of the bolt shanks provided a foolproof way to affix it without concern of getting glue smear on the deck surface. Bolts are Grandt Line 5113. The stemhead fitting is brass with a scale thickness of about .5” (13mm) and the eyes are flattened wire. One of the wires will be clipped flush on the backside and the other will penetrate the wood stem. A port side deck ladder is made of .035” (.9mm) brass rod and finished with Jax Flemish Gray. The ladder receives two styrene mounting brackets and weathering pigment. Two 40” (102cm) tie off cleats will be primed then painted with True Metal on top. I drilled into the bottoms and glued in stubs of brass wire for deck attachment. Then all of the above was glued to the model. Trim pieces were added here and there. All of it is basswood except for the half-round styrene on the right. A wider strip of half-round styrene was added as a rub rail just below the deck surface. This strip also secures the rubber membrane flap that folds over the deck edge. Thanks for stopping by for a look. Be safe and stay well. Gary
Nice progress, Keith. Great little structure and fully framed to boot! Gary
- 732 replies
- Lula
- sternwheeler
Hey Keith, now that's an idea! Wonder if I can find a used one somewhere? Yes Druxey, AutoCAD has been known to have that effect on people. I use DesignCAD for my 2D drawing and have for decades, but for 3D modeling I prefer FreeCAD over it and a number of other alternatives. I think it's a very good solid modeler and a decent surface modeler. There are many good "free to use" programs, but with FreeCAD you download it once and its yours forever; no logging on to a website, registering or having to use it in the cloud. And no concerns that after investing the time to learn a program, the company granting you free access might change the rules and make you a subscriber or a previous user. FreeCAD certainly has its quirks and weaknesses, but so do the alternatives. And I'm not a power user - I just want to make a few parts for my models. Extensive online tutorials and help is available. I found YouTuber MangoJelly Solutions to be a great help. Be safe everyone and stay well. Hope to have a Pelican update this week. Gary
Brig Le FAVORI 1806 by KORTES - 1:55
FriedClams replied to KORTES's topic in - Build logs for subjects built 1801 - 1850
Good to see an update, Alexander. Beautiful work as always! Gary -
Thanks to all for the comments and the "likes" Thanks Paul. It's actually an enjoyable process and the SLA technology does a great job of reproducing details and a smooth surface finish. Hey Jacques, that does sound like a good option and it's wonderful those resources are available to everyone. But I'm in a rather rural spot and a population center large enough to support something like that is some distance away. Thanks for bringing that up though as I'm sure it will be useful to other MSW members. Hello Druxey. Because this was my first serious go at it, it took a heck of a long time. I had so many "how comes", "why nots" and "what ifs" to understand and I deleted and started over many times. These are very simply objects and an accomplished 3D modeler could complete these before I even got started. But now that I have the false confidence of a beginner, it takes me a quarter of the time it did starting out. And of course, some designs are easier than others. In example, the simplest designs would be the gypsy heads which are cross-section sketches followed by a revolve - on a good day, 10 minutes. The winch cable guides, 45 mins. Winch drum and brake drum, 30 mins each providing I don't mess up. But by far the most difficult was the intake cowl as it entailed setting up user defined datum planes upon which cross-sections of the cowl are sketched and are then swept together in an additive pipe function. It sounds way more complicated than it is, and an experienced modeler would likely chuckle at my approach. Nevertheless, it took me hours to figure out, tripping and stumbling along the way and now that I almost know what I'm doing - an hour and a half - maybe. Once I got my head around 3D space and user defined coordinate systems within the global coordinate system, the steam stopped rising out of my ears. Thank you, Keith - your support is always appreciated. Thanks, John - they turned out better than I thought they would. Hello Wefalck. I am the one who is confused, not you. You are correct - this is SLA process using resin not PLA. Sometimes I type faster than I think. I will correct that in my post. Good catch and thanks! Gary
Paul, Keith, John and Dan, thank you for your kind and generous comments and to all for the "likes". 3D modeling seems to be popping up everywhere in scale model building so it’s time to give a try. I’ve always enjoyed the process of hand scratching detail parts, and I have no intention of giving that up. But I’m also aware of my limitations and previous projects have suffered from some ham-handed constructions and 3D modeling will help solve this problem. So, the Pelican will be a mix of printed and handmade details. I designed all the printed parts used in this model specifically for the Pelican. It is solid modeling done with FreeCAD. I created the files but didn’t do the actual printing myself. I don’t see myself using a 3D printer enough to justify owning one, but that could change as consumer units continue to improve and drop in price. Anyway, I uploaded all my STL files to a commercial printer (Print a Thing) and the parts were delivered in less than a week. The total cost for these printings was around $33 US including shipping, tax and setup fees. I ordered extra copies of each part thinking some might be deformed due to their tiny size and fragility, but this was unnecessary. These are likely all the parts I’ll be printing for this model unless I run into trouble scratching something. So here they are and just as I received them. No cleanup has been done to them. Stereolithography (SLA), opaque white resin. Below are the deck mounted winch cable guides. It would have been an effort to scratch one of these from styrene let alone four of them identically. I left off the bolt-down washers and hex heads because they wouldn’t have printed well in this scale. Instead, I’ll place injection molded bolt heads from either Grandt Line or Tichy Train. Here they are on an actual dragger (circled on the right). Above on the left is a different cable guide under one of the four gallows frames. There are three different warping/gypsy heads. I have about 14 cleats of several different sizes. The two largest shown here are monsters (40” (102cm)) that bolt to the deck on top of the whaleback. I didn’t realize cleats were made that large. This is another example where making two precisely the same would be a challenge – as least for me it would. The main winch cable drums, brake drums, pinion and bull gears. I only need one each of the gears, but I created different width versions because I haven’t thought through the details of the winch yet. The spooling drum diameter is very large in relation to its flanges, and I did this to reduce the amount of cable I’ll have to wind. And finally, the air intake cowls. The forward cowl has an integral mounting and rotation flange, but for the engine room intake I created the flange separately so I can adjust the height as need be. It’s the same cowl with a longer duct pipe. I added hex bolts to these flanges and with the naked eye they look alright, but under magnification look more like rivets. My initiation into 3D modeling design was a positive experience and only left a few minor scars. It is rewarding to create parts unique to a project that could have been a real pain to make or at least to make well. There is certainly a learning curve with 3D modeling and at times I was perplexed. But eventually all the loose marbles in my head found holes to drop into and the light bulb turned on. It’s easier than you might think. Now back to the boat model. Thanks for looking. Gary
Nice progress on the Constitution, Glen, really like the J. Ladders. Good news on the award but so sorry to hear about that bottle crack - what a bummer! I’ve heard downing a half bottle of Sailor Jerry can fix that. Gary
- 301 replies
- Constitution
Very nice work on those steam engines, Keith. That’s difficult modeling- putting two things side-by-side and making them look the same. Good to hear you’re putting a dredger on the to-do list! Gary
- 732 replies
- Lula
- sternwheeler
Congrats on a very nice SIB, Roel! I agree with Glen, a unique subject and a quality build. Gary
- 70 replies
- Scheldt River
- Dredger
Phil - S scale is 1:64 so an S scale 1" x 10" is equivalent to 1/64 x 5/32. Mt Albert Scale Lumber in Canada sells S scale lumber in 16" lengths and is available in bulk pricing (minimum of 50) if you need a bunch. Scroll down at the link below to see dimensions. https://handlaidtrack.com/product/stb-s-1x10-16/?v=0b3b97fa6688 They also sell packages of 6 if you need just a few. https://handlaidtrack.com/product/st-s-1x10-16/?v=0b3b97fa6688 Gary
- 274 replies
- minesweeper
- Cape
