Everything posted by bruce d
Byrnes saw fence advice sought
bruce d replied to geneinmurphy's topic in Modeling tools and Workshop Equipment
Others may have something concrete to offer but I would suggest a thorough cleanout of the mating surfaces where the fence grips the table. Unless it has been damaged the fence should (as you know) automatically align at 90 degrees so if it isn't then something is in the way, possibly just a bit of crud stuck in a bad spot on the fence gripping surface. HTH Bruce -
USF Essex by mtbediz - FINISHED - 1:50
bruce d replied to mtbediz's topic in - Build logs for subjects built 1801 - 1850
Wonderful model, Mustafa, well done. -
Archaeological_evidence_of_the_foremast.pdf
High torque, really low speed drill
bruce d replied to Brinkman's topic in Modeling tools and Workshop Equipment
What Mark said. -
I will experiment but it looks like a good way to hold a profile scraper instead of a bevelling blade.
I intend to raid the scrapbox and make one, looks like a useful gizmo. Thanks!
Swan-Class Sloop by Stuglo - FINISHED - 1:48
bruce d replied to stuglo's topic in - Build logs for subjects built 1751 - 1800
Cool find. Now I want one.- 475 replies
Brian Lavery wrote a detailed account of how the French Invincible (74) was captured and taken into service as HMS Invincible. This was in Warship 38 & 39 published in 1986.
Really like the look you have achieved with contrasting wood and painted pieces. The carvings are impressive, hoping for more images up close. Bruce
- 208 replies
- kitbashing
- Woodcarving
(and 4 more)
On the use of steel parts in modelmaking
bruce d replied to starlight's topic in Metal Work, Soldering and Metal Fittings
For smaller workpieces try an EPNS spoon or fork from the local yard sale. They are usually well worn and cheap so whatever electroplated silver is left can be wire brushed away. -
Spot on, Roger, one and the same -
Preac thickness sander
bruce d replied to bushman32's topic in Modeling tools and Workshop Equipment
Ron, ebay is your friend here. Get some accurate measurements from the dead one and with a few minutes stabbing away at the ebay listings you will be able to recognize a replacement. On the other hand if there is an engineering supply house within easy reach then ignore me and go straight to them ( as grsjax says in post above). Good luck! -
If your interest is in using steel for structural purposes, I believe Roger has explained the less troublesome alternatives in the post above. On the other hand, if it is because you want something to look like steel then bear in mind that it's highly unlikely anything on an ocean going craft would have been left in a bare-metal finish: it would have been painted. Still, if you need something to look like natural steel there is a way. Use nickel silver, which despite the name contains neither nickel or silver. It is an alloy, available in sheet form and is used most often in jewellery and cutlery making (it is the NS in EPNS). Of course this is just speculation since I don't know how you were considering using steel in your model. HTH Bruce -
... and ferric metals will cause discolouration in wood. -
Photo Reference Library
bruce d replied to JSGerson's topic in How to use the MSW forum - **NO MODELING CONTENT**
How about making it mandatory to cite the source of the photo? The mods simply delete-with-no-appeal if a citation/source is not included. -
Work Table Recommendations ?
bruce d replied to DanB's topic in Modeling tools and Workshop Equipment
My main bench is made using an Ikea wooden kitchen worktop mounted to construction-grade 2x4s. It was built to take a Myford series 7 lathe and associated tooling, and is bolted to the floor and wall. The lathe is long gone but the bench is now re-jigged to make better use of the underside storage for modelling (if I ever get back to it!). It is complete overkill for my present needs but was what was needed back then. The rule I have used for each of the several benches I have built, both in businesses and homes, is simple: ask yourself 'what do you want to do at the bench' and make what is needed. The two things I then add to the mix are (1) make it strong and stable enough to handle the worst you can imagine happening while going about your intended business and (2) be VERY careful of storing anything above/behind the bench. Whatever you put there, it will fall sooner or later and that is where your model will be. There is also a smaller bench nearby where I have the Byrnes saw, a disc sander and a mini milling machine. I recently made a new conti-board top for it to raise the entire working surface about three inches, putting a series of shallow drawers underneath. Wish I had done it years ago, luv them drawers. Many a good bench has been made using a door and a couple of saw-horses. The variety of tales told so far in this thread show the real test is simply 'can I do what I need to do at this bench?'. Hope to see your final choice! -
Howard, Olivia, that is a nice model. Concerning the "F19083" inscription, can I ask what part of the world you are in (and your grandfather)? No personal info please, it's just that an alpha-numeric like that could be a UK military service number.
