bruce d
Everything posted by bruce d
  1. Here is the link to the active ingredients ... https://en.wikipedia.org/wiki/List_of_synthetic_polymers … and silicon appears to be among the possible ingredients as does Teflon. Silicon is banned in my work area, old bad experience. I would be interested to know if it is in the product. Good find!
  2. Welcome to MSW Billy, looking forward to your log.
  3. Welcome Jacques, I look forward to seeing you here.
  4. I think the same applies to the lances, but the closer picture shows 'frills' much closer to 12 inches. I have no real idea why they exist on a lance on a boat in the hunt. The line to the wrist is on the lance, the killing weapon, not the harpoon. Grizzly stuff.
  5. If I understand correctly, you are asking about a hole called a 'lance tail'. I do not know for sure if this is the answer but here goes: A whaler's lance was a close quarters tool. It had a wrought iron head about five or six feet long fixed to a hickory pole about the same length. A line from the pole ended in a loop worn around the user's wrist. The lance was driven home, often repeatedly, and the mate had the job of hanging on while the struggle got rough. To keep the lance straight was a difficult task and had to be done immediately and rapidly while fighting the whale so a slot was provided in the bow area. The lance was rammed into the slot and the mate levered the handle to straighten the shaft, often in seconds in the middle of a kill. I do not know the name given to the slot for this horrific purpose but the position of the hole indicated fits (if I understood the question). HTH Bruce
  6. To be pedantic, bolt it down before doing any tuning. Have fun!
  7. Jorge, For what it is worth, here is my opinion: do not attempt to use the saw (or judge it) until you have bolted it down solidly to a worktop. Do not use 'vibration dampening' rubber feet, just tighten it down directly to the bench. Get some good blades. Then, set it up from scratch following the makers' instructions. Once that is done you will be able to figure out if the saw is adequate for your needs. Bear in mind that if you replace the saw on the basis of current performance, you will have to follow the process above to set up your new one properly anyway. HTH, Bruce
  8. Alexandru, Fantastic. Well done. I especially like your deck work and boat. Regards. Bruce
  9. Wait! Did it say the boat was collapsible, or the soldiers?
  10. Hello Ann and welcome to MSW. Your story is proof, if any was needed, that this is a hobby with a purpose. I am sure you will get pleasure from completing a task with such deep personal connections and hopefully the forum will be useful: it usually is. Regards, Bruce
  11. Hello Graham, I have just discovered your log and am greatly impressed. I had a quick skim through and believe the next thing is for me to go back to the start because just about every post I saw had something good. Regards, Bruce
  12. Now that is a pretty good trick: 17ft long, 100 soldiers with kit and drawing three inches of water! Reminds me of a modern cruise ship.
  13. So let's see: he was a fake bone model seller working for Bonaparte. Does that make him a Boney phoney? Or a model spy? I know, shuddup and go back to sleep ....
  14. Yes it does. When I saw it, that is exactly what I thought but wondered how often is it applied to a model? Now that the subject is itching me, I will see what is hidden in my shelves or digital stash that tells the story. Thanks, Bruce
  15. Thanks Druxey. And the next question: where is that rule written down? This isn't meant to sound picky. I looked at the planking on Toni's Swallow and saw a wide plank and a narrowed plank side-by-side to make good a section where the curve is subtle. I refer to the planking around the aft hatchway, better shown in the photo below.
  16. Toni, many thanks for the first class descriptions and images. There is something in the picture in post#44 that has made me think. This hurts so I hope you can cast a bit of light on the subject. I have indicated (with bad skill) the shaped planks around the deck fixtures. I have seen something like this before but do not know the rules. Are there rules? Are they dependant on the era? Lovely job on Swallow, I am learning every day. Bruce
  17. In light of the current situation I am putting the 'free stuff' on hold. I will repost once parcels and packages are safe again. Take care, Bruce
  18. In light of the current situation I am cancelling the 'free stuff'. I will repost once parcels and packages become safe again. Take care, Bruce
  19. From The New Shorter Oxford English Dictionary: jewel-block (nautical). either of two small blocks suspended at the ends of main and fore-topsail yards, through which the halyards or studding-sails are passed. There is no mention of 'jewel iron'. Hope this helps.
  20. Moxis, what a tidy workshop!
