Everything posted by bruce d
Hello Bob, Yes, it is a wonderful resource which I was introduced to by an earlier thread in the forum. This wood was considered a superior choice in the past for furniture and house trim and that is the source of my modest stash. I don't have enough to make a useful wardrobe (the ideal use for this aromatic wood) but more than enough for a ship's hull and base. Besides the general question, because you never know what will pop up, the particular point I was curious about was how it acts when bonded to another wood. It has resins, as all cedars do, and strong aromatic properties. Both could cause 'issues'. Any problems? Pretty sure I will use some but it seemed wise to tap into the collective (and vast) wisdom of this forum. Bruce
Hello, Does anyone have experience using a wood called ‘Cedar of Lebanon’? Wiki says ‘Cedrus libani, commonly known as the cedar of Lebanon or Lebanon cedar, is a species of cedar native to the mountains of the Eastern Mediterranean basin.’ I have a small, well seasoned stash of this. It is very easy to work with and takes an edge beautifully, but all the information I have found refers to large applications like doors and wardrobes. I have nothing to tell me how it behaves in small projects where it might be bonded to another wood: for example, is it stable enough to be used in bread-and-butter hulls? Any thoughts appreciated. Bruce
Very nice, Nils. I like the subject and the way you are approaching the build. By the way, have you formed an opinion on the plane you showed in post#21 yet? Bruce
Photo Etching - do it yourself
bruce d replied to Dziadeczek's topic in Metal Work, Soldering and Metal Fittings
Absolutely. And be sure to order the two front-and-back images to be printed 'emulsion to emulsion'. It is worth shopping around as prices vary. -
Thomas, John has given good advice. To add my two cents' worth, I cannot emphasize enough how important registration is if etching from both sides. Have a go at etching, there are several good YouTube guides and I suggest you find one that you feel suits your capabilities and facilities: some of the jeweler's processes can look very casual and amateurish but the fact is they work for those people. However, modellers who need through-etching are not well served by YouTube, and the reason is the difficulty of registering artwork produced without professional equipment. It can be done but the smaller the piece the easier (and the greater the chance of success.) Brian King's book (in the link in earlier post) is useful but the key to success in 2019 is to use the facilities available in 2019. The etching part of the process is within the grasp of any amateur willing to approach the task methodically, but getting the image onto the workpiece is, and always has been, the 'the trick'. Assuming you are going to use a photoreactive etch resist on your workpiece, finding out how your printer performs when given the task of printing mirror-image versions of an image is the first task. The reason is that you will need two images, exact mirror-images of each other, printed on clear sheet to be placed on either side of the workpiece. The image on these sheets must align perfectly, and this is where home printers may let you down. A slight skew or distortion in most printing jobs is invisible and will never matter at all but in this task any difference in the two images will produce an inferior etching. Also, the image toner must be on the surface that is against the etch resist that will be exposed. If it is not then the light will diffuse through the thickness of the sheet and give a false edge, which translates into a soft/poorly defined edge on the developed resist. Having an expensive printer is no guarantee of this particular characteristic. This task is not what modern printers were designed to do with great accuracy so it is necessary to test (you may find that the output of the printer is best in one part of the printed page, such as the middle or bottom, and that is where you will have to place the image). It is easy to see why size matters. There are build logs on the forum that include home etched components. It would be a good idea to study them and see if they match what you want to achieve and are willing to do. HTH Bruce -
Can you say how big, and what thickness material? One side surface etching or all the way through? Everything is possible. Bruce -
It looks identical to one I got 40 years ago, and yes, it was great and I used it for everything. My one 'improvement' to it was to tape a small bit of wood under the spot where my thumb rested to give a more positive feel to the grip. It lasted for years of heavy use and one day grew wings and vanished. Bruce
Oh dear. The railing for the steps is 180 degrees out: or perhaps it was an initiative test for the midshipmen?
- 550 replies
- confederacy
- model shipways
Hello Keith, Maybe you already know the magical material: https://www.milliput.com/ My 'go-to' when I scratchbuilt figures and animals decades ago. (tip: buy direct from Milliput, that way it will be fresh) HTH Bruce
UK - wipe-on-poly brand?
bruce d replied to bruce d's topic in Painting, finishing and weathering products and techniques
Update: Water based polyurethane varnish is now officially endangered in the UK. Ronseal and, I believe two other big manufacturers, have dropped it from their range in the last year. A chat with someone in an independent shop confirmed my hunch that polyurethane just isn't a sexy branding choice. There are more and more acrylic and spirit branded varnishes on the shelves but it looks like 'poly' is out of vogue. Poor poly. It is still available in the UK from at least two sources and I have bought what I hope will be a lifetime supply. The products still available are: Sadolin Polyurethane Extra Durable Varnish (CAUTION: THERE IS ANOTHER PRODUCT IN THEIR RANGE WITH A SIMILAR NAME) Johnstone's Durable Quick Dry Polyurethane Varnish There are probably others but I could not find them. Bruce -
I cannot say what they did in Portsmouth for Triton but in the Caribbean and American yards it was common to use mahogany for the false keel. For example, Bermuda had a wonderful supply of local cedar which was excellent for shipbuilding but they still imported African mahogany for the keel components and American woods for the deck planking. Nice start on Triton. Bruce
https://www.bbc.co.uk/news/world-us-canada-48377930 Bruce
Fantastic. Your build log of Cheerful is my benchmark. Bruce
- 574 replies
- cheerful
- Syren Ship Model Company
I will tell you about my process before I offer advice: you may think I am bonkers. I am nearly finished drawing my plans. This will be my third version. As there were no drawings of the prototype, but her dimensions were known, I researched, compared other ships, studied scantlings, fretted over details and then, with relief, settled on La_Recouvrance as a starting point. She shared many features with my subject AND had been modeled AND was well documented. So I used her lines, distorted the image with PhotoShop to make her the correct beam, painstakingly traced each frame section to scale, drew a keel, blah blah blah... and then realised that La_Recouvrance just could not be stretched/tweaked to look like Pickle. A lot in common, yes, but what I wanted: no. Next, I tried manually adapting the drawings I had digitally produced to make her lines right. This required a total reboot and after some wasted time I accepted that I would be better off to start again from scratch. So I did. Now, the silver lining to this cloud is that my first two attempts taught me good lessons in both digital and traditional technique and, more importantly, over time I had refined my 'mind's eye' image of what Pickle should look like and what will and won't work in a scratchbuilt model. The drawings I am producing now are stripped right down to the basics of hull lines, deck levels, mast and gunport positions etc. So, Caleb, I hope this is useful to you. I have not found a magic wand or a button to push that will produce drawings on demand and I confess there may have been a touch of such silliness in my original decision to scratchbuild a subject that has no existing plans (I can almost hear myself saying 'How hard can it be?), But I am stubborn, or so I have been told. I know you asked about bulkheads but they are a component in the puzzle so forgive the ramble. If you can find a drawing of a ship with the same lines and sections, you should be able to trace them and make the adjustment for depth of planking. Otherwise, study the excellent articles in MSW and other online sources that show how to read drafts, buttock lines etc and plot your own. I know that sound oversimplified but it is what I had to do in the end. Other than roll up your sleeves and see what happens when you start, there is only one bit of practical, nuts-and-bolts advice I can pass on. If there is a set of drawings for the ship you are modeling, or one with the same proportions and general lines, great: get it in your head and ignore the differences. Then, find a set of plans for a model of a similar ship that you like. In this case it is not the ship you need to like, it is the PLANS FOR THE MODEL you must like. Use these plans as, shall we say, 'extensive reference' when breaking down the parts needed to make your model. See what the keel, deadwood, fashion pieces etc look like in the model plans, how the stern and stem are shaped, how the bulkheads join up with the centre piece, do they support the deck or is that a job for separate beams, and so on. Then you at least have a starting point for each of the same issues when you go back to the tasks needed to make that ship you have in your head. Sorry for the long answer, you have given me a soapbox to tell of the experience so far. I will start a build log when there is something to show for all this preparation. Hope this helps and doesn't scare you off, I have enjoyed it even if I do moan about the learning curve. Bruce
Back in post #2 I said 'It sounds like we are plotting similar projects.' Little did I know: mine is 'Pickle', which I am sure you know worked with Entreprenante at Trafalgar on rescue work. Can't help immediately with plans for either of your ships but I will keep my eyes open. Keep us informed. Regards, Bruce
