Tigersteve
Everything posted by Tigersteve
  1. A square strip is provided in the kit to create the thole pins. I rounded the strip and pre-painted before cutting 1/4” pieces. Test fitting before applying glue will give you an idea how much time is needed to set the pins. After the glue dries, lightly sand the pins to the same height. Touch up the paint afterwards. It was difficult to capture a good photo of the result. Steve
  2. Lynn, it does not look too complex for you but it seems expensive for what you are getting in that kit. Looks like a solid hull also, which comes with its own challenges. Looking for cost effective options for you. Another option is the Model Shipways Pilot Boat. Chuck Passaro has written a great practicum to supplement the instructions. https://modelexpo-online.com/Model-Shipways-PHANTOM-NY-PILOT-BOAT-196-SCALE_p_1017.html
  3. Longboat is a great kit with great instructions, but I have to disagree with that as your next choice. The scale and the planking make it very challenging and it could be frustrating. You have many choices though. Message me if you want specifics. Steve
  4. Well, if you got it on the first try that would not be normal! Lol You’ve already learned that the redo will always be better. Steve
  5. While I craft the thole pins, here is option #2 for presentation. This was my original idea for the bucket placement. If you are following this log or just came across it, please let me know which one is your preference. Your feedback is appreciated. Steve
  6. Here’s a couple of reference photos of the presentation I’ve settled on. Let me know if it’s too “kitchen sink” with the extra oar stowed underneath the thwarts. The rope and thole pins should complete the look nicely. (I hope!) Steve
  7. Lynn- I have to agree with Ryland’s recommendation. Model Shipways Muscongus Bay Lobster Smack. It looks like you will get some needed planking practice on this model and you have many different finishing options later in the project. It’s fairly inexpensive and will take quite a bit of time to complete, which is the way it should be. You will know when you are ready for a more complex project. No need to spend hundreds on a kit especially at this moment. Hope this helps. Steve
  8. Thank you very much gentlemen! I am not looking forward to creating or installing the thole pins Steve
  9. Leathering is completed and one coat of Wipe-On-Poly (second photo). I suppose I will need to eliminate one for the presentation. Steve
  10. Using the techniques described in the manual, I tapered and shaped the oars. To get a consistent tapering across all oars, I used the technique shown in the first photo where I sanded towards the blade. The oars were treated with several coats of natural stain followed by two coats of golden oak, which were wiped off after about a minute of saturation. Leathering is next. Steve
  11. I think the sail looks pretty good. Shouldn’t the spar be rounded though? That is sticking out to me. Doesn’t look right. Steve
  12. Finishing the paint job on the buckets took a while. White and green paint were mixed in different ratios to get the desired hue. The final coat was the lightest version of this mixture, followed by a damp brush while the paint was still wet. This removed most of the last coat to create the texture. Holes were drilled in the buckets and the thwarts were permanently installed. Next, I will work on the oars. Steve
  13. Made four buckets- two quarter size and two nickel size. One bucket did not survive, but I think it would have been too crowded in the presentation. These will be painted and holes drilled. 3/16” strips were used in the construction. I applied one coat of paint after this photo, but used too much water. There’s a bit of touch up needed as the water caused some damage. Stay tuned… Steve
  14. Thanks! Took a little break after the painting fiasco. Must build the buckets… Steve
  15. Nameplate applied. This material is shinier than the nameplates on my other projects. Apparently, they don’t use that other material any longer. It’s a bit shiny for my taste, but it will have to due for this project. Still looks clean. Steve
  16. Thank you for the compliments. Means a lot coming from fine craftsman like yourselves. Steve
  17. Testor’s Dullcote does not react well with Tamiya paints. I was getting a spotty, eggshell type finish. To recover, I sanded the surfaces most affected and repainted. Lesson learned. Test finishes off model. I will be using different paints going forward. Also, do not use Wipe-On-Poly over paint unless you want a sheen. I wish I took this advice on previous models. I over worked the sanding of the oars and have requested replacement parts from Model Expo. While I wait for those parts, I will construct the buckets and start the rope work on the model. I purchased Syren rope for this. I worked on the layout for the nameplate. Measurements are 3.25” x .25”. I will get that made at a local trophy shop. Very inexpensive and adds a nice finishing touch to the project. Thank you Mike Stuntflyer and Ryland Craze for your assistance on the paint finishes. I learned a lot from our exchanges. Steve
  18. Really sharp! Some serious geometry happening on this ship. Steve
