Everything posted by Tigersteve
This part of the project is tricky. Yours is looking good. Steve
- 77 replies
- model shipways
- pinnace
I had received my copy of volume 3 before the holidays. Now that I have the correct CD sent from the publisher, I’d like to say some things about the whole package. Even after a quick look at the content included in the book, CD, and the 13 drawings, I can easily say that it’s extensive, wow! What a great resource Ed has put together. It would have been a shame to not have the correct CD, which includes several additional materials. The build log PDFs and rigging checklist are just some of the cherries on top. It’s worth purchasing even if just to find out how Ed contained the massive amount of rigging content into this single volume. It is well done. Steve
- 3,618 replies
- young america
- clipper
Hull planking is complete. Several days of sanding and filling. I used 100 grit through 400 grit. After primer is applied I will see how much more work is necessary to achieve a smooth hull. The stern needs more sanding. I will sand more in that area after the keel and stern post are attached. A tip for those building this vessel in future. Add filler blocks for the first three bulkheads. This will show you if you have the correct shape and help with fairing and planking. I did not fair enough in some areas. The shape at the bow is tricky. Mine still needs work. Steve
Careful with the sanding drum. May be better to use a sanding disc attachment. Easier to control. Steve
- 77 replies
- model shipways
- pinnace
Just received my copy today. Looking forward to enjoying it. On first glance it looks well executed as expected. Steve
- 3,618 replies
- young america
- clipper
Like your first version of painted shingles best v natural Steve
- 1,784 replies
- winchelsea
- Syren Ship Model Company
Back to planking the remainder of the hull in basswood since this will be painted. Almost done with the first belt on the port side. I anticipate many rounds of sanding and filler. Not obsessing over this part of the planking, as I’m fairly sure I can get a nice surface for painting. A drop plank was created at the bow, which I may show in a later post. Nothing worth photographing at this point, but here’s a photo of some plank bending. Steve
I think I had about 10 as well. Marking the frames will help keep your symmetry and the cap rail will finish it off nicely. I planked from the keel up and ended up redoing the top two strakes. Steve
- 77 replies
- model shipways
- pinnace
I had the name plate made at a trophy place. Very inexpensive. Steve
- 77 replies
- model shipways
- pinnace
Thin brass tubes or rods are the way to go. I used 1/16”. Steve
- 77 replies
- model shipways
- pinnace
Thanks! This was another challenging build, but I had a lot of fun modifying some of the features. Steve
- 77 replies
- model shipways
- pinnace
Really nice work on the mini version. Looking forward to seeing the larger one come together. Steve
- 77 replies
- model shipways
- pinnace
It’s looking excellent, Chuck. How is the learning curve with working with this wood? Specifically being able to avoid leaving dents since it’s very soft. Steve
- 1,784 replies
- winchelsea
After messaging Chuck, I adjusted the planking band as there was too much taper. I took a different approach and marked ten planks on most bulkheads and adjusted the tape to a smooth curve. Chuck suggested adding a drop plank, which will result in one less plank terminating at the bow. I will follow this plan and also add a stealer at the stern. Although below the whales will be painted, I wanted to use this project to improve my planking technique. Steve
Determining the planking belts. Tick strips were used to determine and mark the halfway point of the remaining area to be planked. This was done from bulkhead D through 4B. Adjustments were made based off these measurements. I could use our experts feedback on the lines of these belts especially at the bow. Steve
You should test on scrap wood. Steve
- 66 replies
- bounty launch
- model shipways
I would use a long free cloth wrapped around your finger and rub your finger between the ribs. Direction doesn’t matter too much on the inside of the hull. Floorboards will cover some of the finish anyway. What stain color did you decide? Steve
- 66 replies
- bounty launch
- model shipways
