Robin Lous
Posts posted by Robin Lous
  1. Thanks...the deck planking is abachi, the tree nails are walnut.
    I picked walnut, because the tree nails are tiny (0,5 mm)
    I'm not sure what I should do with the hull planking. The planking will be walnut, so no idea what I can use for the tree nails there.
    I'm afraid lighter wood will look odd. Walnut on walnut might be subtle, but perhaps hardly visible ( a lot of work for no result?).
  2. Just to show I'm still working on the shipyard...a minor update.
    Only very limited shipyard time until January, so things slow down, but I do something daily.
    Most deck planks done, so more nailing trees soon.:P
    I switched from painting the sides of the planks with a brush to dab the paint with a cotton bud.
    This goes much faster and it doesn't destroy my paint brushes. I use undiluted acrylic paint, so the paint won't suck into the wood.
    More soon(ish),
    Robin :)
  3. Thanks guys,
    I now finished the centre part of the deck planking...including the wider planks (schaarstokken) these wider planks don't have nails in them.
    Different from the manual. After checking photo's these planks are wider, but not noticeable higher. The manual uses 2 regular planks glued on top of eachother.
    I used wider planks...only a fraction thicker.
    232 hecho a mano tree nails used so far.
    I can now continue the planking, but near the sides (in between the frames) it has to wait until after the hull planking.
    Frames 4 to 8 will be removed after planking the hull.
    Slow, but steady...more soon.
    Robin :)
  4. Well Carl, the only way I could think of to make the tree nails....
    On 16-11-2017 at 4:18 AM, EJ_L said:
    Those tree nails will be a long and tedious venture but it looks like it will be well worth the effort. Looking good!!
    It is tedious, but only making the tree nails...the rest goes reasonably quick and easy.
    Marking the place with a pencil, the drilling, placing (with a drop of PVA on the tip), cutting and sanding...all no problem at all.
    Just sharpening those 1x1 mm walnut strips takes most of the time. I do a batch of about 40 in 30 minutes....just the sticks.
    Where I am now...
    By trial and error I learned it's far more easy to use longer punji sticks.
    The cutting off with a cutter or a pair of decal scissors, filing and sanding is done in minutes.
    It's all fine, because I think it is worth the effort and because it's 1/50 scale the 0,5 mm tree nails don't look too oversized.
    A lot of it will be hidden underneath the foreccastle and the quarter deck, but well...I do those also. :D
    138 done!
    More soon,
    Robin :)
  5. I finished planking the centre part of the deck.
    And I used this photo to make the mast foot...
    Because the caulking between these planks is very wide, I used 0,4 mm thin walnut strips for this.
    After all...the walnut tree nails I'll use on the deck are not tree nails, but is also caulking, so it does match.
    The wider/heavier planks (Dutch: schaarstokken) next to the centre part shown here also...not in place...just to show them.
    I painted the sides of the deck planks with dark smoke brown (Vallejo 70.939).
    Tree nailing this part of the deck is next...I hope I can nail this (lol), it can make or break the look of the deck. Very scary job!
    More soon,
    Robin :)
  6. 10 hours ago, cog said:
    but the upper side of a grating usually looks like the one you are not using.
    Might usually be true, but this is how it looks on the replica ship. I didn't study 1595 gratings used on a Dutch pinas, so it can be wrong.
    Now busy with the planking...
    Before someone says the planks near the mast are not staggered, that's because this part will be covered with mast foot planks.
    This is the part in between the schaarstokken (translation?). I use wider planks for them.
    I'll tree nail the deck with 0,5 mm walnut (the planks are 4 mm wide).
    Since work will become increasingly busy until the end of the year...I'll be happy when I get the deck done this year...and perhaps finish the balsa.
    More soon, but it will slow down on my shipyard.
    Robin :)
